Problems running Equinox on Sharp Zaurus [message #56782] |
Fri, 13 January 2006 16:08 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: neil.integility.com
I've been trying to get Equinox to run on a Sharp Zaurus (a Linux/ARM
based PDA). I'm using the Personal Profile JVM from Sun
(http://java.sun.com/developer/earlyAccess/pp4zaurus/) and when I try to
start the OSGi console I get:
bash-2.05$ /home/QtPalmtop/j2me/bin/cvm -jar org.eclipse.osgi_3.2.0.jar
-console
sun.misc.CVM.parseCommandLineOptions([Ljava/lang/String:Ljav a/lang/String:Z)|(Compiled
Method)(Unknown Source)
Cannot start VM (exception during sun.misc.CVM.parseCommandLineOptions())
Could not create JVM.
I'm not sure where to start looking to try to fix this, can anybody help?
Neil Bartlett
Re: Problems running Equinox on Sharp Zaurus [message #57841 is a reply to message #56782] |
Tue, 24 January 2006 04:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
Hmm, this looks like something from the VM since the NPE is happening in a
Sun class. The command line looks cool.
Jeff
"Neil Bartlett" <neil@integility.com> wrote in message
news:57ba63b241986a05b5d1fb09df70d3bc$1@www.eclipse.org...
> -console
> java.lang.NullPointerException
> at
|(Compiled
> Thanks
> Neil Bartlett
Re: Problems running Equinox on Sharp Zaurus [message #58011 is a reply to message #57841] |
Tue, 24 January 2006 15:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I agree, unfortunately the lack of line number information makes it hard
to find the cause...
It's not so relevant now since I have been able to get a full J2RE (from
Blackdown) running on the device, but it would have been nice to see
Equinox working under the J2ME stack.
- Neil
> Jeff
Re: Problems running Equinox on Sharp Zaurus [message #58239 is a reply to message #58011] |
Thu, 26 January 2006 14:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Interesting. Perhaps you could try a different VM? IBM's J9 VM is
available for the Zaurus SL-6000 (and perhaps others) at
http://www-306.ibm.com/software/wireless/weme/
I run large chunks of Eclipse on that VM (not on the Zaurus) quite
frequently.
Jeff
news:90353beab9ab64575f1fd76506923b82$1@www.eclipse.org...
> - Neil
a
> > Jeff
Re: Problems running Equinox on Sharp Zaurus [message #59681 is a reply to message #58239] |
Fri, 03 February 2006 11:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Jeff,
Thanks for the information. I had previously thought that J9 was for
PocketPC only.
As usual the IBM download site was staggeringly confusing, but once I
found the right download it worked perfectly! Equinox OSGi console running
on Sharp Zaurus C3100.
Thanks again. Now to speak to the SWT guys about a Qtopia port...
Neil
> frequently.
> Jeff
>> - Neil
> a
>> > Jeff
Re: Problems running Equinox on Sharp Zaurus [message #60891 is a reply to message #59681] |
Thu, 09 February 2006 16:48 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Great! If you have some cool apps or writeups or screenshots etc to show it
would be interesting to make this available. Even a "how you did it" or
"what you did" write up would be interesting to others I'm sure.
Jeff
news:65851ab8411b1af5072273e849c2bda1$1@www.eclipse.org...
> Jeff,
> PocketPC only.
> Regards
> Neil
> > frequently.
> > Jeff
hard
(from
> >> - Neil
in
> > a
> >> > Jeff
FUDForum. Page generated in 0.04404 seconds
