VE 1.0M2 and Import Existing Project [message #56658] |
Sat, 21 August 2004 11:48 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: Jeffrey_Mason.MSN.com
If I import an existing project that was created with Eclipse and VE, VE
doesn't activate.
Is there something I missing to activate VE for a visual class within this
existing project?
BoomerangThree
Re: VE 1.0M2 and Import Existing Project [message #56685 is a reply to message #56658] |
Sat, 21 August 2004 11:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
"BoomerangThree" <Jeffrey_Mason@MSN.com> wrote in message
news:cg7cln$vfu$1@eclipse.org...
> doesn't activate.
> existing project?
Solved my own problem with some additional research in the group...
Whenever you'd rather open a class with the Java editor rather than the
Visual Editor, select the class in the package explorer, right click on
it and choose Open With->Java Editor. The association of that file will
change to always open with the Java Editor, until you choose to Open
With->Visual Editor later on.
Re: VE 1.0M2 and Import Existing Project [message #597508 is a reply to message #56658] |
> doesn't activate.
> existing project?
FUDForum. Page generated in 0.03063 seconds
