Home » Eclipse Projects » Nebula » Header Font does not repaint properly
Header Font does not repaint properly [message #56351] Tue, 15 July 2008 18:06 Go to next message
Originally posted by: kathir.atc.tcs.com
I created a GridViewer with two columns Property and Value.
When i set a new font for the Grid the font size on the Grid header font
gets changed but the it does not look like its repainting it properly.
Say if i set a bigger font, just the header text gets repainted but the
header area is still the same leaving half the text invisible in(height
wise)
BR,
Kathir.
Re: Header Font does not repaint properly [message #58319 is a reply to message #56351] Fri, 22 August 2008 23:15 Go to previous message
David Kyle is currently offline David KyleFriend
Check out https://bugs.eclipse.org/bugs/show_bug.cgi?id=212281.
Re: Header Font does not repaint properly [message #591924 is a reply to message #56351] Fri, 22 August 2008 23:15 Go to previous message
Previous Topic:GridViewer - EditorActivationStrategy per Column
Next Topic:Grid/Gridviewer - Too long texts
Current Time: Sat Nov 09 03:39:21 GMT 2024
Powered by FUDForum. Page generated in 0.02840 seconds
