Home » Modeling » GMF (Graphical Modeling Framework) » Adding a listener to a diagram after opening it in an edtor
Adding a listener to a diagram after opening it in an edtor [message #56403] Wed, 27 September 2006 09:42 Go to next message
Originally posted by: daniel-p.gmx.de
Hi everybody,
I need to add a listener to a digram after I opened it programmatically. I
first create a FileInput which I then pass to the IEditorPart
IDE.openEditor method.
I tried adding a listener to the underlying domain model before calling
IDE.openEditor, but as I expected this does not work.
Does anybody know how to accomplish that task?
Dan
Re: Adding a listener to a diagram after opening it in an edtor [message #56871 is a reply to message #56403] Thu, 28 September 2006 05:12 Go to previous messageGo to next message
Hello Daniel,
Please take a loot on generated ???EditPart class for your diagram. (this
class extends DiagramEditPart). You can override addNotationalListeners()
method in this class and attach your listener to the Diagram instance there.
Alex Shatalin
Re: Adding a listener to a diagram after opening it in an edtor [message #56922 is a reply to message #56871] Thu, 28 September 2006 06:42 Go to previous messageGo to next message
Sorry, that does not work in my case, since I have to add the listener
from inside another plug-in and set up the listener with some generic
information.
Dan
On Thu, 28 Sep 2006 11:12:51 +0200, Alex Shatalin <vano@borland.com> wrote:
> Hello Daniel,
> (this class extends DiagramEditPart). You can override
> addNotationalListeners() method in this class and attach your listener
> Alex Shatalin
Re: Adding a listener to a diagram after opening it in an edtor [message #56947 is a reply to message #56922] Thu, 28 September 2006 07:04 Go to previous messageGo to next message
Hello Daniel,
Then take a look on generated ???ViewProvider class. This class return ???ViewFactory.class
from getDiagramViewClass(). You can:
- create your own ViewProvider and register it with higher priority then
generated one
- implement only getDiagramViewClass in this provider and return custom factory
class from there.
- custom factory class could subclass generated factory class and attach
desired listener by overriding createDiagram() method.
Alex Shatalin
Re: Adding a listener to a diagram after opening it in an edtor [message #57675 is a reply to message #56947] Fri, 29 September 2006 16:02 Go to previous messageGo to next message
Daniel,
Depending on what you want to do, it might make more sense to install an
editpolicy on your diagram editpart and add the listener in here.
Search the GMF docs for info on the editpolicy service to learn how to
install an editpolicy from another plugin.
Cherie
Alex Shatalin wrote:
> Hello Daniel,
> ???ViewFactory.class from getDiagramViewClass(). You can:
> generated one
> factory class from there.
> Alex Shatalin
Re: Adding a listener to a diagram after opening it in an edtor [message #58359 is a reply to message #57675] Mon, 02 October 2006 10:02 Go to previous message
Daniel :
I don not think View Factories are the way to go here; since view
factories will be invoked only during view creation; which means if your
diagram view is serialized in the resource, the next time you open it no
view factory will be called to create the diagram.
Now , regarding adding listeners, when you say you open the diagram
programatically do you mean you just opened the resource or did you
render the diagram on the screen ?
If you just loaded the resource, then Edit parts or edit policies
will not help since they exist only if the diagram is rendered, an you
might need a resource listener instead which you should install after
you load the resource
If you rendered the diagram then your diagram edit part is already
listening to the diagram, you can modify it to add listeners as you
like, check addSemanticListeners, or you can create a speciallied edit
policy that does the listening and install it on your edit part
> Daniel,
> editpolicy on your diagram editpart and add the listener in here. Search
> the GMF docs for info on the editpolicy service to learn how to install
> Cherie
>> Hello Daniel,
>> then generated one
>> custom factory class from there.
>> attach desired listener by overriding createDiagram() method.
>> Alex Shatalin
Previous Topic:Bug in Ecore Editor, assotiation between Eclass and EEnum
Next Topic:Specify what to use as Link containers
Current Time: Thu Nov 06 04:12:10 EST 2025
Powered by FUDForum. Page generated in 0.04316 seconds
