Home » Eclipse Projects » Mylyn » Using weekly updates with Eclipse 3.3.2
Using weekly updates with Eclipse 3.3.2 [message #56230] Tue, 19 August 2008 06:47 Go to next message
Hi all,
today we tried to upgrade to Mylyn 3.0.1 using this procedure:
1. Fresh install of Eclipse 3.3.2 Europa Winter
2. Upgrade to Mylyn 3.0.1
3. Add extras site for 3.0.1
4. Failed to add incubator for 3.0.1 (we need the Generic Web Connector / Web templates)
At this point we switched to the weekly update sites
5. Update from weekly update site for incubator, install Generic Web Connector
6. Tried to update from weekly update site for E3.3 and extras
As we select to install all E3.3 features, some dependency to the UI seems to be broken.
Any idea how to consistently install Mylyn 3.0.1/2 for Eclipse 3.3.2 from the weekly update site?
Thanks, Jörg
P.S. Sorry, I checked the News group but did not found any suitable answer.
Re: Using weekly updates with Eclipse 3.3.2 [message #56247 is a reply to message #56230] Tue, 19 August 2008 08:05 Go to previous messageGo to next message
Hi all,
update on installation success:
Now we reverted our config to the initial fresh installation of Eclipse 3.3.2 Europa Winter.
Then we directly added the 3 weekly update site:
download.eclipse.org/tools/mylyn/update/weekly/e3.4
download.eclipse.org/tools/mylyn/update/weekly/extras
download.eclipse.org/tools/mylyn/update/weekly/incubator
This works directly.
But the migration path from 3.0.1 seems to be blocked somehow.
We also noted that the installation of Mylyn 3.0.1 for E3.3.2 added a (non-editable) update site for
Mylyn, which seems to point to the 3x versions (i.e. Eclipse 3.4). So we had to disable this
built-in update site and use our own one. Maybe this is a bug in the packaging of the E3.3 version.
Cheers, Jörg
On 08/19/08 12:47, Jörg Thönnes wrote:
> Hi all,
> Thanks, Jörg
Re: Using weekly updates with Eclipse 3.3.2 [message #56283 is a reply to message #56247] Tue, 19 August 2008 16:26 Go to previous messageGo to next message
Thanks for letting us know. The site.xml of the incubator site indeeds had a
bogus mirror redirect. I have fixed that and installing from the site
should work again within the hour.
Please make sure to you use the 3.3 update site for Eclipse 3.3.2:
download.eclipse.org/tools/mylyn/update/weekly/e3.3
Can you elaborate why the update did not work?
> (non-editable) update site for Mylyn, which seems to point to the 3x
> versions (i.e. Eclipse 3.4). So we had to disable this built-in update
> version.
That is odd. I just installed from this site
download.eclipse.org/tools/mylyn/update/e3.3 and was able to reproduce the
problem. I'll look into it.
Steffen
Re: Using weekly updates with Eclipse 3.3.2 [message #56287 is a reply to message #56283] Tue, 19 August 2008 17:46 Go to previous messageGo to next message
It turned out that the URL of the discovery site in the Task List feature
for Eclipse 3.3 was pointing at the 3.4 update site:
244618: tasklist feature for 3.3 contributes link to 3.4 update site
https://bugs.eclipse.org/bugs/show_bug.cgi?id=244618
I have fixed that and added an entry to the FAQ how to recover:
http://wiki.eclipse.org/Mylyn/FAQ#Why_is_the_update_on_Eclip se_3.3_failing.3F
Thanks again Jörg for finding and reporting these bugs!
Steffen
> a bogus mirror redirect. I have fixed that and installing from the site
>> E3.3 version.
> Steffen
Re: Using weekly updates with Eclipse 3.3.2 [message #56294 is a reply to message #56283] Wed, 20 August 2008 03:12 Go to previous message
Sorry, that was a cut'n' paste error. Of course, I do use the .../weekly/e3.3
I could describe the steps so you could reproduce:
2. Upgrade to Mylyn 3.0.1 using
3. Added all extras for Mylyn 3.0.1 using
download.eclipse.org/tools/mylyn/update/extras
4. Failed to Generic Web Connector from the incubator site
download.eclipse.org/tools/mylyn/update/incubator
At this point we decided to switch to the weekly update sites
5. Added Generic Web Connector from the incubator site
This fails due to unsatisfied dependencies.
Sorry, that I do not have the time at the moment to go through these steps myself and provide you
with more details. If you try these steps yourself, you will hopefully see the same errors.
Cheers, Jörg
Re: Using weekly updates with Eclipse 3.3.2 [message #592559 is a reply to message #56230] Tue, 19 August 2008 08:05 Go to previous message
Hi all,
Cheers, Jörg
> Hi all,
> Thanks, Jörg
Re: Using weekly updates with Eclipse 3.3.2 [message #592575 is a reply to message #56247] Tue, 19 August 2008 16:26 Go to previous message
> version.
Steffen
Re: Using weekly updates with Eclipse 3.3.2 [message #592585 is a reply to message #56283] Tue, 19 August 2008 17:46 Go to previous message
Steffen
>> E3.3 version.
> Steffen
Re: Using weekly updates with Eclipse 3.3.2 [message #592603 is a reply to message #56283] Wed, 20 August 2008 03:12 Go to previous message
Cheers, Jörg
Previous Topic:Missing News & Noteworthy for weekly builds
Next Topic:JIRA filter not showing full results as a Mylyn query
Current Time: Wed Mar 12 00:46:02 EDT 2025
Powered by FUDForum. Page generated in 0.03373 seconds
