Home » Archived » Visual Editor (VE) » VE will not start properly with N20040819 and 1.0M2
VE will not start properly with N20040819 and 1.0M2 [message #56604] Sat, 21 August 2004 11:45 Go to next message
Originally posted by: Jeffrey_Mason.MSN.com
When I attempt to open an existing project that was constructed with VE I
get the following error:
Launch mode run not supported for configuration type
org.eclipse.jem.proxy.LocalProxyLaunchConfigurationType
org.eclipse.core.runtime.CoreException: Launch mode run not supported for
configuration type org.eclipse.jem.proxy.LocalProxyLaunchConfigurationType
org.eclipse.debug.internal.core.LaunchConfigurationType.getD elegate(LaunchConfigurationType.java:221)
org.eclipse.debug.internal.core.LaunchConfiguration.getDeleg ate(LaunchConfiguration.java:360)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:514)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:150)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:481)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:292)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:224)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorVMController$CreateRegistry.run(JavaVisualEditorVMContro ller.java:164)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
It seems to be erratic. Anyone have any ideas?
BoomerangThree
Re: VE will not start properly with N20040819 and 1.0M2 [message #56984 is a reply to message #56604] Mon, 23 August 2004 19:55 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Please tell me build driver ids of Eclipse, GEF, EMF, and VE your are using.
Thanks, Rich Kulp
Re: VE will not start properly with N20040819 and 1.0M2 [message #57113 is a reply to message #56984] Mon, 23 August 2004 22:24 Go to previous messageGo to next message
Originally posted by: JMM.Hotmail.com
Thanks for the reply Rich.
From Help / About:
Graphical Editing Framework = 3.0.0
Java EMF Model = 1.0.0
Workbench = 3.0.0
Visual Editor = 1.0.0
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:cgdhtm$euu$1@eclipse.org...
> using.
> Thanks, Rich Kulp
Re: VE will not start properly with N20040819 and 1.0M2 [message #57241 is a reply to message #57113] Tue, 24 August 2004 15:47 Go to previous message
For VE is 1.0M2 or is it another driver? For Eclipse, GEF, and EMF (NOT
Java EMF, but EMF), are they the released versions or some integration
driver?
Thanks, Rich Kulp
Re: VE will not start properly with N20040819 and 1.0M2 [message #597613 is a reply to message #56604] Mon, 23 August 2004 19:55 Go to previous message
Thanks, Rich Kulp
Re: VE will not start properly with N20040819 and 1.0M2 [message #597647 is a reply to message #56984] Mon, 23 August 2004 22:24 Go to previous message
From Help / About:
Workbench = 3.0.0
> using.
> Thanks, Rich Kulp
Re: VE will not start properly with N20040819 and 1.0M2 [message #597692 is a reply to message #57113] Tue, 24 August 2004 15:47 Go to previous message
driver?
Thanks, Rich Kulp
Previous Topic:Using VE for RCP ViewParts?
Next Topic:Using VE for RCP ViewParts?
Current Time: Thu Aug 29 13:00:26 GMT 2024
Powered by FUDForum. Page generated in 0.03658 seconds
