| NLS in RAP applications [message #56742] |
Thu, 01 November 2007 07:02  |
Can I use the eclipse NLS components in RAP applications? Is it possible
that every session has its own NLS settings; ie. one user works in a
german session wheras another uses an english session.
Peter
| Re: NLS in RAP applications [message #58467 is a reply to message #58178] |
Wed, 07 November 2007 23:55  |
Originally posted by: eclipse-dev.volanakis.de
> to be the least invasive solution. From a technical point of view the
other
> way round meaning using RAP NLS in RCP applications is at least feasible.
Thanks for the info. Using the RAP-style-NLS in an RCP Application seems
like an acceptable compromise.
Kind regards,
Elias.
Frank Appel wrote:
> unfortunately the RCP solution doesn't work on the server-side, and it even
> doesn't work for all use-cases in RCP. Switching the language of an
> application that is already running for example doesn't work. So there is no
> chance to reuse NLS as it is currently used in RCP, and believe us we don't
> like this eighter. Moving the class variables to instance variables seemed
> to be the least invasive solution. From a technical point of view the other
> Ciao
> Frank
> "Elias Volanakis" <eclipse-dev@volanakis.de> schrieb im Newsbeitrag
> news:fgqnhr$rhn$1@build.eclipse.org...
>>> * if your NLS code in RCP looks like this:
>>> label.setText( MyMessages.Welcome_Text );
>>> your RAP code would look like this:
>>> label.setText( MyMessages.get().Welcome_Text );
>> Personally, I'm not too fond of this suggestion, because it introduces
>> different APIs between an RCP Application and the RAP counterpart, thus
>> making it less attractive -- but I don't see how to support multiple
>> languages per VM differently at this moment...
>> Maybe MyMessages.get().Welcome_Text could also work in the RCP App, so
>> that I could use the same "style" in both Apps?
>> Just wondering,
>> Elias.
FUDForum. Page generated in 0.22976 seconds
