| Parameterized vararg match problem [message #56077] |
Sat, 27 August 2005 21:44  |
The pointcut in the example below is not applied.
public class Test1<E> {
public void method1(E...args) {
public aspect TestAspect {
after(Test1 test1, Object[] arg) returning: execution(*
Test1.method1(Object...)) && target(test1) && args(arg) {
System.out.println("got here");
If I remove vararg from the pointcut declaration (below) then the pointcut
is applied ok.
after(Test1 test1) returning: execution(* Test1.method1(Object...)) &&
target(test1) {
Is there something wrong with the declaration or is it a bug?
I am using AJDT M3.
Roman
| Re: Parameterized vararg match problem [message #56311 is a reply to message #56157] |
Tue, 30 August 2005 20:19  |
https://bugs.eclipse.org/bugs/show_bug.cgi?id=108437
Roman
"Adrian Colyer" <adrian_colyer@uk.ibm.com> wrote in message
news:df220a$b4h$1@news.eclipse.org...
> Roman Kishchenko wrote:
> I confirm I can reproduce this bug. It only occurs when the vararg type is
> a type parameter (ie. if you change the definition of method1 to take an
> (Object... args) parameter then the matching works as expected.
> Please raise a bug report and I'll get this fixed for you.
> Thks, Adrian.
| Re: Parameterized vararg match problem [message #589937 is a reply to message #56077] |
Tue, 30 August 2005 12:37  |
is a type parameter (ie. if you change the definition of method1 to take
an (Object... args) parameter then the matching works as expected.
Thks, Adrian.
| Re: Parameterized vararg match problem [message #589954 is a reply to message #56157] |
Roman
> Thks, Adrian.
FUDForum. Page generated in 0.35580 seconds
