Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP on eclipse 3.2M5?
Re: TPTP on eclipse 3.2M5? [message #56733 is a reply to message #56706] |
Thu, 09 March 2006 00:25   |
You've done a really good job of documenting your Eclipse version
(3.2M5), EMF/XSD/SDO versions (2.1.0, 2.1.2, and 2.2.0M5), and even your
JVMs (okay, I'm tired of duplicating your extensive efforts... I'm sure
you are too!).
But you missed a key piece of information... what version of TPTP are
you using??!?
My recollection (and unfortunately it's been hectic shifting to i2 work
on 4.2 once i1 was over) is that THE version for 4.2i1 is ... (checks
web page) TPTP-4.2.0-200602281515 (the latest "stable build ... go to
TPTP downloads, and click the 4.2.0 download tab).
At the bottom of that download page are the Requirements:
3.2M5a (<== NOTE THE ****a****)
2.2.0M5 EMF/XSD/SDO
etc.
I seem to recall that the 3.2M5a was specifically introduced to fix the
problems you saw with the 3.2M5/2.2.0M5/4.2.0[M5?... wonder why the page
doesn't call it that... I think that is what it is!] combination.
I'm sorry for the troubles you're running into. 4.2 is "in development",
and yes, there has been an effort to get everything on the same
(Callisto) "train" with the M5 effort. You were close... just not quite
there.
RDS
Michael Moser wrote:
> I was trying to run TPTP on eclipse 3.2M5 but I seem to get caught in a
> version frenzy. While the installation of TPTP and agent controller, the
> agent controller's configuration, the setting of the profiling
> preferences and the specification of a profiling set all worked fine,
> the actual execution& profiling always fails.
> Since some error messages (depending on the VM used) indicated some
> EMF/SDO/XSD error (java.lang.NoSuchMethodError:
> org.eclipse.emf.ecore.EPackage$Registry.getEFactory(Ljava/la ng/String;)Lorg/eclipse/emf/ecore/EFactory;)
> I tried with 3 different versions (2.1.0, 2.1.2, 2.2.0M5), but none
> worked. I also tried using different VMs (IBM JSDK1.4.2, Sun VM 1.4.2
> and Sun VM 1.5.0)
> With Sun J2SDK 1.4.2 the error I get is:
> !ENTRY org.eclipse.core.jobs 4 2 2006-03-08 22:25:09.226
> !MESSAGE An internal error occurred during: "Launching".
> !STACK 0
> java.lang.NoClassDefFoundError
> at
> org.eclipse.hyades.models.hierarchy.impl.HierarchyPackageImp l. <init>(HierarchyPackageImpl.java:263)
> at
> org.eclipse.hyades.models.hierarchy.impl.HierarchyPackageImp l.init(HierarchyPackageImpl.java:304)
> at
> org.eclipse.hyades.trace.internal.ui.TraceUIManager.getResou rceSet(TraceUIManager.java:193)
> at org.eclipse.hyades.trace.ui.UIPlugin.getResourceSet(UIPlugin .java:252)
> at
> org.eclipse.hyades.trace.ui.internal.util.PDCoreUtil.createM onitor(PDCoreUtil.java:389)
> at
> org.eclipse.hyades.trace.ui.internal.util.PDCoreUtil.launchT race(PDCoreUtil.java:662)
> at
> org.eclipse.hyades.trace.ui.internal.launcher.ProfileJavaApp licationDelegate.launch(ProfileJavaApplicationDelegate.java: 83)
> at
> org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:639)
> at
> org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:565)
> at
> org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:753)
> at
> org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:943)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
> With the IBM 1.4.2 JSDK and Sun's Java 5 VM the error is:
> !ENTRY org.eclipse.osgi 4 0 2006-03-08 22:27:59.986
> !MESSAGE An error occurred while automatically activating bundle
> org.eclipse.hyades.statistical.ui (380).
> !STACK 0
> org.osgi.framework.BundleException: The activator
> org.eclipse.hyades.statistical.ui.UiPlugin for bundle
> org.eclipse.hyades.statistical.ui is invalid
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:965)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:314)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:83)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:402)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:186)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:338)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:390)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:351)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:81)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:276)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:138)
> at
> org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
> at
> org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
> at
> org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
> at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:241)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:51)
> at
> org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:237)
> at
> org.eclipse.ui.internal.EarlyStartupRunnable.getExecutableEx tension(EarlyStartupRunnable.java:115)
> at
> org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartu pRunnable.java:66)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at org.eclipse.core.runtime.Platform.run(Platform.java:816)
> at org.eclipse.ui.internal.Workbench$20.run(Workbench.java:1745 )
> Caused by: java.lang.NoSuchMethodError:
> at
> org.eclipse.hyades.models.hierarchy.impl.HierarchyFactoryImp l.init(HierarchyFactoryImpl.java:65)
> at
> org.eclipse.hyades.models.hierarchy.HierarchyFactory.<clinit >(HierarchyFactory.java:38)
> at
> at
> at
> org.eclipse.hyades.models.hierarchy.HierarchyPackage.<clinit >(HierarchyPackage.java:78)
> at sun.misc.Unsafe.ensureClassInitialized(Native Method)
> at
> sun.reflect.UnsafeFieldAccessorFactory.newFieldAccessor(Unsa feFieldAccessorFactory.java:25)
> at
> sun.reflect.ReflectionFactory.newFieldAccessor(ReflectionFac tory.java:122)
> at java.lang.reflect.Field.acquireFieldAccessor(Field.java:917)
> at java.lang.reflect.Field.getFieldAccessor(Field.java:898)
> at java.lang.reflect.Field.get(Field.java:357)
> at
> org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(RegistryReader.java:167)
> at
> org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegistryImpl.java:107)
> at
> org.eclipse.hyades.models.hierarchy.impl.HierarchyPackageImp l.init(HierarchyPackageImpl.java:302)
> at
> org.eclipse.hyades.model.statistical.impl.StatisticalPackage Impl.init(StatisticalPackageImpl.java:222)
> at org.eclipse.hyades.statistical.ui.UiPlugin.<init>(UiPlugin.java:97)
> at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
> at
> sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
> at
> sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
> at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
> at java.lang.Class.newInstance0(Class.java:350)
> at java.lang.Class.newInstance(Class.java:303)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:136)
> ... 27 more
> Is there a combination of TPTP, EMF&SDO&XSD & VMs that works with
> eclipse 3.2M5? Or do I also have to install yet another eclipse version
> to do my profiling?
> Michael
Re: TPTP on eclipse 3.2M5? [message #56760 is a reply to message #56733] |
Thu, 09 March 2006 00:40   |
Ahhh, found it... The main project page for TPTP (<
http://www.eclipse.org/tptp/index.html >) has, under "What's New", "TPTP
4.2 i1/M5 stable build available", and the accompanying "download" link
there takes you right to that 02281515 download page.
RDS
> you are too!).
> you using??!?
> 2.2.0M5 EMF/XSD/SDO
> etc.
> there.
> RDS
>> a version frenzy. While the installation of TPTP and agent controller,
>> the agent controller's configuration, the setting of the profiling
>> and Sun VM 1.5.0)
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 27 more
>> version to do my profiling?
>> Michael
Re: TPTP on eclipse 3.2M5? [message #56814 is a reply to message #56760] |
Thu, 09 March 2006 03:38  |
Thanks, I had been using this version already. Shortly peeking into the
plugins directory I found it to contain a wild collection of jar files
with mixed 4.1.1 and 4.2.0 version suffixes. But the date is always
200602281515, so I guess that's ok.
Michael
"Randy D. Smith" <randy.d.smith@intel.com> wrote in message
news:duof42$j60$1@utils.eclipse.org...
> "TPTP 4.2 i1/M5 stable build available", and the accompanying
> "download" link there takes you right to that 02281515 download page.
> RDS
>> your JVMs (okay, I'm tired of duplicating your extensive efforts...
>> I'm sure you are too!).
>> you using??!?
>> work on 4.2 once i1 was over) is that THE version for 4.2i1 is ...
>> (checks web page) TPTP-4.2.0-200602281515 (the latest "stable build
>> ... go to TPTP downloads, and click the 4.2.0 download tab).
>> 2.2.0M5 EMF/XSD/SDO
>> etc.
>> the problems you saw with the 3.2M5/2.2.0M5/4.2.0[M5?... wonder why
>> the page doesn't call it that... I think that is what it is!]
>> combination.
>> development", and yes, there has been an effort to get everything on
>> the same (Callisto) "train" with the M5 effort. You were close...
>> just not quite there.
>> RDS
>>> in a version frenzy. While the installation of TPTP and agent
>>> controller, the agent controller's configuration, the setting of the
>>> profiling preferences and the specification of a profiling set all
>>> worked fine, the actual execution& profiling always fails.
>>> 1.4.2 and Sun VM 1.5.0)
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Method)
>>> at
>>> at
>>> at
>>> ... 27 more
>>> Michael
Current Time: Tue Apr 22 17:39:23 EDT 2025
Powered by FUDForum. Page generated in 0.03695 seconds
