[ATL] Empty stack Exception [message #56752] |
Wed, 08 August 2007 18:52 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ivano![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ivanomalavolta%40yahoo.it) Messages: 35 Registered: July 2009 |
Member |
Hi, I have a problem launching an ATL transformation between two models.
This is the header and the first rule of the transformation (the other
rules are very similar: I have a rule for each element of DARWIN
metamodel):
-- @atlcompiler atl2006
module UML2Copy;
create OUT : A0 from IN : DARWIN;
rule DurationInterval {
from s : DARWIN!DurationInterval
to t : A0!DurationInterval (
name <- s.name,
visibility <- s.visibility,
eAnnotations <- s.eAnnotations,
ownedComment <- s.ownedComment,
clientDependency <- s.clientDependency,
nameExpression <- s.nameExpression,
templateParameter <- s.templateParameter,
type <- s.type,
min <- s.min,
max <- s.max)
A0 and DARWIN metamodels have a common section and I with these rules I
want to copy each element of the commmon section.
Executing the transformation I have the following exception, does someone
know why? If I isolate one rule tha transformation works!
****** BEGIN Stack Trace
exception:
java.util.EmptyStackException
at java.util.Stack.peek(Unknown Source)
at java.util.Stack.pop(Unknown Source)
at org.atl.engine.vm.ASMStackFrame.pop(ASMStackFrame.java:90)
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:30 0)
at org.atl.engine.vm.ASMOperation.exec(ASMOperation.java:155)
at org.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java: 60)
at org.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java: 50)
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:21 4)
at org.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:276)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:1 36)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:9 4)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:6 8)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:6 4)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:230)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:168)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:145)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:121)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .launch(AtlLaunchConfigurationDelegate.java:97)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:639)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:565)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:754)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:944)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
A.main() : ??#22 null
local variables = {self=UML2Copy : ASMModule}
local stack = []
A.__matcher__() : ??#107 null
local stack = []
A.__matchEAnnotation() : ??#0 null
local stack = []
****** END Stack Trace
Execution terminated due to error (see launch configuration to allow
continuation after errors).
Re: [ATL] Empty stack Exception [message #56807 is a reply to message #56752] |
Wed, 08 August 2007 19:23 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: quentin.glineur.obeo.fr
Hi Ivano,
You told that the transformation works when you isolate one rule. Then,
could you isolate and send a pair of rules that make the transformation
crash ?
Quentin GLINEUR.
> metamodel):
> module UML2Copy;
> from s : DARWIN!DurationInterval to t : A0!DurationInterval (
> name <- s.name,
> type <- s.type,
> min <- s.min,
> max <- s.max)
> someone know why? If I isolate one rule tha transformation works!
> exception: java.util.EmptyStackException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> local stack = []
> local stack = []
> local stack = []
FUDForum. Page generated in 0.03138 seconds
