Home » Archived » Test and Performance Tools Platform (TPTP) » Extending profiler
Extending profiler [message #56286] |
Sun, 05 March 2006 08:13  |
Originally posted by: michael.zend.com
Hi All,
Is it possible to extend TPTP's profiler for different language (say
Perl)? If so, what whould you recommend me for reading
(I didn't find any helpful document describing how to extend TPTP's
profiler), or just give me some kind of glue what parts should be
extended, and what should stay as is.
Thanks a lot.
Re: Extending profiler [message #56461 is a reply to message #56342] |
Tue, 07 March 2006 04:23   |
Hi Paul,
Thank you for your answer!
As I understood the structure of the language must match Java's structures (threads, exceptions, classes, etc...),
otherwise it's impossible to create such an Agent?
Paul Slauenwhite wrote:
> Hi Michael,
> Although there is no specific information on extending the Java
> Profiler, you can write an agent that generates the same trace XML fragments
> to populate the TPTP Trace model. The XML fragments need to follow the TPTP
> Event Specification for Java profiling (see
> http://www.eclipse.org/tptp/platform/documents/resources/pro filingspec/XML4Profiling.htm
> and
> http://www.eclipse.org/tptp/platform/documents/resources/pro filingspec/trace.dtd.html).
> Your agent would write the fragments to a Logging Agent that the workbench
> would monitor to populate the TPTP Trace model. See the
> http://www.eclipse.org/tptp/home/documents/eclipseWorld2005/ EclipseWorld_2005_Tutorial_2_Eugene_Chan_Paul_Slauenwhite.pd f
> presentation and its source code
> ( http://www.eclipse.org/tptp/home/documents/eclipseWorld2005/ EclipseWorld_20
> 05_Tutorial_2_Source_Code_Eugene_Chan_Paul_Slauenwhite.zip) for an example
> agent.
> Paul
> "Michael Spector" <michael@zend.com> wrote in message
> news:dueo52$aqd$1@eclipse.org...
>>Hi All,
>>Thanks a lot.
Re: Extending profiler [message #56488 is a reply to message #56461] |
Tue, 07 March 2006 09:39  |
Hi Michael,
The TPTP data model has been expanded in TPTP V4.1.0 to support
application performance data from non-Java complied applications, such as
C/C++. For more information, see:
Help >> Help Contents >> Monitoring and analyzing performance >> Monitoring
and analyzing application performance >> Profiling an application >>
Profiling views >> Understanding the application context system in profiling
views
Paul
news:dujjea$mgr$1@eclipse.org...
> Hi Paul,
> > Hi Michael,
fragments
TPTP
> > and
workbench
example
> > agent.
> > Paul
> >>Hi All,
> >>Thanks a lot.
Current Time: Wed Apr 16 10:01:37 EDT 2025
Powered by FUDForum. Page generated in 0.10791 seconds
