Home » Language IDEs » PHP Development Tools (PDT) » command line debugging
command line debugging [message #57062] Fri, 05 October 2007 10:12 Go to next message
Originally posted by: ben.nordin.parivedasolutions.com
I'm having problems debugging cli scripts. I can debug web pages just
fine. I can usually run Zend's command line debugger until I hit a
module that I need loaded. I have tried changing the PHP executable to
Zend Core's, which has the proper modules and configuration. However,
I'm getting an errors because it's trying to read the configuration from
"C:\Windows" instead of the "C:\Program Files\Zend\Core\etc" directory.
How do I change this? Is this even the correct approach?
Thanks for your help.
Ben
Re: command line debugging [message #57112 is a reply to message #57062] Fri, 05 October 2007 11:32 Go to previous messageGo to next message
Originally posted by: Martin.eisengardt.de
Configuration directory might be overwritten inside Apache (PhpIniDir
directive).
have a look at http://www.php.net/manual/en/configuration.php
Did not test it but setting PHPRC environment variable should help. You are
possible to set it within eclipse/ debug configuration at the environment
tab.
Re: command line debugging [message #57138 is a reply to message #57112] Fri, 05 October 2007 12:47 Go to previous messageGo to next message
> directive).
> tab.
No dice. The PHPIniDir directive is not used within my Apache
configuration. Anyways, since this is a CLI problem, I don't see how
Apache is involved.
I ran phpinfo() from eclipse and got the following:
Configuration File (php.ini) Path => C:\WINDOWS
PHPRC => C:\Program Files\Zend\Core\etc
If I run from the cmd.exe command line I get correct results:
Configuration File (php.ini) Path => C:\Program Files\Zend\Core\etc\php.ini
I checked the IniFilePath setting in the registry, and it is correct. I
even tried passing '-c "C:\Program Files\Zend\Core\etc"' as a command
line argument within eclipse. It is still trying to read from
C:\Windows\php.ini.
Re: command line debugging [message #57192 is a reply to message #57138] Fri, 05 October 2007 17:37 Go to previous messageGo to next message
OK. Do not know why but PDT copies my configuration file and inserts some
things (includes paths etc.). There seems to be no chance to overwrite
configuration directory at cli.
>> Loaded Configuration File => C:\Dokumente und
>> Einstellungen\mepeisen\Lokale Einstellungen\Temp\php.ini
This file will be created by PDT. It takes your PHP.ini located near your
PHP.exe. Simply place/copy your correct configuration file within the same
directory (at linux I use a link instead). At command line PHP does use
every environment variable and registry setting (as intended). But PDT
overwrites this with a special manipulated php.ini
I think PDT should respect any environment variable described in PHPs manual
to find the correct file. Maybe You can fill a bug report :-)
Greets
Martin
Re: command line debugging [message #57274 is a reply to message #57192] Mon, 08 October 2007 14:26 Go to previous message
Thanks Martin! Copying the configuration alongside php.exe solves the
problem for me. I reported bug #205754.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=205754
Ben
Previous Topic:Debugging stops with "Error"
Next Topic:problems with zend pdt
Current Time: Wed Apr 16 00:33:32 EDT 2025
Powered by FUDForum. Page generated in 0.02734 seconds
