Re: Running EMFT Transaction Standalone [message #56236 is a reply to message #55969] |
Tue, 03 October 2006 21:45 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi, Mario,
The EMFT Transaction API currently is heavily dependent on Eclipse, as is
the EMFT Validation component that it depends on for transaction validation
(commit). These components both use Eclipse capabilities such as extension
points and plug-ins, as well as numerous APIs such as IStatus that are
defined by the Eclipse platform.
There is currently no plan to provide an Eclipse-free transaction or
validation API.
Christian
Mario Fortier wrote:
> I have trouble with getting EMFT Transaction running outside Eclipse.
> The class initialization of the org.eclipse.emf.transaction.util.Lock
> throws an exception of null access (I am running it on .NET and the
> exception text does not say much more than this).
> It seems that the problem is with the code
> EMFTransactionPlugin.getPluginId().
> Two questions:
> (1) Should I expect that running Transaction outside Eclipse is
> possible?
> (2) Would it make sense to eliminate the dependencies on
> EMFTransactionPlugin for the Lock class?
> \Mario
> More Info:
> - Running on .NET using IKVM and GNU.Classpath
> - EMF and EMF.Edit are running stand-alone on my setup with no
> problems.
> - Using Transaction 1.0.0.v200606261303
> - Using emf 2.2.1.v200609210005
> - I can get valid EditingDomain, CommandStack and Runnable
> instantiated. The exception occurs as soon as I try to runExclusive()
> a command.
Re: Running EMFT Transaction Standalone [message #56377 is a reply to message #56236] |
Wed, 04 October 2006 05:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Mario Fortier![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=mfortier%40ta-lib.org) Messages: 5 Registered: July 2009 |
Junior Member |
Hi Christian,
Thanks for the info. I will plan accordingly.
\Mario
On Tue, 03 Oct 2006 17:45:30 -0400, "Christian W. Damus"
<cdamus@ca.ibm.com> wrote:
>Hi, Mario,
>validation API.
>Cheers,
>Christian
Re: Running EMFT Transaction Standalone [message #593507 is a reply to message #55969] |
Tue, 03 October 2006 21:45 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi, Mario,
validation API.
Christian
> Two questions:
> possible?
> \Mario
> More Info:
> problems.
> a command.
Re: Running EMFT Transaction Standalone [message #593537 is a reply to message #56236] |
Junior Member |
Hi Christian,
\Mario
>Hi, Mario,
>validation API.
>Cheers,
>Christian
FUDForum. Page generated in 0.02808 seconds
