Re: TPTP often hangs after first execution... [message #57067 is a reply to message #56869] |
Thu, 09 March 2006 18:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Randy D. Smith![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=randy.d.smith%40intel.com) Messages: 394 Registered: July 2009 |
I don't know about the guys over on the profiling side, but it's not a
"known bug" to me. I'd file a bugzilla, and document what you can about
the scenario. In particular, are you going IAC (local connection ) or
RAC (agent controller in separate process)? Simple case (like the
tutorial CarModel) or something more complex? Make sure to indicate
JVM... and make sure you put the "a" on the 3.2M5 so they don't
immediately assume pilot error! :-)
I'm over on the (new technology) AC side, so when I see such things (and
I've seen things like this during the M5 development cycle) I assume
it's my stuff... One workaround I've developed for such situations
that's a half step above "killing and restarting eclipse" is to have
another workspace with very little in it (so startup is simple, e.g.,
have it in Resource mode) and just "Switch Workspace..." on the File
menu... then switch back. That seems to set things so that I can delete
the old run and run again.
But, again, directly to your question... I've actually run the CarModel
profiling multiple times on that stable release without needing to
restart... so your bugzilla could be very helpful.
RDS
Michael Moser wrote:
> I observe, that very often profiling is unable to restart after
> completion or
> termination of a prior run. Is this a known effect/bug? Any workaround
> (other than killing and restarting eclipse...).
> This is on Eclipse 3.2M5 and TPTP-4.2.0-200602281515.
> Michael
FUDForum. Page generated in 0.04474 seconds
