Running EMFT Transaction Standalone [message #55969] |
Mon, 02 October 2006 23:40  |
I have trouble with getting EMFT Transaction running outside Eclipse.
The class initialization of the org.eclipse.emf.transaction.util.Lock
throws an exception of null access (I am running it on .NET and the
exception text does not say much more than this).
It seems that the problem is with the code
EMFTransactionPlugin.getPluginId().
Two questions:
(1) Should I expect that running Transaction outside Eclipse is
possible?
(2) Would it make sense to eliminate the dependencies on
EMFTransactionPlugin for the Lock class?
\Mario
More Info:
- Running on .NET using IKVM and GNU.Classpath
- EMF and EMF.Edit are running stand-alone on my setup with no
problems.
- Using Transaction 1.0.0.v200606261303
- Using emf 2.2.1.v200609210005
- I can get valid EditingDomain, CommandStack and Runnable
instantiated. The exception occurs as soon as I try to runExclusive()
a command.
Re: Running EMFT Transaction Standalone [message #56377 is a reply to message #56236] |
Wed, 04 October 2006 01:32  |
Hi Christian,
Thanks for the info. I will plan accordingly.
\Mario
On Tue, 03 Oct 2006 17:45:30 -0400, "Christian W. Damus"
<cdamus@ca.ibm.com> wrote:
>Hi, Mario,
>The EMFT Transaction API currently is heavily dependent on Eclipse, as is
>the EMFT Validation component that it depends on for transaction validation
>(commit). These components both use Eclipse capabilities such as extension
>points and plug-ins, as well as numerous APIs such as IStatus that are
>defined by the Eclipse platform.
>There is currently no plan to provide an Eclipse-free transaction or
>validation API.
>Cheers,
>Christian
Re: Running EMFT Transaction Standalone [message #593507 is a reply to message #55969] |
Tue, 03 October 2006 17:45  |
Hi, Mario,
validation API.
Christian
Mario Fortier wrote:
> Two questions:
> possible?
> \Mario
> More Info:
> problems.
> a command.
Re: Running EMFT Transaction Standalone [message #593537 is a reply to message #56236] |
Hi Christian,
\Mario
>Hi, Mario,
>validation API.
>Cheers,
>Christian
FUDForum. Page generated in 0.02963 seconds
