Home » Archived » M2M (model-to-model transformation) » ATL2 / Eclipse 3.3 - Launch file on Linux looses the transformation file
ATL2 / Eclipse 3.3 - Launch file on Linux looses the transformation file [message #56480] Tue, 07 August 2007 05:23 Go to next message
--------------040403010506050405040904
A transformation launched on Linux looses the transformation file in the
next uses of the configuration, and we must do non trivial gymnastic to
retrieve a functional launch configuration :
- change the project to another
- come back to the ATL project
- select the transfo file
- click on the "Revert" button as we have loose the (meta)models
- then we can launch the transfo ... Pfffuiii....
I join the launch file (which contains the transformation file path!!!).
Cordialement
Vincent MAH
Re: ATL2 / Eclipse 3.3 - Launch file on Linux looses the transformation file [message #56562 is a reply to message #56480] Tue, 07 August 2007 09:21 Go to previous message
Originally posted by: mikael.barbero.gmail.com
Hi Vincent,
Can you please open a bug on the bugzilla ? It is the best way to
discuss about these kinds of issues.
Mikael
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Previous Topic:Lazy Rule Error
Next Topic:[ATL] ACG documentation available on the Wiki
Current Time: Wed Apr 16 13:27:52 EDT 2025
Powered by FUDForum. Page generated in 0.02821 seconds
