Home » Modeling » M2T (model-to-text transformation) » [JET2] Iterating through the elements of an EList in an EMF model
[JET2] Iterating through the elements of an EList in an EMF model [message #56561] Thu, 29 January 2009 06:14 Go to next message
I've got an EClass with a method "EList<State> getValidStates()".
State is defined as "public enum State implements Enumerator".
I would like to iterate on the State contained in the EList in the JET
templates.
I tried this:
<c:iterate select="$element/validStates" var="validState">
<c:get select="$validState" />
</c:iterate>
but it doesn't work.
Is it possible to do what I'm trying to do?
Thanks in advance.
Re: [JET2] Iterating through the elements of an EList in an EMF model [message #56669 is a reply to message #56561] Thu, 29 January 2009 09:56 Go to previous messageGo to next message
Youmm:
JET's XPath engine uses EMFs reflective APIs. It only sees
EStructuralFeature implementations (EReferences and EAttributes). I
currently does not do reflection on the actual Java class for methods that
are not declared in the ECore model.
Is there an EReference or an EAttribute declaration of validSates ?
Paul
"Youmm P." <kototamo@gmail.com> wrote in message
news:gls2rt$mua$1@build.eclipse.org...
> Hello,
> templates.
> I tried this:
> </c:iterate>
> Thanks in advance.
Re: [JET2] Iterating through the elements of an EList in an EMF model [message #56696 is a reply to message #56669] Thu, 29 January 2009 10:28 Go to previous messageGo to next message
No, the EList values are dynamically created by the getValidStates function.
Re: [JET2] Iterating through the elements of an EList in an EMF model [message #56722 is a reply to message #56696] Fri, 30 January 2009 09:16 Go to previous message
Youmm:
I think your best choice is to drop into Java code...
a) Make sure your JET project has a dependency on the plug-in defining the
Ecore model. (Open plugin.xml or META-INF/MANIFEST.MF, and go to the
Dependencies tab)
b) Add imports for the classes your template was to access
<%-- import the classes you'll need --%>
<%@jet import="a.b.c.YourElement a.b.c.State" %>
<%@jet import="org.eclipse.jet.XPathContextExtender" %>
c) get the JET variable as a Java variable. Assuming $element is the JET
variable containing EObject:
YourElement element =
(YourElement)XPathContext.getInstance(context).resolveAsObje ct(null, "$element");
d) Write the Java scriptlet
<% for(State state : element.getValidStates() ) { %>
.... template content <%= state.toString %>
Paul
news:glshpg$vqi$1@build.eclipse.org...
> function.
Previous Topic:Re: JET1 Editor for EMF Codegen template extensions
Next Topic:JET2 merging of model data with existing Java code
Current Time: Fri Nov 07 20:29:45 EST 2025
Powered by FUDForum. Page generated in 0.03913 seconds
