| How to debug an around() advice? [message #55972] |
Thu, 11 August 2005 15:02  |
I followed the instructions, my main method is in a class so I'm trying
to debug like a normal Java App, I can see the 'advised by' in the
editor but I can't get to the aroud() advise breakpoint.
| Re: How to debug an around() advice? [message #58570 is a reply to message #56000] |
Wed, 16 November 2005 11:17  |
Adrian Colyer wrote:
>> trying to debug like a normal Java App, I can see the 'advised by' in
>> the editor but I can't get to the aroud() advise breakpoint.
> If around advice is inlined, the debugger can't figure out what to do
> (we still have some JSR 45 related work to do in this area, and possibly
> so does the Eclipse debugger). To debug around advice, you also need to
> go to the project properties and turn off the "inline around advice"
> AspectJ compiler option. Debugging should then hopefully work as
> expected...
How do I set this option using the <iajc> ant task?
| Re: How to debug an around() advice? [message #589867 is a reply to message #55972] |
Fri, 12 August 2005 04:12  |
expected...
| Re: How to debug an around() advice? [message #590902 is a reply to message #56000] |
> expected...
FUDForum. Page generated in 0.04964 seconds
