Home » Language IDEs » C / C++ IDE (CDT) » problem with step over debugging
problem with step over debugging [message #55915] Wed, 01 January 2003 08:26 Go to next message
Originally posted by: javacard.hotmail.com
I'm using 'cdt-200212181146-win32_1.0.1.bin.dist.zip'.Currently CDT can
work when I compile code,run code.But once I launch debugging session
after I set breakpoint,the 'step in/over/return' button's color turns
grey.Actually I can't use any functionalities in debugging mode,for
instance:there's nothing in variables/memory/expressions views.
I just make the helloworld program as my test case,still failed.Does it
mean CDT gets problems with GDB?I've upgraded the default GDB of minGW
into GDB v5.2.1 already.
thanks a lot in advance.
xusoo
Re: problem with step over debugging [message #55948 is a reply to message #55915] Wed, 01 January 2003 08:39 Go to previous messageGo to next message
and more,I've set '-g' option already,but still failure.
After i terminate the debugging session,the 'stepping arrow' is still
there in source editor.
regards,
xusoo
xusoo wrote:
> xusoo
Re: problem with step over debugging [message #55966 is a reply to message #55915] Wed, 01 January 2003 15:05 Go to previous messageGo to next message
Originally posted by: mikhailkhod.rogers.com
"xusoo" <javacard@hotmail.com> wrote in message
news:auuqai$k9b$1@rogue.oti.com...
Can you describe what you see in the Launch view?
The availability of the debugger's menu options depend on the item currently
selected in the Launch view. The 'step' options are available only for
threads or stack frames.
The variables view displays the content of the currently selected stack
frame. If no stack frame is selected it is empty.
To add an expression to the Expression view use the 'Add C/C++ Expression'
option of the editor's context menu. It is enabled only if your debug
session is running.
> xusoo
Mikhail
Re: problem with step over debugging [message #56069 is a reply to message #55966] Wed, 01 January 2003 23:47 Go to previous messageGo to next message
Mikhail Khodjaiants wrote:
> > Hi,
> session is running.
there's only three lines in the launch view:
+--Helloworld Program[C/C++ local]
+--GDB Debugger(1/2/03 12:51 PM)
+--d:\workspace\testdrv.exe(1/2/03 12:51 PM)
no matter which one I select,the step is not available.Then I try minGW's
gdb,and steping/printing variable is successful in the command line.That's
why i think maybe it's problem between Eclipse's debugger and GDB.
> > xusoo
> Mikhail
thanks
xusoo
Re: problem with step over debugging [message #56096 is a reply to message #56069] Thu, 02 January 2003 11:43 Go to previous messageGo to next message
news:av0g9b$662$1@rogue.oti.com...
> > Hi,
> > > Hi,
can
currently
Expression'
> > session is running.
Is the 'Show Debugger Console' option of the Launch view context menu
enabled? If so, check it and the console will show the output from gdb.
Check also the '.log' file. It is located in <Eclipse
directory>\workspace\.metadata.
it
> > > xusoo
> > Mikhail
> thanks
> xusoo
Re: problem with step over debugging [message #56122 is a reply to message #56096] Thu, 02 January 2003 14:05 Go to previous messageGo to next message
Originally posted by: bangham.neocera.com
I'm wrestling with this same problem - where is the "Launch View"? it is not
listed under my Window->Show View message bar.
thanks, mike
"Mikhail Khodjaiants" <mikhailk@qnx.com> wrote in message
news:av1pfd$ob5$1@rogue.oti.com...
> > Hi,
> > > Hi,
> > > > Hi,
CDT
> can
session
turns
> currently
stack
> Expression'
> > > session is running.
minGW's
line.That's
failed.Does
> it
minGW
> > > > xusoo
> > > Mikhail
> > thanks
> > Regards,
> > xusoo
Re: problem with step over debugging [message #56148 is a reply to message #56122] Thu, 02 January 2003 14:22 Go to previous messageGo to next message
"Michael" <bangham@neocera.com> wrote in message
news:av21qd$tal$1@rogue.oti.com...
not
It's the 'Debug' view. 'LaunchView' is the name of the class that implements
this view. Sorry for that.
> thanks, mike
> > > Hi,
> > > > Hi,
> > > > > Hi,
> CDT
> > can
> session
> turns
mode,for
> > currently
for
> stack
> > Expression'
debug
> > > > session is running.
> minGW's
> line.That's
> failed.Does
> > it
> minGW
> > > > > xusoo
> > > > Mikhail
> > > thanks
> > > Regards,
> > > xusoo
Re: problem with step over debugging [message #56171 is a reply to message #56148] Thu, 02 January 2003 14:51 Go to previous messageGo to next message
The "show debugger console" option is also disabled. My log file has the
following entry:
!ENTRY org.eclipse.cdt.launch 4 150 Dec 27, 2002 17:32:37.359
!MESSAGE Failed Launching CDI Debugger : No symbol "auto" in current
context.
!STACK 0
org.eclipse.cdt.debug.mi.core.cdi.MI2CDIException: No symbol "auto" in
current context.
org.eclipse.cdt.debug.mi.core.cdi.SourceManager.setAutoSolib (SourceManager.j
ava:100)
org.eclipse.cdt.debug.mi.core.GDBDebugger.initializeLibrarie s(GDBDebugger.ja
va:28)
org.eclipse.cdt.debug.mi.core.GDBDebugger.createLaunchSessio n(GDBDebugger.ja
va:44)
org.eclipse.cdt.debug.mi.core.CygwinGDBDebugger.createLaunch Session(CygwinGD
BDebugger.java:29)
org.eclipse.cdt.launch.internal.LocalCLaunchConfigurationDel egate.launch(Loc
alCLaunchConfigurationDelegate.java:84)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfigurati
on.java:136)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationDialog
$10.run(LaunchConfigurationDialog.java:2299)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext
..java:98)
Thanks, Mike
news:av22pl$b23$1@rogue.oti.com...
> not
implements
> > thanks, mike
> > > > Hi,
> > > > > Hi,
> > > > > > Hi,
> > > > > > I'm using
> > CDT
> > > can
> > session
> > turns
> mode,for
> > > currently
> for
> > stack
> > > Expression'
> debug
> > > > > session is running.
> > minGW's
> > line.That's
gdb.
> > failed.Does
> > > it
> > minGW
> > > > > > xusoo
> > > > > Mikhail
> > > > thanks
> > > > Regards,
> > > > xusoo
Re: problem with step over debugging [message #56192 is a reply to message #56171] Thu, 02 January 2003 15:33 Go to previous messageGo to next message
Can you check if the 'Load shared library symbols automatically' option is
set? Open the launch configuration page and select the 'Debugger' tab.
news:av24gu$23o$1@rogue.oti.com...
> following entry:
> context.
> !STACK 0
> current context.
> at
> ava:100)
> at
> va:28)
> at
> va:44)
> at
> BDebugger.java:29)
> at
> at
> on.java:136)
> at
> at
> .java:98)
> Thanks, Mike
is
> > not
> implements
> > > thanks, mike
> > > > > Hi,
> > > > > > Hi,
> > > > > > > Hi,
> > > > > > > I'm using
> > > CDT
> > > > can
> > > session
color
> > > turns
> > mode,for
views.
item
> > > > currently
only
> > for
selected
> > > stack
> > > > Expression'
> > debug
> > > > > > session is running.
> > > minGW's
> > > line.That's
menu
> gdb.
> > > failed.Does
> > > > it
of
> > > minGW
> > > > > > > xusoo
> > > > > > Mikhail
> > > > > thanks
> > > > > Regards,
> > > > > xusoo
Re: problem with step over debugging [message #56291 is a reply to message #56171] Thu, 02 January 2003 15:43 Go to previous messageGo to next message
Please, try this:
1. start gdb with '-i mi' option
2. type '-gdb-set auto-solib-add off' and press Enter
> following entry:
> context.
> !STACK 0
> current context.
> at
> ava:100)
> at
> va:28)
> at
> va:44)
> at
> BDebugger.java:29)
> at
> at
> on.java:136)
> at
> at
> .java:98)
> Thanks, Mike
is
> > not
> implements
> > > thanks, mike
> > > > > Hi,
> > > > > > Hi,
> > > > > > > Hi,
> > > > > > > I'm using
> > > CDT
> > > > can
> > > session
color
> > > turns
> > mode,for
views.
item
> > > > currently
only
> > for
selected
> > > stack
> > > > Expression'
> > debug
> > > > > > session is running.
> > > minGW's
> > > line.That's
menu
> gdb.
> > > failed.Does
> > > > it
of
> > > minGW
> > > > > > > xusoo
> > > > > > Mikhail
> > > > > thanks
> > > > > Regards,
> > > > > xusoo
Re: problem with step over debugging [message #56322 is a reply to message #56192] Thu, 02 January 2003 19:18 Go to previous messageGo to next message
It is not checked - if I check it, an exception is raised "no symbol auto in
current context"
news:av26uo$rc5$1@rogue.oti.com...
the
> > following entry:
> > context.
> > !STACK 0
> > current context.
> > at
> > ava:100)
> > at
> > va:28)
> > at
> > va:44)
> > at
> > BDebugger.java:29)
> > at
> > at
> > on.java:136)
> > at
> > at
> > .java:98)
> > Thanks, Mike
it
> is
> > > not
> > implements
> > > > thanks, mike
> > > > > > Hi,
> > > > > > > Hi,
> > > > > > > > Hi,
> > > > > > > > I'm using
> > > > CDT
> > > > > can
debugging
> > > > session
> color
> > > > turns
> > > mode,for
> views.
> item
> > > > > currently
> only
> > > for
> selected
> > > > stack
> > > > > Expression'
your
> > > debug
> > > > > > > session is running.
try
> > > > minGW's
> > > > line.That's
GDB.
> menu
> > gdb.
> > > > failed.Does
> > > > > it
GDB
> of
> > > > minGW
> > > > > > > > xusoo
> > > > > > > Mikhail
> > > > > > thanks
> > > > > > Regards,
> > > > > > xusoo
Re: problem with step over debugging [message #56338 is a reply to message #56291] Thu, 02 January 2003 19:20 Go to previous messageGo to next message
The response is:
&"Not symbol table is loaded. Use the \"file\" command. \n"
news:av27gu$rob$1@rogue.oti.com...
> Please, try this:
the
> > following entry:
> > context.
> > !STACK 0
> > current context.
> > at
> > ava:100)
> > at
> > va:28)
> > at
> > va:44)
> > at
> > BDebugger.java:29)
> > at
> > at
> > on.java:136)
> > at
> > at
> > .java:98)
> > Thanks, Mike
it
> is
> > > not
> > implements
> > > > thanks, mike
> > > > > > Hi,
> > > > > > > Hi,
> > > > > > > > Hi,
> > > > > > > > I'm using
> > > > CDT
> > > > > can
debugging
> > > > session
> color
> > > > turns
> > > mode,for
> views.
> item
> > > > > currently
> only
> > > for
> selected
> > > > stack
> > > > > Expression'
your
> > > debug
> > > > > > > session is running.
try
> > > > minGW's
> > > > line.That's
GDB.
> menu
> > gdb.
> > > > failed.Does
> > > > > it
GDB
> of
> > > > minGW
> > > > > > > > xusoo
> > > > > > > Mikhail
> > > > > > thanks
> > > > > > Regards,
> > > > > > xusoo
Re: problem with step over debugging [message #56396 is a reply to message #56291] Fri, 03 January 2003 03:48 Go to previous messageGo to next message
same phenomena as yours,waiting for response.
regards,
xusoo
> Please, try this:
> > following entry:
> > context.
> > !STACK 0
> > current context.
> > at
> > ava:100)
> > at
> > va:28)
> > at
> > va:44)
> > at
> > BDebugger.java:29)
> > at
> > at
> > on.java:136)
> > at
> > at
> > .java:98)
> > Thanks, Mike
> is
> > > not
> > implements
> > > > thanks, mike
> > > > > > Hi,
> > > > > > > Hi,
> > > > > > > > Hi,
> > > > > > > > I'm using
> > > > CDT
> > > > > can
> > > > session
> color
> > > > turns
> > > mode,for
> views.
> item
> > > > > currently
> only
> > > for
> selected
> > > > stack
> > > > > Expression'
> > > debug
> > > > > > > session is running.
> > > > minGW's
> > > > line.That's
> menu
> > gdb.
> > > > failed.Does
> > > > > it
> of
> > > > minGW
> > > > > > > > xusoo
> > > > > > > Mikhail
> > > > > > thanks
> > > > > > Regards,
> > > > > > xusoo
Re: problem with step over debugging [message #56504 is a reply to message #56322] Fri, 03 January 2003 11:23 Go to previous messageGo to next message
news:av2k66$2rc$1@rogue.oti.com...
in
> current context"
What happens if it's unchecked? As I see from the trace the debugger calls
setAutoSolib(). It is possible that minGW doesn't support this feature.
is
> the
> > > following entry:
> > > context.
> > > !STACK 0
> > > current context.
> > > at
> > > ava:100)
> > > at
> > > va:28)
> > > at
> > > va:44)
> > > at
> > > BDebugger.java:29)
> > > at
> > > at
> > > on.java:136)
> > > at
> > > at
> > > .java:98)
> > > Thanks, Mike
> it
> > is
> > > > not
> > > implements
> > > > > thanks, mike
> > > > > > > Hi,
> > > > > > > > Hi,
> > > > > > > > > Hi,
> > > > > > > > > I'm using
> > > > > CDT
> > > > > > can
> debugging
> > > > > session
> > color
> > > > > turns
> > > > mode,for
> > views.
the
> > item
> > > > > > currently
available
> > only
> > > > for
> > selected
> > > > > stack
C/C++
> > > > > > Expression'
> your
> > > > debug
> > > > > > > > session is running.
> try
> > > > > minGW's
> > > > > line.That's
> GDB.
> > menu
from
> > > gdb.
> > > > > failed.Does
> > > > > > it
> GDB
> > of
> > > > > minGW
> > > > > > > > > xusoo
> > > > > > > > Mikhail
> > > > > > > thanks
> > > > > > > Regards,
> > > > > > > xusoo
Re: problem with step over debugging [message #56533 is a reply to message #56504] Fri, 03 January 2003 13:17 Go to previous message
Is there any type of documentation that describes how to get gdb, gcc and
eclipse to work well together? I tried Cygwin because that was recommended
in a previous post. I'm running Win2K - surely, this is an often used
combination that many others have gotten to work?
Thanks, Mike
news:av4cku$u1r$1@rogue.oti.com...
auto
> in
> > current context"
option
> is
has
> > the
> > > > following entry:
> > > > context.
> > > > !STACK 0
in
> > > > current context.
> > > > at
> > > > ava:100)
> > > > at
> > > > va:28)
> > > > at
> > > > va:44)
> > > > at
> > > > BDebugger.java:29)
> > > > at
> > > > at
> > > > on.java:136)
> > > > at
> > > > at
> > > > .java:98)
> > > > Thanks, Mike
View"?
> > it
> > > is
> > > > > not
> > > > implements
> > > > > > thanks, mike
> > > > > > > > Hi,
> > > > > > > > > Hi,
> > > > > > > > > > Hi,
> > > > > > > > > > I'm using
> > > > > > CDT
> > > > > > > can
> > debugging
> > > > > > session
button's
> > > color
> > > > > > turns
debugging
> > > > > mode,for
> > > views.
> the
> > > item
> > > > > > > currently
> available
> > > only
> > > > > for
> > > selected
> > > > > > stack
> C/C++
> > > > > > > Expression'
> > your
> > > > > debug
> > > > > > > > > session is running.
I
> > try
> > > > > > minGW's
command
> > > > > > line.That's
and
> > GDB.
context
> > > menu
> from
> > > > gdb.
case,still
> > > > > > failed.Does
> > > > > > > it
default
> > GDB
> > > of
> > > > > > minGW
> > > > > > > > > > xusoo
> > > > > > > > > Mikhail
> > > > > > > > thanks
> > > > > > > > Regards,
> > > > > > > > xusoo
Previous Topic:Using CDT for PalmOS Development
Next Topic:makefile
Current Time: Thu Nov 06 10:19:16 EST 2025
Powered by FUDForum. Page generated in 0.06269 seconds
