Home » Archived » IMP » Problems with LPG parser
Problems with LPG parser [message #5023] Mon, 17 September 2007 13:53 Go to next message
Originally posted by: olegm.gmail.com
I am trying to follow the tutorial of IMP
http://eclipse-imp.sourceforge.net/documentation/users_guide .html
and get stuck on compiling LPG grammar (see the log below).
FAQ
http://eclipse-imp.sourceforge.net/documentation/faq.html
mentions project "lpg.runtime.java" that can be used for external
compilation of LPG, however, I didn't manage to find it anywhere.
Whas it meant to import plugin "org.eclipse.imp.lpg.runtime" as a project?
Finally, I have tried running LPG binary on the command-line,
but then it complained about the syntax of a template file (see the log
below).
Any suggestions, please? :)
I have archived my whole workspace at:
http://uuslepo.it.da.ut.ee/~olegm/temp/workspace.tar.gz
Thank You for Your help,
Oleg Mürk
----------------- Bash -----------------
[olegm@localhost ~]$ uname -a
Linux localhost.localdomain 2.6.22.5-76.fc7 #1 SMP Thu Aug 30 13:47:21
EDT 2007 i686 i686 i386 GNU/Linux
[olegm@localhost ~]$ tar xzf Desktop/eclipse-SDK-3.2.2-linux-gtk.tar.gz
[olegm@localhost ~]$ cat eclipse/eclipse.ini
-vm
/usr/java/jdk1.5.0_12/bin/java
-vmargs
-Xms40m
-Xmx1024m
----------------- Eclipse -----------------
Eclipse:Help->Software Updates->...
http://www.cs.cornell.edu/Projects/polyglot/eclipseUpdates/
http://lpg.sourceforge.net/updates/
http://eclipse-imp.sourceforge.net/updates/
Eclipse:Files->New->New Plugin Project
OM
Eclipse:Files->New->Programming Language Descriptor
OM
Eclipse:Files->New->New LPG Grammar with Parser Wrapper
java.io.IOException: java.io.IOException:
/home/olegm/eclipse/plugins/lpg.runtime_2.0.6/lpgexe/lpg-lin ux_x86:
cannot execute
[olegm@localhost ~]$ chmod u+x
"" -include-directory='/home/olegm/eclipse/plugins/org.eclipse. imp.lpg.metatooling_1.0.62/templates/;/home/olegm/eclipse/pl ugins/lpg.runtime_2.0.6/templates/' ""
is an invalid option OM/src/om/safari/parser OMParser.g line 1
1190048698873 43
[olegm@localhost ~]$ cat workspace/OM/src/om/safari/parser/OMParser.l
/home/olegm/workspace/OM/src/om/safari/parser/OMParser.g:0:0 :0:0:0:0:
Error: Option
is missing preceding '-'
Error:
../eclipse/plugins/lpg.runtime_2.0.6/lpgexe/lpg-linux_x86
Options in effect for workspace/OM/src/om/safari/parser/OMKWLexer.gi:
ACTION-BLOCK=("workspace/OM/src/om/safari/parser/OMKWLexer.java ","/.","./")
AST-DIRECTORY="./Ast" AST-TYPE="Ast" NOATTRIBUTES NOAUTOMATIC-AST
NOBACKTRACK BYTE CONFLICTS
DAT-DIRECTORY="workspace/OM/src/om/safari/parser/"
DAT-FILE="workspace/OM/src/om/safari/parser/OMKWLexerdcl.data "
DCL-FILE="workspace/OM/src/om/safari/parser/OMKWLexerdcl.java "
NODEBUG
DEF-FILE="workspace/OM/src/om/safari/parser/OMKWLexerdef.java "
NOEDIT
NOERROR-MAPS ESCAPE='$'
EXPORT-TERMINALS=("workspace/OM/src/om/safari/parser/OMParsersym.java ","TK_","")
EXTENDS-PARSETABLE FACTORY="new " FILE-PREFIX="OMKWLexer" NOFIRST
NOFOLLOW NOGLR NOGOTO-DEFAULT
GRM-FILE="workspace/OM/src/om/safari/parser/OMKWLexer.gi"
IMP-FILE="workspace/OM/src/om/safari/parser/OMKWLexerimp.java "
INCLUDE-DIRECTORY=" /home/olegm/eclipse/plugins/org.eclipse.imp.lpg.metatooling_ 1.0.62/templates/;/home/olegm/eclipse/plugins/lpg.runtime_2. 0.6/templates/ "
LALR=1
NOLIST MARGIN=4 MAX-CASES=1024 NAMES=OPTIMIZED NONT-CHECK
OR_MARKER='|'
OUT-DIRECTORY="workspace/OM/src/om/safari/parser/"
PACKAGE="om.safari.parser" NOPARENT-SAVE
PARSETABLE-INTERFACES="lpg.runtime.ParseTable" PREFIX="Char_"
PRIORITY
PROGRAMMING_LANGUAGE=JAVA
PRS-FILE="workspace/OM/src/om/safari/parser/OMKWLexerprs.java "
NOQUIET
READ-REDUCE REMAP-TERMINALS NOSCOPES NOSERIALIZE NOSHIFT-DEFAULT
NOSINGLE-PRODUCTIONS NOSOFT-KEYWORDS NOSTATES SUFFIX=""
SYM-FILE="workspace/OM/src/om/safari/parser/OMKWLexersym.java "
TAB-FILE="OMKWLexer.t" TABLE TEMPLATE="KeywordTemplate.gi"
TRACE=CONFLICTS NOVARIABLES NOVERBOSE NOVISITOR
VISITOR-TYPE="Visitor"
WARNINGS NOXREF
/home/olegm/eclipse/plugins/org.eclipse.imp.lpg.metatooling_ 1.0.62/templates/KeywordTemplate.gi:25:1:25:4:775:778:
Error: Syntax error detected on this token
Re: Problems with LPG parser [message #5094 is a reply to message #5023] Mon, 17 September 2007 14:03 Go to previous messageGo to next message
One more thing:
When I try "Window->Preferences->LPG Preferences->Select Project", it
shows me my project "OM", however selecting it does not have any effect
and I cannot edit any LPG preferences.
Oleg Murk wrote:
> Hello,
> FAQ
> below).
> Oleg Mürk
> -vm
> -vmargs
> -Xms40m
> -Xmx1024m
> OM
> OM
> cannot execute
> 1190048698873 43
> Error: Option
> Error:
> DCL-FILE="workspace/OM/src/om/safari/parser/OMKWLexerdcl.java " NODEBUG
> DEF-FILE="workspace/OM/src/om/safari/parser/OMKWLexerdef.java " NOEDIT
> IMP-FILE="workspace/OM/src/om/safari/parser/OMKWLexerimp.java " LALR=1
> OR_MARKER='|'
> PARSETABLE-INTERFACES="lpg.runtime.ParseTable" PREFIX="Char_" PRIORITY
> PRS-FILE="workspace/OM/src/om/safari/parser/OMKWLexerprs.java " NOQUIET
> WARNINGS NOXREF
Re: Problems with LPG parser [message #5161 is a reply to message #5094] Mon, 17 September 2007 19:06 Go to previous messageGo to next message
Hi Oleg:
It would appear from your output that you are trying to use IMP on
Linux. Unfortunately, at the moment we only support the Windows
version and only the Windows binary is up to date.
Feel free to download the LPG source from Sourceforge and build
a Linux binary for LPG on your system. I believe that that should work fine.
--philippe
Oleg Murk wrote:
> One more thing:
> Oleg Murk wrote:
>> Hello,
>> FAQ
>> project?
>> log below).
>> Oleg Mürk
>> -vm
>> -vmargs
>> -Xms40m
>> -Xmx1024m
>> OM
>> OM
>> cannot execute
>> 1 1190048698873 43
>> Error: Option
>> Error:
>> NODEBUG
>> OR_MARKER='|'
>> PRIORITY
>> NOQUIET
>> WARNINGS NOXREF
Re: Problems with LPG parser [message #5229 is a reply to message #5161] Tue, 18 September 2007 14:02 Go to previous messageGo to next message
> fine.
Building LPG binary for Linux from sources didn't give results (the same
errors). However I managed to run LPG using Windows emulator Wine.
The trick is to replace the contents of file
$ECLIPSE_HOME/plugins/lpg.runtime_2.0.6/lpgexe/lpg-linux_x86
with a script
#/bin/bash
`echo wine $0 $* | sed "s/lpg-linux_x86/lpg-win32_x86.exe/" | sed
"s/\"-include/-include/" | sed "s/'\"/'/"`
and make it executable
chmod u+x $ECLIPSE_HOME/plugins/lpg.runtime_2.0.6/lpgexe/lpg-linux_x86
OM
Re: Problems with LPG parser [message #5295 is a reply to message #5229] Tue, 18 September 2007 21:09 Go to previous message
Good idea. Thanks for the info.
--thanks
Oleg Murk wrote:
> Hello,
>> fine.
> with a script
> #/bin/bash
> Cheers,
> OM
Re: Problems with LPG parser [message #566414 is a reply to message #5023] Mon, 17 September 2007 14:03 Go to previous message
One more thing:
Oleg Murk wrote:
> Hello,
> FAQ
> below).
> Oleg Mürk
> -vm
> -vmargs
> -Xms40m
> -Xmx1024m
> OM
> OM
> cannot execute
> 1190048698873 43
> Error: Option
> Error:
> OR_MARKER='|'
> WARNINGS NOXREF
Re: Problems with LPG parser [message #566429 is a reply to message #5094] Mon, 17 September 2007 19:06 Go to previous message
Hi Oleg:
--philippe
Oleg Murk wrote:
> One more thing:
> Oleg Murk wrote:
>> Hello,
>> FAQ
>> project?
>> log below).
>> Oleg Mürk
>> -vm
>> -vmargs
>> -Xms40m
>> -Xmx1024m
>> OM
>> OM
>> cannot execute
>> 1 1190048698873 43
>> Error: Option
>> Error:
>> NODEBUG
>> OR_MARKER='|'
>> PRIORITY
>> NOQUIET
>> WARNINGS NOXREF
Re: Problems with LPG parser [message #566450 is a reply to message #5161] Tue, 18 September 2007 14:02 Go to previous message
> fine.
with a script
#/bin/bash
OM
Re: Problems with LPG parser [message #566474 is a reply to message #5229] Tue, 18 September 2007 21:09 Go to previous message
--thanks
Oleg Murk wrote:
> Hello,
>> fine.
> with a script
> #/bin/bash
> Cheers,
> OM
Previous Topic:Problems with LPG parser
Next Topic:LexStream
Current Time: Wed Apr 23 22:55:08 EDT 2025
Powered by FUDForum. Page generated in 0.26329 seconds
