java Printstream printf() [message #56360] |
Fri, 22 April 2005 22:25 |
Originally posted by: justin.loh.plexelis.com
I have tried to use java printf (available in jdk1.5.0_02) in the
following program:
//Fig 2.6: Welcome4.java
// Printing multiple lines in a dialog box.
public class Welcome4
// main method begins execution of Java appliation
public static void main(String args[])
System.out.printf("%s\n%s\n", "Welcome to ", "Java
Programming");
} // end method main
} //end class Welcome4
It compile fine when I compile it in cmd window using javac.exe. But when
I tried it in Eclipse, it did not compile giving an exception message:
Exception in thread "main" java.lang.Error: Unresolved compilation
problem:
The method printf(String, Object[]) in the type PrintStream is not
applicable for the arguments (String, String, String)
Can anyone help?
Rgds,
Justin Loh
Re: java Printstream printf() [message #56408 is a reply to message #56360] |
Fri, 22 April 2005 23:10 |
Originally posted by: mirdous.seznam.cz
Well try to press ctrl+space to bring content assist
and you'll see there are 2 printf methods
1. printf(Locale, String , Object[])
2. printf(String, Object[])
that's why you get Ex
> following program:
> { System.out.printf("%s\n%s\n", "Welcome to ",
> "Java Programming"); } // end method main
> when I tried it in Eclipse, it did not compile giving an exception message:
> problem: The method printf(String, Object[]) in the type PrintStream
> is not applicable for the arguments (String, String, String)
> Can anyone help?
> Rgds,
> Justin Loh
Re: java Printstream printf() [message #57761 is a reply to message #56408] |
Tue, 26 April 2005 15:28 |
Originally posted by: jusloh.singnet.com.sg
I know about content assist but it does not solve the problem. javac.exe
compiles OK with the same program but Eclipse just complains with the
exception message reported. Why??? The same problem is reported by Tim
Julian:
21.04. * System.out.printf Broken? Tim Julian
25.04. `* Re: System.out.printf Broken? Chris Laffra
26.04. +- Re: System.out.printf Broken? Tim Julian
26.04. `- Re: System.out.printf Broken? Tim Julian
But his case is with:
System.out.printf( "Product is %d\n", result );
It says .printf is expecting an object[] and not an int!
Eclipse did not go well with String.format method too and reports the
similar exception message.
All I know is that all these two methods are new methods in JDK1.5.0_02
version and Eclipse just don't how to deal with them (I did set the
preference>java setting to JRE1.5.0_02).
Justin Loh
Re: java Printstream printf() [message #57932 is a reply to message #57761] |
Tue, 26 April 2005 21:29 |
> Julian:
> System.out.printf( "Product is %dn", result );
> Justin Loh
You need to be running one of the 3.1M releases of Eclipse (3.1M6 is
current) and you also need to set you compiler compliance level to 1.5.
FUDForum. Page generated in 0.04639 seconds
