Re: Problem with ant output. [message #56140 is a reply to message #56112] |
Fri, 13 June 2003 12:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: darin_swanson.oti.com
Which compiler are you using? Are you setting the build.compiler property?
javac will attempt to do incremental compiles...from the Ant doc: "
The source and destination directory will be recursively scanned for Java
source files to compile. Only Java files that have no corresponding .class
file or where the class file is older than the .java file will be compiled."
Could this be the case that the .class files is up to date?
If not please log a bug report against platform-ant and we can look into
things more in detail.
Darins
"Mathias Ohlsson" <mathias.ohlsson@enovation.se> wrote in message
news:bccebi$3j6$1@rogue.oti.com...
> I don't know what Im missing here. I have a normal build.xml which
compiles
> normally in the dos-prompt. The thing is that when I use it in Eclipse Im
> missing a lot of the output. For example, when I do a build (where I
compile
> one file) I get this in Eclipse:
> Buildfile: D:\Project\myproject\build.xml
> init:
> compile:
> BUILD SUCCESSFUL
> Total time: 771 milliseconds
> But when I do this in dos, I get:
> Buildfile: build.xml
> init:
> compile:
> [javac] Compiling 1 source file to D:\Project\myproject\lib
> BUILD SUCCESSFUL
> Total time: 12 seconds
> How do I set Eclipse so I see the javac output? Another things I have
> noticed is that I can compile error files through Eclipse.With that I mean
> that I get the same output as the first example when I know there is an
> error in the file. The error is then shown when I run the program (it can
> for example be a missing semicolon). Eclipse dont tell me anything that
the
> error exist, more than showing it in the task view. Is there some way to
> make it stop when there is an error?
> This is the tasks I have in the build.xml file:
> <target name="init">
> <mkdir dir="${build}" />
> <tstamp/>
> </target>
> <target name="compile" depends="init">
> <javac classpath = "${classpath}"
> srcdir = "${src}"
> destdir = "${build}"
> deprecation = "on"
> <include name="**/*.java"/>
> </javac>
> </target>
> Thanks in advance!
> /Mathias Ohlsson
Re: Problem with ant output. [message #56437 is a reply to message #56410] |
Fri, 13 June 2003 12:51 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
We will investigate your bug report.
Darins
news:bccgpl$63l$1@rogue.oti.com...
> No, the .class file is not up to date and that isnt the real problem. The
> file is found and compiled, that I have checked but its the output in the
> console thats missing. It doesnt say that there is x nr of files compiling
> nor does it give feedback when there is errors in the file. Although I
find
> it strange that it can output an .class file with errors in it, the
problem
> I have is that I lack the information about it.
> /Mathias
> "Darin Swanson" <darin_swanson@oti.com> wrote in message
> news:bccgd0$5ms$1@rogue.oti.com...
property?
Java
..class
> compiled."
> > Thanks
> > Darins
> > > Hi,
> > compiles
> Im
> > compile
> > > init:
> > > compile:
> > > BUILD SUCCESSFUL
> > > init:
> > > compile:
> > > BUILD SUCCESSFUL
> mean
an
> can
that
> > the
to
> > > <tstamp/>
> > > </target>
> > > srcdir = "${src}"
> > > deprecation = "on"
> > > </javac>
> > > </target>
> > > Thanks in advance!
> > > /Mathias Ohlsson
FUDForum. Page generated in 0.02701 seconds
