VE shows "IWAV0170I Connection creation failed" when trying to load/show a frame [message #55958] |
Fri, 13 August 2004 05:07  |
Originally posted by: ab2248.gmx.de
I have installed
- eclipse-SDK-3.0-win32.zip
- 3.139.406 emf-sdo-runtime-2.0.0.zip
- GEF-runtime-3.0.zip
- VE-runtime-1.0M2.zip
and I'm trying to create a simple AWT Frame. The source code is
correctly shown by the editor.
Then javaw.exe tries to access the internet (Why is that?), as
my firewall shows. After giving permission I get the error:
Visual Editor for Java Error
Error trying to set a new file into the editor.
Reason:
IWAV0171E Could not create a socket connection to remote vm.
The .log file shows:
java.lang.RuntimeException: IWAV0170I Connection creation failed.
java.lang.IllegalStateException: IWAV0171E Could not create a socket connection to remote vm.
It might be a simple newbie mistake. Can you help me? :-)
Albrecht
Re: VE shows "IWAV0170I Connection creation failed" when trying to load/show a frame [message #70531 is a reply to message #56041] |
Tue, 09 November 2004 04:33  |
Originally posted by: crafterm.managesoft.com
Hi Jeff,
Thanks for the tip - that fixed it up for me as well. I was under Linux
though, and was running Eclipse through a socks proxy.
All working well now.
Marcus
Jeff wrote:
>>The Visual Editor needs to create a network connection to localhost
>>(127.0.0.1) in order to communicate with the remote virtual machines
>>used for beaninfo introspection and the graphical presentation of the
>>visual class being edited. Firewalls can cause problems with this
>>connection. Try disabling your firewall and see if it works. If you're
>>able to work with the VE with your firewall disabled, try to configure
>>your firewall to allow a Java to make a connection to the local machine.
>> - Jeff
Re: VE shows "IWAV0170I Connection creation failed" when trying to load/show a frame [message #597301 is a reply to message #55958] |
Fri, 13 August 2004 07:16  |
Albrecht wrote:
<snip>
> Reason:
> Albrecht
- Jeff
Re: VE shows "IWAV0170I Connection creation failed" when trying to load/show a frame [message #597310 is a reply to message #56014] |
Fri, 13 August 2004 08:00  |
Your suggestion met the problem, it works now. Thanks a lot! :-)
Albrecht
> - Jeff
> > Reason:
> > Albrecht
Re: VE shows "IWAV0170I Connection creation failed" when trying to load/show a frame [message #602791 is a reply to message #56041] |
Hi Jeff,
Marcus
>> - Jeff
FUDForum. Page generated in 0.49732 seconds
