| CDO and ConcurrentModificationException [message #56509] |
Wed, 04 October 2006 11:28  |
Originally posted by: yannick.lizzi.silogic.fr
Hi all,
I get a ConcurrentModificationException when saving a resource after
getting and modifing its content, and I don't understand why...
I reproduced the error by modifying the CDO example project:
In project cdo.examples.ui -->
cdo.examples.ui.internal.actions.LoadResourceAction, I modify as follow:
private void loadResource() throws Exception {
.... // create resource manager
.... // load content of resource1
// Populate the model from the second resource.
System.out.println("--> TEST: Populate the model from the second resource");
Library library2 = (Library)resource2.getContents().get(0);
Book book = (Book)library2.getBooks().get(0);
book.setTitle("hello"); // my modif: try to update the book title
resourceManager.commit(); // commit modification
resourceManager.stop();
Once the library resources have been created, I invoke the Load library
resources to run my updates and the error happens when commit is invoked.
I get the same error if I update the book title after recreating a new
resource manager with a new resource set (just after the
resourceManager.stop()).
First, I would like to understand why ;), and also what are the
differences between this way of modifying the model and the way showed
in the example (that is via the cdo editor).
Yannick
| Re: CDO and ConcurrentModificationException [message #56565 is a reply to message #56509] |
Wed, 04 October 2006 13:53  |
Originally posted by: stepper.sympedia.de
Yannick,
It's simply a bug. I've fixed it and tomorrows maintenance build will
have the correction.
If you want to read about the cause refer to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=159765
Cheers
/Eike
Yannick Lizzi schrieb:
> Hi all,
> resource");
> library resources to run my updates and the error happens when commit
> is invoked.
> Thanks
> Yannick
| Re: CDO and ConcurrentModificationException [message #593663 is a reply to message #56509] |
Yannick,
Cheers
/Eike
> Hi all,
> resource");
> is invoked.
> Thanks
> Yannick
FUDForum. Page generated in 0.06691 seconds
