Home » Eclipse Projects » GEF » Make Label to have several editable parts?
| Make Label to have several editable parts? [message #56035] |
Sat, 18 January 2003 14:58  |
Thanks. I try this, but the getLocation() always return me the *SAME*
co-ordinate regardless where I click on the label.
Here is what I did:
- create a new LocationEditManager and in its createDirectEditRequest(),
copy the location from the incoming directEditRequest to this new Direct
edit request that it is going to create.
protected DirectEditRequest createDirectEditRequest(){
DirectEditRequest req = new DirectEditRequest();
if (request != null){
req.setLocation(incomingDirectEditRequest.getLocation());
req.setCellEditor(getCellEditor());
return req;
- create a new DirectEditPolicy, I print out the location of the request:
But the location is ALWAYS the same, regardless where I click the label:
protected void showCurrentEditValue(DirectEditRequest request) {
System.out.println ("showCurrentEditValue x:" + request.getLocation().x + "
y:" + request.getLocation().y);
LogicSubpart host =
(LogicSubpart)((AbstractGraphicalEditPart)getHost()).getMode l();
- in my editPart, I install this new direct edit policy and create my new
directEditManager when necessary.
Could you please if I miss anything? What I want to do is I have a label
looks like this "XX / MM / YY", if user clicks between the beginning of the
label to the first "/", I only pops up "XX". Same thing if user clicks
between the first "/" and the last "/", only "MM" will pop up.
Thanks for any help.
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:b09ncg$hvk$1@rogue.oti.com...
> Yes, DirectEditRequest is now a subclass of LocationRequest.
> Eric
> Hal wrote:
> > Hi,
> > Couple months ago I post a message about how to make label to have
several
> > editable parts. Randy Hudson, that can be done if a simple change is
made in
> > GEF. Would you please tell me if that change is in the latest build?
> > Thank you.
> > Subject: Re: Make Label to have serval editable parts?
> > From: hudsonr@us.eye-bee-em.com (Randy Hudson)
> > Newsgroups: eclipse.tools.gef
> > Organization: EclipseCorner
> > Date: Oct 09 2002 20:24:13
> > If we make a simple change in GEF (SelectEditPartTracker), Hal could use
> > this figure with a single editpart. The change would be to make "direct
> > edit" a LocationRequest. Hal could just take the Request and compare
its
> > location to the location of the 3 labels.
> > However, both of these solution only work with the mouse. You would
still
> > have to figure out how to switch between the 3 CellEditors with the
> > keyboard.
> >>>public void performRequest(Request request) {
> >>>if (request.getType() == RequestConstants.REQ_DIRECT_EDIT) {
> > Point where = ((LocationRequest)request).getLocation(); //Returns
the
> > location on the Canvas
> > getMonthLabel().translateToRelative(where); //You could use any of
the
> > 3 labels for this translation
> > if (getMonthLabel().containsPoint(where)){
> > performMonthDirectEdit();
> > } else if ...
> > //etc.
| Re: Make Label to have several editable parts? [message #56065 is a reply to message #56035] |
Sat, 18 January 2003 16:23   |
Hal,
Direct edit happens during SelectEditPartTracker.performDirectEdit(), which calls
performRequest(Request) on your EditPart. The location I printed out in this method changed when I
clicked on different places on the LogicLabel. Is this where you're getting the incoming request?
Are you creating a new manager for each direct edit or are you caching the manager somewhere in
between direct edits? Try stepping through the performRequest(Request) in your EditPart and make
sure the location is being updated properly in your DirectEditManager.
Hope this helps.
Eric
> Here is what I did:
> return req;
> LogicSubpart host =
>>Eric
>>Hal wrote:
>>>Hi,
> several
> made in
>>>Thank you.
> its
> still
>>>keyboard.
> the
> the
>>> } else if ...
>>> //etc.
| Re: Make Label to have several editable parts? [message #56092 is a reply to message #56065] |
Sat, 18 January 2003 17:39   |
Thanks, I will try that.
Another question that I have is the co-ordinate I get is absolute, how can
I get it with respective to the beginning of the label?
news:b0cfjh$hdp$1@rogue.oti.com...
> Hal,
which calls
> Hope this helps.
> Eric
> > Here is what I did:
> > return req;
request:
> > LogicSubpart host =
new
the
> >>Eric
> >>Hal wrote:
> >>>Hi,
> > several
> > made in
> >>>Thank you.
use
"direct
> > its
> > still
> >>>keyboard.
> > the
> > the
> >>> } else if ...
> >>> //etc.
| Re: Make Label to have several editable parts? [message #56169 is a reply to message #56092] |
Sun, 19 January 2003 02:08   |
Calling label.translateToRelative(point) will give you that point relative to the label's coordinate
system.
>>Hal,
> which calls
>>Hope this helps.
>>Eric
>>>Here is what I did:
>>>return req;
> request:
>>>LogicSubpart host =
> new
> the
>>>>Eric
>>>>Hal wrote:
>>>>>Hi,
>>>several
>>>made in
>>>>>Thank you.
> use
> "direct
>>>its
>>>still
>>>>>keyboard.
>>>the
>>>the
>>>>> } else if ...
>>>>> //etc.
| Re: Make Label to have several editable parts? [message #57944 is a reply to message #56169] |
Fri, 24 January 2003 17:11   |
Eric,
Thanks for your response.
I print out the value of the co-ordinate of the request location (before and
after calling translateToRelative()),
but I don't understand is why X is 39 and Y is 27 after I
translateToRelative()? From the 3rd result, the width of the host is 24 and
height is 13, so X should be 0 < x < 24 and Y should be 0 < y < 13 right?
how come x is 39 and y is 27?
Before x:188 y:163
After x:39 y:27
host.x:0 host.y:0 host.width:24 host.height:13
<< the code>>
Point location = request.getLocation();
System.out.println ("Before x:" + location.x + " y:" + location.y);
LogicSubpart host =
IFigure figure = ((AbstractGraphicalEditPart)getHost()).getFigure();
figure.translateToRelative(location);
System.out.println ("After x:" + location.x + " y:" + location.y);
System.out.println (" host.x:" + host.getLocation().x + " host.y:" +
host.getLocation().y + " host.width:" + host.getSize().width + "
host.height:" + host.getSize().height);
news:b0dhro$hdp$2@rogue.oti.com...
> system.
can
> >>Hal,
> > which calls
the
in
> >>Hope this helps.
> >>Eric
> >>>Here is what I did:
Direct
> >>>return req;
> > request:
label:
> >>>LogicSubpart host =
> > new
label
> > the
> >>>>Eric
> >>>>Hal wrote:
> >>>>>Hi,
> >>>several
> >>>made in
> >>>>>Thank you.
> > use
> > "direct
> >>>its
> >>>still
> >>>>>keyboard.
> >>>the
of
> >>>the
> >>>>> } else if ...
> >>>>> //etc.
| Re: Make Label to have several editable parts? [message #58972 is a reply to message #57944] |
Tue, 28 January 2003 16:02  |
"Relative" in Draw2D means that the coordinate is relative to the figure's
bounds, not relative to it's top-left corner. This is because most figures
are positioned in absolute coordinates.
In your case, the figure's bounds were probably at something like x = 20, so
0 <= (39-20) < 24.
"Hal" <otaconss2@hotmail.com> wrote in message
news:b0sci7$olq$1@rogue.oti.com...
> Eric,
and
and
> Before x:188 y:163
> After x:39 y:27
> << the code>>
> LogicSubpart host =
relative
> > system.
how
> can
> > >>Hal,
> > > which calls
in
> the
> in
> > >>Hope this helps.
> > >>Eric
> > >>>Here is what I did:
> Direct
> > >>>return req;
> > > request:
> label:
> > >>>LogicSubpart host =
> > > new
> label
of
> > > the
clicks
> > >>>>Eric
> > >>>>Hal wrote:
> > >>>>>Hi,
> > >>>several
is
> > >>>made in
build?
> > >>>>>Thank you.
could
> > > use
> > > "direct
compare
> > >>>its
would
> > >>>still
> > >>>>>keyboard.
//Returns
> > >>>the
> of
> > >>>the
> > >>>>> } else if ...
> > >>>>> //etc.
Current Time: Fri Nov 07 16:51:38 EST 2025
Powered by FUDForum. Page generated in 0.04539 seconds
