Property for "Connect every time the workbench is started" ? [message #57254] |
Sun, 12 July 2009 21:32 |
Originally posted by: yoduderoo.netscape.net
I am programmatically creating a database connection. Works fine.
However, I can't figure out which property to pass so that the db is
connected every time the workbench is started.
Specifically, I am referring to the Properties instance ("prop") in the
snippet below :
ProfileManager.getInstance().createProfile(
profileName,
"Description store",
DerbyProfileFactory.PROFILE_ID,
prop);
What is the property (which I presumably would pass in the "prop"
instance) for connecting at workbench start-up?
Thanks,yo
Re: Property for "Connect every time the workbench is started" ? [message #57280 is a reply to message #57254] |
Mon, 13 July 2009 11:20 |
In the meantime, looks to me like there is no property. Instead,
auto-connect is a boolean argument to two of the three
ProfileManager.createProfile() methods and the
ProfileManager.modifyProfile() method. So I set that boolean to true,
and the profile sets auto-connect.
Only thing, I don't understand what a "parent profile" is. It is
required in the createProfile() methods where the autoConnect argument
occurs. Anybody know what a parent profile is?
Thanks, yo
Yo wrote:
> snippet below :
> profileName,
> prop);
> Thanks,yo
Re: Property for "Connect every time the workbench is started" ? [message #596067 is a reply to message #57254] |
Yo Messages: 10 Registered: July 2009 |
Junior Member |
Thanks, yo
Yo wrote:
> snippet below :
> profileName,
> prop);
> Thanks,yo
FUDForum. Page generated in 0.03088 seconds
