Home » Archived » XML Schema Definition (XSD) » java.lang.NullPointerException when adding Element
java.lang.NullPointerException when adding Element [message #56707] |
Thu, 30 December 2004 10:09 |
Originally posted by: ooi.de.ibm.com
I have a problem when adding a element to a schema. A NullPointerException
occurs although the schema and the element exist.What could the problem
be?
here is the class i am experimenting with.
The error is in the addElements() method.
public class Example {
private XSDSchema schema;
private File outputFile;
private DocumentBuilderFactory docFactory;
private Document document;
private String parentClassName;
private ArrayList currentProperties;
private String root;
private String xsd;
private String muws;
public Example (String inputParentClassName,String inputPathName){
parentClassName = inputParentClassName;
schema = XSDFactory.eINSTANCE.createXSDSchema();
outputFile = new File(inputPathName + "//" + parentClassName+".xsd");
createDocument();
initializeSchema();
initializeNamespaces();
//addImports();
addElements();
save();
private void createDocument(){
docFactory = DocumentBuilderFactory.newInstance();
DocumentBuilder builder = null;
try {
builder = docFactory.newDocumentBuilder();
} catch (ParserConfigurationException e1) {
e1.printStackTrace();
document = (Document) builder.newDocument();
private void initializeSchema(){
Element schemaElement = (Element)
document.createElementNS(XSDUtil.SCHEMA_FOR_SCHEMA_URI_2001, "schema");
schema.setElement(schemaElement);
document.appendChild(schemaElement);
private void initializeNamespaces(){
schema.setTargetNamespace("http://dmtf.org/v2.8/"+parentClassName+".xsd");
java.util.Map qNamePrefixToNamespaceMap =
schema.getQNamePrefixToNamespaceMap();
root = "http://dmtf.org/v2.8/";
qNamePrefixToNamespaceMap.put("cim-root",root);
xsd= "http://www.w3.org/2001/XMLSchema";
qNamePrefixToNamespaceMap.put("xsd",xsd);
muws = "http://docs.oasis-open.org/wsdm/2004/XX/muws/schema";
qNamePrefixToNamespaceMap.put("muws",muws);
String currentParentXSDnamespace = "http://dmtf.org/v2.8/"+
parentClassName+".xsd";
qNamePrefixToNamespaceMap.put(parentClassName+"-xsd",currentParentXSDnamespace);
schema.update();
private void addImports(){
XSDImport muwsImport = XSDFactory.eINSTANCE.createXSDImport();
muwsImport.setNamespace(muws);
muwsImport.setSchemaLocation("\\import\\MUWS.xsd");
schema.getContents().add(muwsImport);
XSDImport rootImport = XSDFactory.eINSTANCE.createXSDImport();
rootImport.setNamespace(root);
rootImport.setSchemaLocation("\\import\\CIM_root.xsd");
schema.getContents().add(rootImport);
private void addElements(){
XSDElementDeclarationImpl element =(XSDElementDeclarationImpl)
XSDFactory.eINSTANCE.createXSDElementDeclaration();
element.setName("anElement");
schema.getContents().add(element);
Example example1 = new Example("Example","C:\\Documents and
Settings\\Administrator\\Desktop");
private void save(){
try {
Source source = new DOMSource(document);
Result result = new StreamResult(outputFile);
Transformer xformer = TransformerFactory.newInstance().newTransformer();
xformer.transform(source,result);
} catch (TransformerConfigurationException e) {
e.printStackTrace();
} catch (TransformerFactoryConfigurationError e) {
} catch (TransformerException e) {
thank you very much.
Re: java.lang.NullPointerException when adding Element [message #56762 is a reply to message #56707] |
Thu, 30 December 2004 13:26 |
--------------090207060905060305060804
HT,
You need to make these match:
*"schema"*);
qNamePrefixToNamespaceMap.put(*"xsd"*,xsd);
schema.update();
I.e., you either need to use "xsd:schema" to create the element with a
prefix that matches the prefix you've defined or you need to use
put(null, xsd) to define the prefix according to the QName that will use it.
Is there some particularly compelling reason why you keep trying to
create the element manually? Doing schema.setDocument(document) will
avoid the mistakes you are making creating the element manually.
HT Ooi wrote:
> NullPointerException occurs although the schema and the element
> exist.What could the problem be?
> private String xsd;
> createDocument();
> initializeSchema();
> //addImports();
> addElements();
> save();
> try {
> schema.update();
> public static void main(String[] args) {
> try {
<html>
<head>
http-equiv="Content-Type">
</head>
HT,<br>
<br>
You need to make these match:<br>
<blockquote><small>
Re: java.lang.NullPointerException when adding Element [message #56789 is a reply to message #56762] |
Thu, 30 December 2004 15:32 |
Hi Ed,
I used your suggestion,now using
schema.setDocument(document);
instead of:
i still got an exception at the same place. What would you advise?
Thank you again.
Ed Merks wrote:
> HT,
> *"schema"*);
> schema.update();
> HT Ooi wrote:
>> private String xsd;
>> createDocument();
>> initializeSchema();
>> //addImports();
>> addElements();
>> save();
>> try {
>> schema.update();
>> muwsImport.setSchemaLocation("\import\MUWS.xsd");
>> rootImport.setSchemaLocation("\import\CIM_root.xsd");
>> Example example1 = new Example("Example","C:\Documents and
>> Settings\Administrator\Desktop");
>> try {
Re: java.lang.NullPointerException when adding Element [message #56817 is a reply to message #56762] |
Thu, 30 December 2004 15:48 |
Hi Ed,
instead of:
Thank you again.
Ed Merks wrote:
> HT,
> *"schema"*);
> schema.update();
> HT Ooi wrote:
>> private String xsd;
>> createDocument();
>> initializeSchema();
>> //addImports();
>> addElements();
>> save();
>> try {
>> schema.update();
>> try {
Re: java.lang.NullPointerException when adding Element [message #56843 is a reply to message #56789] |
Thu, 30 December 2004 16:11 |
--------------040600070305030002050200
HT,
Did you do this as we established in previous notes was necessary:
(xsdSchema.getSchemaForSchemaQNamePrefix(),
XSDConstants.SCHEMA_FOR_SCHEMA_URI_2001);
You probably just left the explicit "xsd" and never made sure that
xsdSchema.setSchemaForSchemaQNamePrefix("xsd") was called. (I changed
it to null to match "schema" as I explained.) All these different
things you are trying and having problems with are all variations on the
same theme: choosing a prefix, defining an xmlns declaration to bind
that prefix to the right schema for schema namespace, and using that
prefix consistently.
Your next problem you have will be that you are bypassing this code in
XSDResourceImpl.doSave when you are saving the Document directly, so you
need to ensure that the element is demand created using updateElement if
necessary.
protected void doSave(OutputStream os, Map options) throws IOException
XSDSchema xsdSchema = getSchema();
if (xsdSchema != null)
* Document document = xsdSchema.getDocument();
if (document == null)
xsdSchema.updateDocument();
if (xsdSchema.getElement() == null)
xsdSchema.updateElement(); <<<<<
doSerialize(os, document, options == null ? null :
(String)options.get(XSD_ENCODING));
HT Ooi wrote:
> Hi Ed,
> instead of:
> Thank you again.
> Ed Merks wrote:
>> HT,
>> *"schema"*);
>> schema.update();
>> a prefix that matches the prefix you've defined or you need to use
>> use it.
>> HT Ooi wrote:
>>> Hi,
>>> private String xsd;
>>> inputPathName){
>>> createDocument();
>>> initializeSchema();
>>> //addImports();
>>> addElements();
>>> save();
>>> try {
>>> document = (Document) builder.newDocument(); }
>>> schema.update();
>>> try {
<html>
<head>
</head>
HT,<br>
<br>
Did you do this as we established in previous notes was necessary:<br>
<blockquote>qNamePrefixToNamespaceMap.put<br>
Re: java.lang.NullPointerException when adding Element [message #593424 is a reply to message #56707] |
Ed Merks Messages: 33185 Registered: July 2009 |
HT,
*"schema"*);
schema.update();
HT Ooi wrote:
> private String xsd;
> createDocument();
> initializeSchema();
> //addImports();
> addElements();
> save();
> try {
> schema.update();
> try {
<html>
<head>
</head>
HT,<br>
<br>
<blockquote><small>
Ed Merks
Re: java.lang.NullPointerException when adding Element [message #593439 is a reply to message #56762] |
Hi Ed,
instead of:
Thank you again.
Ed Merks wrote:
> HT,
> *"schema"*);
> schema.update();
> HT Ooi wrote:
>> private String xsd;
>> createDocument();
>> initializeSchema();
>> //addImports();
>> addElements();
>> save();
>> try {
>> schema.update();
>> try {
Re: java.lang.NullPointerException when adding Element [message #593455 is a reply to message #56762] |
Hi Ed,
instead of:
Thank you again.
Ed Merks wrote:
> HT,
> *"schema"*);
> schema.update();
> HT Ooi wrote:
>> private String xsd;
>> createDocument();
>> initializeSchema();
>> //addImports();
>> addElements();
>> save();
>> try {
>> schema.update();
>> try {
Re: java.lang.NullPointerException when adding Element [message #593467 is a reply to message #56789] |
HT,
necessary.
HT Ooi wrote:
> Hi Ed,
> instead of:
> Thank you again.
> Ed Merks wrote:
>> HT,
>> *"schema"*);
>> schema.update();
>> use it.
>> HT Ooi wrote:
>>> Hi,
>>> private String xsd;
>>> inputPathName){
>>> createDocument();
>>> initializeSchema();
>>> //addImports();
>>> addElements();
>>> save();
>>> try {
>>> schema.update();
>>> try {
<html>
<head>
</head>
HT,<br>
<br>
Ed Merks
Current Time: Fri Jul 19 10:15:59 GMT 2024
Powered by FUDForum. Page generated in 0.05337 seconds
