Home » Newcomers » Newcomers » System.out.printf Broken?
System.out.printf Broken? [message #56194] Thu, 21 April 2005 18:51 Go to next message
Originally posted by: tim.julian.hsc.utah.edu
When I run the simple code from a Deitle book such as the following:
import java.util.Scanner; // program uses Scanner
public class Product
public static void main( String args[] )
// create Scanner to obtain input from command window
Scanner input = new Scanner( System.in );
int x; // first number input by user
int y; // second number input by user
int z; // third number input by user
int result; // product of numbers
System.out.print( "Enter first integer: " ); // prompt for input
x = input.nextInt(); // read first integer
System.out.print( "Enter second integer: " ); // prompt for input
y = input.nextInt(); // read second integer
System.out.print( "Enter third integer: " ); // prompt for input
z = input.nextInt(); // read third integer
result = x * y * z; // calculate product of numbers
System.out.printf( "Product is %d\n", result );
} // end method main
} // end class Product
It says .printf is expecting an object[] and not an int!
Any ideas?
(the scanner works fine as contrasted with the new NetBeans!)
Re: System.out.printf Broken? [message #57298 is a reply to message #56194] Mon, 25 April 2005 20:05 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
What version of Eclipse are you running? You need at least 3.1M6
Chris Laffra, http://eclipsefaq.org
"Tim Julian" <tim.julian@hsc.utah.edu> wrote in message
news:2771bd5dde50f1a1760f1908933d8346$1@www.eclipse.org...
> Any ideas?
Re: System.out.printf Broken? [message #57627 is a reply to message #57298] Tue, 26 April 2005 09:46 Go to previous messageGo to next message
I am running 3.0.2. Is not that the latest "safe" version?
Re: System.out.printf Broken? [message #57652 is a reply to message #57298] Tue, 26 April 2005 10:12 Go to previous messageGo to next message
I reloaded the latest version: 3.1M6 and it still gave me the error: "the
method printf( String, Object[]) in the type PrintStream is not applicable
for the arguments (String,int). Any ideas?
int result = 1;
System.out.printf( "result= %d\n", result );
It does not get much simpler than this....
Re: System.out.printf Broken? [message #58554 is a reply to message #56194] Wed, 27 April 2005 16:55 Go to previous messageGo to next message
Originally posted by: john.eclipsefaq.org
Are you using a Java 1.5 VM? Make sure your JRE (Preferences > Java >
Installed JREs) is using Java 1.5. The method you are trying to use was
only introduced in this version of Java, which did not exist at the time
Eclipse 3.0 was released.
> public class Product {
> Any ideas?
Re: System.out.printf Broken? [message #58988 is a reply to message #58554] Thu, 28 April 2005 10:00 Go to previous messageGo to next message
Yes, I have JRE 1.5 installed. If you will notice the scanner object is
part of 1.5. The scanner object works fine, it is the System.out.printf
method that does not work.
Re: System.out.printf Broken? [message #59087 is a reply to message #58988] Thu, 28 April 2005 11:36 Go to previous messageGo to next message
You also need to have the Java Complier compliance set to 1.5.
Re: System.out.printf Broken? [message #59685 is a reply to message #59087] Fri, 29 April 2005 14:19 Go to previous messageGo to next message
That finally fixed the problem: windows / preferences / compiler /
Compiler compliance level
Set to 5.0
It is odd that the scanner object did work correctly however....
Re: System.out.printf Broken? [message #59709 is a reply to message #59685] Fri, 29 April 2005 14:27 Go to previous message
> Set to 5.0
It sounds like you are confusing the language specification with the
runtime library. 5.0 made changes to both. The Scanner is a new class in
the runtime library. The compiler changes necessary to convert the
System.printf arguments properly is a language change.
You can use a 1.4 compiler to compile classes that reference the 5.0
runtime libraries.
Previous Topic:HTML WYSIWYG Editor
Next Topic:Dump Question: The requested resource (/tutorial/snoop) is not available
Current Time: Sat Oct 25 18:28:41 EDT 2025
Powered by FUDForum. Page generated in 0.08912 seconds
