Home » Eclipse Projects » DTP » Informix - error "Method can be called only once."
Informix - error "Method can be called only once." [message #56613] Mon, 25 May 2009 09:39 Go to next message
Denis Kranjcec is currently offline Denis KranjcecFriend
Hi!
I have the same problem as described in post:
http://dev.eclipse.org/newslists/news.eclipse.dtp/msg01419.h tml
Everything works fine in Data Source Explorer, but all queries in SQL
Scrapbook throws "Method can be called only once." until terminated.
I'm using:
eclipse.buildId=M20090211-1700
org.eclipse.datatools.common.doc.user
(1.6.2.v200810071455-1507w31191939244824) "Data Tools Platform Tutorial
Documentation"
org.eclipse.datatools.connectivity.doc.user
(1.6.2.v200810071455-27A18s733I3I7I599G59) "Data Tools Platform
Connectivity Documentation"
org.eclipse.datatools.connectivity.feature
(1.6.2.v200810071455-7_7K7NDn-QYKjkBKlmD4edYsAX) "Data Tools Platform
Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature
(1.6.2.v200901211403-7C67XCYQCD7ESIqIQco) "DTP ODA Designer UI Framework
Plug-in"
org.eclipse.datatools.connectivity.oda.feature
(1.6.2.v200810071455-7F27SBcMAAxCcHmCNWi) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.6.2.v200810071455-37A09oA55S6H_L8DFG24)
"Data Tools Platform User Documentation"
org.eclipse.datatools.enablement.apache.derby.feature
(1.6.2.v200810071455-6577AlJCKcLZI2Ljcc8MDD) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.enablement.feature
(1.6.2.v200810071455-7D8H7P9FT9Ofz-RuiDlMiw8OR2pj) "Eclipse Data Tools
Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature
(1.6.2.v200810071455-57_2_pFAIQJZIsLSXb8MDD) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.ibm.feature
(1.6.2.v200810071455-7D47FEB7sQSBV7hXWQ6R) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.jdbc.feature
(1.6.2.v200810071455-3-29oA55S7__D7LCC) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.enablement.msft.feature
(1.6.1.v200809191145-442_kE77c7VBQDFNW) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.mysql.feature
(1.6.2.v200810071455-446_kE77d8H_VALOJ) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.oda.designer.feature
(1.6.1.v200809191145-2118s733I3I6C4_6C) "Eclipse Data Tools Platform XML
ODA Designer"
org.eclipse.datatools.enablement.oda.feature
(1.6.2.v200810071455-797P78CYQCD5DjGdEURT) "Eclipse Data Tools Platform
XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature
(1.6.2.v200810071455-443_kE77d7OAPAMJQ) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.postgresql.feature
(1.6.2.v200810071455-442_kE77d7N9VANON) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.sap.feature
(1.6.2.v200810071455-440_kE77c7QAQEIQQ) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.sybase.feature
(1.6.2.v200810071455-7A-5E9IgKLjM1d1Oepu) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.intro (1.6.2.v200810071455-1507w311918132411)
"Eclipse Data Tools Platform Intro Plug-in"
org.eclipse.datatools.modelbase.feature
(1.6.2.v200810071455-6-2BcMAAyBWDkEVSb) "Eclipse Data Tools Platform
SQLModel Plug-in"
org.eclipse.datatools.sdk.feature
(1.6.2.v200810071455-67S779KdRRFAuQFpKZ2z-0mp49Vx) "DTP Connectivity
Templates Plug-in"
org.eclipse.datatools.sdk.feature.source (1.6.2.v200810071455) "Eclipse
Datatools Source"
org.eclipse.datatools.sqldevtools.feature
(1.6.2.v200810071455-7F7d7AE8yz-YIwEvOFuOF3SqVz-z) "Eclipse Data Tools
Platform SQL Tools Common UI Plug-in"
org.eclipse.datatools.sqltools.doc.user
(1.6.2.v200810071455-1507w31191939244824) "Data Tools Platform SQL Dev
Tools Documentation"
When query is terminated correct results are shown in "Result 1" tab.
Status tab is filled with "Method can be called only once." messages.
Informix version is 11.10
What is wrong with my setup?
I can provide more information if needed.
Denis Kranjcec
Re: Informix - error "Method can be called only once." [message #56641 is a reply to message #56613] Mon, 25 May 2009 10:46 Go to previous message
Upgrading JDBC driver from version 2.21.0 to version 3.10.0 solved this
problem.
Regrads,
Denis Kranjcec
Re: Informix - error "Method can be called only once." [message #595844 is a reply to message #56613] Mon, 25 May 2009 10:46 Go to previous message
problem.
Regrads,
Denis Kranjcec
Previous Topic:Informix - error "Method can be called only once."
Next Topic:db4o database in the Data Tools Platfom
Current Time: Sun Dec 22 06:07:12 GMT 2024
Powered by FUDForum. Page generated in 0.03073 seconds
