ClassCastException 'Compartment Mapping' [message #56453] |
Wed, 27 September 2006 18:27 |
Originally posted by: markus.musil.chello.at
Hi GMF-Community,
I need some help. I tried to make a compartment where I can put a
customized figure in.
I thought I've done everything right, but if I try to generate the
genmodel I'm getting the following error message:
java.lang.ClassCastException: org.eclipse.gmf.gmfgraph.impl.NodeImpl
org.eclipse.gmf.mappings.impl.CompartmentMappingImpl.getComp artment(CompartmentMappingImpl.java:88)
org.eclipse.gmf.mappings.impl.CompartmentMappingImpl.eGet(Co mpartmentMappingImpl.java:193)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:594)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:586)
org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.hasNext(EContentsEList.java:416)
org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryPr oxyResolves(EObjectValidator.java:328)
org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryDe faultConstraint(EObjectValidator.java:183)
org.eclipse.emf.ecore.util.EObjectValidator.validate(EObject Validator.java:168)
org.eclipse.gmf.internal.validate.ValidatorChain.validate(Va lidatorChain.java:70)
org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:127)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:107)
org.eclipse.emf.ecore.util.Diagnostician.doValidateContents( Diagnostician.java:146)
org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:130)
org.eclipse.emf.ecore.util.Diagnostician.doValidateContents( Diagnostician.java:142)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:87)
org.eclipse.gmf.internal.codegen.popup.actions.TransformToGe nModel.validate(TransformToGenModel.java:305)
org.eclipse.gmf.internal.codegen.popup.actions.TransformToGe nModel.run(TransformToGenModel.java:105)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1496)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1520)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1505)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 279)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3312)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2941)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
eclipse.buildId=M20060629-1905
java.version=1.5.0_06
java.vendor=Apple Computer, Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=de_DE
Framework arguments: -keyring /Users/guidmo/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws carbon -keyring
/Users/guidmo/.eclipse_keyring -consoleLog -showlocation
Thanks and Regards
Markus
Re: ClassCastException 'Compartment Mapping' [message #56511 is a reply to message #56453] |
Wed, 27 September 2006 18:46 |
Originally posted by: markus.musil.codeworkz.at
--------------000903090507060209010805
Markus Musil schrieb:
> Hi GMF-Community,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks and Regards
> Markus
sorry something went wrong during adding the files
thx
Content-Type: text/xml; x-mac-type="0"; x-mac-creator="0";
name="modelworkz.gmftool"
Content-Disposition: inline;
filename="modelworkz.gmftool"
<gmftool:ToolRegistry xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:gmftool="http://www.eclipse.org/gmf/2005/ToolDefinition">
<palette>
<tools
xsi:type="gmftool:ToolGroup"
title="Modelworkz">
<tools
xsi:type="gmftool:CreationTool"
title="Entity"
description="Create new Entity">
<smallIcon
xsi:type="gmftool:DefaultImage"/>
<largeIcon
</tools>
<tools
title="Attribute"
description="Create new Attribute">
<smallIcon
<largeIcon
</tools>
<tools
title="EntityRelationship"
description="Create new EntityRelationship">
<smallIcon
<largeIcon
</tools>
<tools
title="TableLink"
description="Create new TableLink">
<smallIcon
<largeIcon
</tools>
</tools>
</palette>
</gmftool:ToolRegistry>
name="modelworkz.gmfmap"
filename="modelworkz.gmfmap"
<gmfmap:Mapping xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:gmfmap="http://www.eclipse.org/gmf/2005/mappings"
<nodes>
<containmentFeature
href="modelworkz.ecore#//Map/entities"/>
<ownedChild>
<domainMetaElement
href="modelworkz.ecore#//Entity"/>
<labelMappings>
<diagramLabel
href="modelworkz.gmfgraph#EntityName"/>
<features
href="modelworkz.ecore#//NamedElement/name"/>
</labelMappings>
<tool
href="modelworkz.gmftool#//@palette/@tools.0/@tools.0"/>
<diagramNode
href="modelworkz.gmfgraph#Entity"/>
<children
compartment="//@nodes.0/@ownedChild/@compartments.0"
referencedChild="//@nodes.0/@ownedChild/@children.0/@ownedChild ">
<containmentFeature
href="modelworkz.ecore#//Entity/attributes"/>
<childrenFeature
<ownedChild>
<domainMetaElement
href="modelworkz.ecore#//Attribute"/>
<labelMappings
viewPattern="{0}::{1}"
editPattern="{0}:{1}">
<diagramLabel
href="modelworkz.gmfgraph#AttributeName"/>
<features
<features
href="modelworkz.ecore#//TypedElement/type"/>
</labelMappings>
<tool
href="modelworkz.gmftool#//@palette/@tools.0/@tools.1"/>
<diagramNode
</ownedChild>
</children>
<children
compartment="//@nodes.0/@ownedChild/@compartments.1"
referencedChild="//@nodes.0/@ownedChild/@children.1/@ownedChild ">
<containmentFeature
href="modelworkz.ecore#//Entity/tablelink"/>
<childrenFeature
<ownedChild>
<domainMetaElement
href="modelworkz.ecore#//TableLink"/>
<labelMappings>
<diagramLabel
href="modelworkz.gmfgraph#TableLinkName"/>
<features
</labelMappings>
<tool
href="modelworkz.gmftool#//@palette/@tools.0/@tools.3"/>
<diagramNode
</ownedChild>
</children>
<compartments
children="//@nodes.0/@ownedChild/@children.0">
<compartment
href="modelworkz.gmfgraph#Attributes"/>
</compartments>
<compartments
children="//@nodes.0/@ownedChild/@children.1">
<compartment
href="modelworkz.gmfgraph#TableLink"/>
</compartments>
</ownedChild>
</nodes>
<links>
<domainMetaElement
href="modelworkz.ecore#//EntityRelationship"/>
<labelMappings>
<diagramLabel
href="modelworkz.gmfgraph#RelationshipName"/>
<features
</labelMappings>
<containmentFeature
href="modelworkz.ecore#//Map/entityrelationships"/>
<tool
href="modelworkz.gmftool#//@palette/@tools.0/@tools.2"/>
<diagramLink
href="modelworkz.gmfgraph#EntityRelationship"/>
<sourceMetaFeature
xsi:type="ecore:EReference"
href="modelworkz.ecore#//EntityRelationship/source"/>
<linkMetaFeature
href="modelworkz.ecore#//EntityRelationship/target"/>
</links>
<diagram>
<diagramCanvas
href="modelworkz.gmfgraph#Modelworkz"/>
<domainModel
href="modelworkz.ecore#/"/>
<domainMetaElement
href="modelworkz.ecore#//Map"/>
<palette
href="modelworkz.gmftool#//@palette"/>
</diagram>
</gmfmap:Mapping>
name="modelworkz.gmfgraph"
filename="modelworkz.gmfgraph"
<gmfgraph:Canvas xmi:version="2.0"
xmlns:gmfgraph="http://www.eclipse.org/gmf/2005/GraphicalDefinition" name="Modelworkz">
<figures
name="Default">
<figures
xsi:type="gmfgraph:Rectangle"
referencingElements="Attributes"
name="AttributeFigure"/>
<figures
xsi:type="gmfgraph:PolylineConnection"
referencingElements="EntityRelationship"
name="EntityRelationshipFigure"
targetDecoration="//@figures.0/@figures.1/@children.1">
<children
xsi:type="gmfgraph:Label"
referencingElements="RelationshipName"
name="RelationshipNameFigure"
text="<...>"/>
<children
xsi:type="gmfgraph:PolylineDecoration">
<template
x="-1"
y="1"/>
<template/>
<template
x="-1"
y="-1"/>
</children>
</figures>
<figures
referencingElements="Entity"
name="EntityFigure">
<children
referencingElements="EntityName"
name="EntityNameFigure"
text="<...>"/>
</figures>
<figures
referencingElements="TableLink"
name="TableLinkFigure"
outline="false"
fill="false"
lineWidth="0">
<layoutData
xsi:type="gmfgraph:XYLayoutData"/>
<children
xsi:type="gmfgraph:Ellipse"
name="Top">
<foregroundColor
xsi:type="gmfgraph:RGBColor"
red="100"
green="100"
blue="100"/>
<backgroundColor
red="255"
green="255"
blue="255"/>
<location
x="5"
y="3"/>
<size
x="8"
y="4"/>
</children>
<children
xsi:type="gmfgraph:Polygon"
name="Container">
<foregroundColor
red="100"
green="100"
blue="100"/>
<backgroundColor
red="255"
green="255"
blue="255"/>
<template
x="1"
y="3"/>
<template
x="1"
y="28"/>
<template
x="9"
y="28"/>
<template
x="9"
y="3"/>
</children>
<maximumSize
dx="10"
dy="30"/>
<minimumSize
dx="10"
dy="30"/>
<preferredSize
dx="10"
dy="30"/>
<size
x="10"
y="30"/>
</figures>
<figures
referencingElements="TableLinkName"
name="TableLinkNameFigure"
text="<...>"/>
<figures
referencingElements="AttributeName Attribute"
name="AttributeNameFigure"
text="<...>"/>
<figures
name="TableLinkCompFigure"/>
</figures>
<nodes
name="Entity"
figure="EntityFigure"/>
<nodes
name="Attribute"
figure="AttributeNameFigure"/>
<nodes
name="TableLink"
figure="TableLinkFigure"
resizeConstraint="NONE"/>
<connections
name="EntityRelationship"
figure="EntityRelationshipFigure"/>
<compartments
name="Attributes"
figure="AttributeFigure"/>
<compartments
name="TableLink"
figure="TableLinkCompFigure"/>
<labels
name="EntityName"
figure="EntityNameFigure"/>
<labels
name="AttributeName"
<labels
name="RelationshipName"
figure="RelationshipNameFigure"
elementIcon="false"/>
<labels
name="TableLinkName"
figure="TableLinkNameFigure"/>
</gmfgraph:Canvas>
name="modelworkz.ecore"
filename="modelworkz.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="Modelworkz"
nsURI="at.codeworkz.modelworkz" nsPrefix="mdlwrkz">
<eClassifiers xsi:type="ecore:EClass" name="Map">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="title" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="entities" upperBound="-1"
eType="#//Entity" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="entityrelationships" upperBound="-1"
eType="#//EntityRelationship" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Entity" eSuperTypes="#//NamedElement">
<eStructuralFeatures xsi:type="ecore:EReference" name="attributes" upperBound="-1"
eType="#//Attribute" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="tablelink" upperBound="-1"
eType="#//TableLink" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Attribute" eSuperTypes="#//NamedElement #//TypedElement"/>
<eClassifiers xsi:type="ecore:EClass" name="EntityRelationship" eSuperTypes="#//NamedElement">
<eStructuralFeatures xsi:type="ecore:EReference" name="source" lowerBound="1"
eType="#//Entity"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="target" lowerBound="1"
eType="#//Entity"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="NamedElement">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
defaultValueLiteral=""/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="TypedElement">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="type" eType="#//TypeNames"
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="TypeNames">
<eLiterals name="String"/>
<eLiterals name="Integer"/>
<eLiterals name="Date"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="TableLink" eSuperTypes="#//NamedElement">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="abbreviation" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
</ecore:EPackage>
--------------000903090507060209010805--
Re: ClassCastException 'Compartment Mapping' [message #56538 is a reply to message #56511] |
Wed, 27 September 2006 19:05 |
Michael Golubev Messages: 383 Registered: July 2009 |
Just ensure you have different names for all nodes/figures in gmf graph.
Now you have Compartment and Node with same name.
If you are not able to open gmfraph resource in EMF editor, change it as
text.
Michael
"Markus Musil" <markus.musil@codeworkz.at> wrote in message
news:efegu0$183$1@utils.eclipse.org...
>> Hi GMF-Community,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> Thanks and Regards
>> Markus
> thx
> <palette>
> <tools
> title="Modelworkz">
> <tools
> title="Entity"
> <smallIcon
> <largeIcon
> </tools>
> <tools
> title="Attribute"
> <smallIcon
> <largeIcon
> </tools>
> <tools
> <smallIcon
> <largeIcon
> </tools>
> <tools
> title="TableLink"
> <smallIcon
> <largeIcon
> </tools>
> </tools>
> </palette>
> <nodes>
> <containmentFeature
> <ownedChild>
> <domainMetaElement
> <labelMappings>
> <diagramLabel
> <features
> </labelMappings>
> <tool
> <diagramNode
> <children
> <containmentFeature
> <childrenFeature
> <ownedChild>
> <domainMetaElement
> <labelMappings
> <diagramLabel
> <features
> <features
> </labelMappings>
> <tool
> <diagramNode
> </ownedChild>
> </children>
> <children
> <containmentFeature
> <childrenFeature
> <ownedChild>
> <domainMetaElement
> <labelMappings>
> <diagramLabel
> <features
> </labelMappings>
> <tool
> <diagramNode
> </ownedChild>
> </children>
> <compartments
> <compartment
> </compartments>
> <compartments
> <compartment
> </compartments>
> </ownedChild>
> </nodes>
> <links>
> <domainMetaElement
> <labelMappings>
> <diagramLabel
> <features
> </labelMappings>
> <containmentFeature
> <tool
> <diagramLink
> <sourceMetaFeature
> <linkMetaFeature
> </links>
> <diagram>
> <diagramCanvas
> <domainModel
> <domainMetaElement
> <palette
> </diagram>
> </gmfmap:Mapping>
> name="Modelworkz">
> <figures
> name="Default">
> <figures
> <figures
> <children
> text="<...>"/>
> <children
> <template
> x="-1"
> y="1"/>
> <template/>
> <template
> x="-1"
> y="-1"/>
> </children>
> </figures>
> <figures
> <children
> text="<...>"/>
> </figures>
> <figures
> outline="false"
> fill="false"
> lineWidth="0">
> <layoutData
> <children
> name="Top">
> <foregroundColor
> red="100"
> green="100"
> blue="100"/>
> <backgroundColor
> red="255"
> green="255"
> blue="255"/>
> <location
> x="5"
> y="3"/>
> <size
> x="8"
> y="4"/>
> </children>
> <children
> name="Container">
> <foregroundColor
> red="100"
> green="100"
> blue="100"/>
> <backgroundColor
> red="255"
> green="255"
> blue="255"/>
> <template
> x="1"
> y="3"/>
> <template
> x="1"
> y="28"/>
> <template
> x="9"
> y="28"/>
> <template
> x="9"
> y="3"/>
> </children>
> <maximumSize
> dx="10"
> dy="30"/>
> <minimumSize
> dx="10"
> dy="30"/>
> <preferredSize
> dx="10"
> dy="30"/>
> <size
> x="10"
> y="30"/>
> </figures>
> <figures
> text="<...>"/>
> <figures
> text="<...>"/>
> <figures
> </figures>
> <nodes
> name="Entity"
> <nodes
> name="Attribute"
> <nodes
> name="TableLink"
> <connections
> <compartments
> name="Attributes"
> <compartments
> name="TableLink"
> <labels
> name="EntityName"
> <labels
> <labels
> <labels
> </gmfgraph:Canvas>
> upperBound="-1"
> </eClassifiers>
> upperBound="-1"
> upperBound="-1"
> </eClassifiers>
> lowerBound="1"
> eType="#//Entity"/>
> lowerBound="1"
> eType="#//Entity"/>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
Re: ClassCastException 'Compartment Mapping' [message #58446 is a reply to message #56538] |
Mon, 02 October 2006 16:40 |
Hi Michael,
thank you for your help. Worked perfectly!
regards,
markus
Michael Golubev schrieb:
> text.
> Michael
>>> Hi GMF-Community,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thanks and Regards
>>> Markus
>> thx
>> <?xml version="1.0" encoding="UTF-8"?>
>> <palette>
>> <tools
>> title="Modelworkz">
>> <tools
>> title="Entity"
>> <smallIcon
>> <largeIcon
>> </tools>
>> <tools
>> title="Attribute"
>> <smallIcon
>> <largeIcon
>> </tools>
>> <tools
>> <smallIcon
>> <largeIcon
>> </tools>
>> <tools
>> title="TableLink"
>> <smallIcon
>> <largeIcon
>> </tools>
>> </tools>
>> </palette>
>> <nodes>
>> <containmentFeature
>> <ownedChild>
>> <domainMetaElement
>> <labelMappings>
>> <diagramLabel
>> <features
>> </labelMappings>
>> <tool
>> <diagramNode
>> <children
>> <containmentFeature
>> <childrenFeature
>> <ownedChild>
>> <domainMetaElement
>> <labelMappings
>> <diagramLabel
>> <features
>> <features
>> </labelMappings>
>> <tool
>> <diagramNode
>> </ownedChild>
>> </children>
>> <children
>> <containmentFeature
>> <childrenFeature
>> <ownedChild>
>> <domainMetaElement
>> <labelMappings>
>> <diagramLabel
>> <features
>> </labelMappings>
>> <tool
>> <diagramNode
>> </ownedChild>
>> </children>
>> <compartments
>> <compartment
>> </compartments>
>> <compartments
>> <compartment
>> </compartments>
>> </ownedChild>
>> </nodes>
>> <links>
>> <domainMetaElement
>> <labelMappings>
>> <diagramLabel
>> <features
>> </labelMappings>
>> <containmentFeature
>> <tool
>> <diagramLink
>> <sourceMetaFeature
>> <linkMetaFeature
>> </links>
>> <diagram>
>> <diagramCanvas
>> <domainModel
>> <domainMetaElement
>> <palette
>> </diagram>
>> </gmfmap:Mapping>
>> name="Modelworkz">
>> <figures
>> name="Default">
>> <figures
>> <figures
>> <children
>> text="<...>"/>
>> <children
>> <template
>> x="-1"
>> y="1"/>
>> <template/>
>> <template
>> x="-1"
>> y="-1"/>
>> </children>
>> </figures>
>> <figures
>> <children
>> text="<...>"/>
>> </figures>
>> <figures
>> outline="false"
>> fill="false"
>> lineWidth="0">
>> <layoutData
>> <children
>> name="Top">
>> <foregroundColor
>> red="100"
>> green="100"
>> blue="100"/>
>> <backgroundColor
>> red="255"
>> green="255"
>> blue="255"/>
>> <location
>> x="5"
>> y="3"/>
>> <size
>> x="8"
>> y="4"/>
>> </children>
>> <children
>> name="Container">
>> <foregroundColor
>> red="100"
>> green="100"
>> blue="100"/>
>> <backgroundColor
>> red="255"
>> green="255"
>> blue="255"/>
>> <template
>> x="1"
>> y="3"/>
>> <template
>> x="1"
>> y="28"/>
>> <template
>> x="9"
>> y="28"/>
>> <template
>> x="9"
>> y="3"/>
>> </children>
>> <maximumSize
>> dx="10"
>> dy="30"/>
>> <minimumSize
>> dx="10"
>> dy="30"/>
>> <preferredSize
>> dx="10"
>> dy="30"/>
>> <size
>> x="10"
>> y="30"/>
>> </figures>
>> <figures
>> text="<...>"/>
>> <figures
>> text="<...>"/>
>> <figures
>> </figures>
>> <nodes
>> name="Entity"
>> <nodes
>> name="Attribute"
>> <nodes
>> name="TableLink"
>> <connections
>> <compartments
>> name="Attributes"
>> <compartments
>> name="TableLink"
>> <labels
>> name="EntityName"
>> <labels
>> <labels
>> <labels
>> </gmfgraph:Canvas>
>> upperBound="-1"
>> </eClassifiers>
>> upperBound="-1"
>> upperBound="-1"
>> </eClassifiers>
>> lowerBound="1"
>> eType="#//Entity"/>
>> lowerBound="1"
>> eType="#//Entity"/>
>> </eClassifiers>
>> </eClassifiers>
>> </eClassifiers>
>> </eClassifiers>
>> </eClassifiers>
>> </ecore:EPackage>
FUDForum. Page generated in 0.04534 seconds
