Debug and Run Configurations Speed Varies [message #57132] |
Fri, 13 June 2003 21:39 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: vnssoftware.myway.com
The same application takes less than a minute when doing Run>Run..It takes
more than 5 minutes when doing Debug>Debug..(that is in debug mode)
Why? PLEASE HELP OTHERWISE ALL MY EFFORTS TO GET ECLIPSE FOR DEBUGGING
WILL BE OF NO USE SINCE I CANNOT DEBUG WITH SUCH SLOW SPEED!
Thanks...
Re:INFO ADDED Debug and Run Configurations Speed Varies [message #57188 is a reply to message #57132] |
Fri, 13 June 2003 22:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
vns wrote:
> Thanks...
Just for info sake-
I am using Eclipse 2.1
JDK from Sun 1.3.1
Thanks...
Re:INFO ADDED Debug and Run Configurations Speed Varies [message #57521 is a reply to message #57188] |
Sat, 14 June 2003 15:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
No need to shout your needs....
Increase the memory of the JVM.
On MacOsX I modified -vm in the info.plist of Eclipse to have -Xms90M
and -Xmx250M. It incresed the speed a lot.
Patrice Drolet
Re: INFO ADDED Debug and Run Configurations Speed Varies [message #57967 is a reply to message #57521] |
Mon, 16 June 2003 00:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I am on Windows 2000. Is info.plist present there?
Can there be any other reason for this difference. Is Memory Requirement
for Run and debug configurations so different? Thanks.....
Re: INFO ADDED Debug and Run Configurations Speed Varies [message #58015 is a reply to message #57967] |
Mon, 16 June 2003 00:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
>> Xms90M and -Xmx250M. It incresed the speed a lot.
> Requirement for Run and debug configurations so different? Thanks.....
On Windows 2000... I do not know. Somebody can certainly helps here.
I know that on Macosx, if I debug it is faster when I increase the
memory of the JVM.
Patrice Drolet
Re: INFO ADDED Debug and Run Configurations Speed Varies [message #58039 is a reply to message #58015] |
Mon, 16 June 2003 01:14 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Can Hotspot / Classic version help in debugging with jdk 1.3.1
Should I be passing -classic parameter in the command line options?
Thanks once again for help....
Re: INFO ADDED Debug and Run Configurations Speed Varies [message #58089 is a reply to message #57967] |
Mon, 16 June 2003 02:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: bob.objfac.com
Don't look for other reasons until you've tried more memory.
If you're on Win2K, and you're starting Eclipse by double-click, make a
shortcut. Then right-click the shortcut > Properties and enter the Target as
G:\eclipse\eclipse.exe -vmargs -Xmx256MB
adjusting the path to fit your configuration.
Bob
"vns" <vnssoftware@myway.com> wrote in message
news:bcj2pa$2fb$1@rogue.oti.com...
FUDForum. Page generated in 0.03641 seconds
