Home » Eclipse Projects » Equinox » problem with EclipseStarter
problem with EclipseStarter [message #56943] Mon, 16 January 2006 19:49 Go to next message
I'm still using the latest official 3.1.1 Eclipse release with its
Equinox internals, and I'm having issues launching Equinox with the
update configurator.
I apologize for the length of this post. I thought it better to be as
complete as I can. Specifically:
I have the following disk layout.
/root
/plugins
org.eclipse.osgi_3.1.1.jar
org.eclipse.core.runtime_3.1.1.jar
org.eclipse.update.configurator_3.1.0.jar
my.test_1.0.0.jar
In other words, I want my disk layout to mirror that of Eclipse
including, eventually, support for /root/features.
I'm invoking a JVM with a class-path of
/root/plugins/org.eclipse.osgi_3.1.1.jar
I'm setting the system properties: (\+line breaks for formatting)
---start properties
osgi.bundles=\
org.eclipse.core.runtime@1:start,\
org.eclipse.update.configurator@2:start
osgi.configuration.area=\
/root/config
eclipse.ignoreApp=
true
---end properties
I'm using org.eclipse.core.runtime.adaptor.EclipseStarter.main() as my
Java entry point. I'm also initializing the OSGi console with no exit so
that I can see the OSGi status when I'm done.
The first thing the EclipseStarter does is set the PROP_INSTALL_AREA
system property ("osgi.install.area") to the directory of the system jar
(i.e. /root/plugins). This overwrites any value that the system property
already has. (The fact that this system property is essentially
read-only is not clear from the documentation.)
The configurator starts but does not find my test jar, or any jar for
that matter. Near as I can tell from my debugging, when the configurator
is going to look for plugins, it appends "/plugins" to the install area,
and thus looks in /root/plugins/plugins. This is obviously not right. To
me there appears to be an "impedance mismatch" between Eclipse and OSGi.
1) Has this been changed in 3.2?
2) Do those who use the OSGi system jar with the configurator put the
system jar in the parent directory (e.g. /root in my layout)?
3) What am I supposed to do if I want the Eclipse disk layout? Should I
start my process with startup.jar, or will I run into the same type of
problem?
Thanks in advance.
/djk
Re: problem with EclipseStarter [message #57865 is a reply to message #56943] Mon, 23 January 2006 23:42 Go to previous message
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
This sounds like a great bug report. Certainly what you are proposing
should work. Can you try this same thing with 3.2 and report on your
success/failure?
Jeff
"David Kemper" <djk@tibco.com> wrote in message
news:dqhev3$kr$1@utils.eclipse.org...
> /root
> /plugins
> my.test_1.0.0.jar
> ---start properties
> osgi.bundles=\
> /root/config
> eclipse.ignoreApp=
> true
> ---end properties
> problem?
> Thanks in advance.
> /djk
Previous Topic:plugins is not a valid directory when launching through Java Web Start
Next Topic:Starting framework from Java code with EclipseStarter
Current Time: Tue Oct 28 23:49:44 EDT 2025
Powered by FUDForum. Page generated in 0.03732 seconds
