java 1.5 compliance [message #56896] |
Mon, 25 April 2005 15:05 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: cookie.monster.somewhere.com
I have just install eclipse and started my first java project but have a
problem with java 1.5 syntax. Basically the IDE does not recognize the new
1.5 syntax. When I check the project settings the compiler compliance
allows 1.3 and 1.4 but no 1.5. What's going on? How can I get eclipse to
recognize my 1.5 java code??
I'm using the latest version from march 12th.
thanks!
cookie.
Re: java 1.5 compliance [message #57142 is a reply to message #56948] |
Mon, 25 April 2005 21:15 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: hendrik_maryns.despammed.com
Darin Swanson uitte de volgende tekst op 25/04/2005 17:31:
> You are using the 3.0.2 release of Eclipse which does not have the 1.5
> support.
> 1.5 support has been added in the 3.1 stream of Eclipse. Try 3.1 M6
How can I upgrade from 3.0.2 without having to re-import all my
projects? It doesn't give any results if I do Help -> Search for
updates didn't give me the option to switch to 3.1.
TIA, H.
Hendrik Maryns
Interesting websites:
www.lieverleven.be (I cooperate)
www.eu04.com European Referendum Campaign
aouw.org The Art Of Urban Warfare
Re: java 1.5 compliance [message #57576 is a reply to message #57168] |
Tue, 26 April 2005 12:40 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Darin Swanson uitte de volgende tekst op 26/04/2005 0:06:
> Use the -data Eclipse option to point to your exsiting workspace.
> Note your workspace will be upgraded for use with 3.1...you will not then be
> able to go back and use this same workspace with 3.0.2
Thanks, but let me see if I get it right: I should download & install
3.1, then start it up from the command line with the option -data
$path-to-my-workspace?
Isn't there a clean and clear way, just some option to find inside my
current Eclipse? I guess no, ah well.
Cheers, H.
> "Hendrik Maryns" <hendrik_maryns@despammed.com> wrote in message
> news:d4jmqs$gt2$1@news.eclipse.org...
>>>support.
Hendrik Maryns
Re: java 1.5 compliance [message #57671 is a reply to message #57576] |
Tue, 26 April 2005 14:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: reply.group.com
Try, File--> Switch workspace.
news:d4ld15$gj0$1@news.eclipse.org...
>> be
> Thanks, but let me see if I get it right: I should download & install 3.1,
> Cheers, H.
>>>>support.
> Hendrik Maryns
FUDForum. Page generated in 0.08958 seconds
