Home » Archived » BPMN Modeler » Re: Attach timer event to activity - is it possible ?
Re: Attach timer event to activity - is it possible ? [message #4990] Tue, 30 December 2008 04:43 Go to next message
Originally posted by: atoulme.intalio.com
Hi Sara, this is not supported at the moment. You can simulate it by
adding a subprocess that you collapse to get the same effect.
Antoine
Sara wrote:
> Is anybody know is possible attach event (specially timer event) to
> activity (task) in Eclipse BPMN modeler ? I want to paint situation like
> „if the activity doesn't be finished in 5 minutes then the
> activity will be break and process go using another flow”.
> I have the latest version of Ganymede with SOA Tools. When I try to
> (attach) put event to activity BPMN modeler doesn't allow me to do it.
> When I pull the event on activity then event stay 1 centimetre from
> activity and background of cursor is red. Maybe somebody know how I can
> paint situation like I wrote above?
> Thank you for any help.
> Best regards,
> Sara
Re: Attach timer event to activity - is it possible ? [message #5056 is a reply to message #4990] Tue, 30 December 2008 05:33 Go to previous messageGo to next message
Hi Antoine,
Thanks for your replay.
I have to paint 4 different flow from one task (default flow, flow as a
result of timer break, 2 conditional flow). I have never use a subprocess
in situation like that so I haven't got any idea how I can do it using
subprocess (I can't attach event to subprocess). Maybe some suggestion ?
Sara
Re: Attach timer event to activity - is it possible ? [message #5124 is a reply to message #5056] Tue, 30 December 2008 05:50 Go to previous messageGo to next message
You can attach an event on the bottom border of a subprocess.
Antoine
Sara wrote:
> Hi Antoine,
> Thanks for your replay. I have to paint 4 different flow from one task
> (default flow, flow as a result of timer break, 2 conditional flow). I
> have never use a subprocess in situation like that so I haven't got any
> idea how I can do it using subprocess (I can't attach event to
> Best regards,
> Sara
Re: Attach timer event to activity - is it possible ? [message #5193 is a reply to message #5124] Tue, 30 December 2008 06:20 Go to previous message
Thanks for help ;)
Sara
Previous Topic:Task with an Intermediate Event attached to its boundary
Next Topic:Re: Use Error intermediate event ?
Current Time: Thu Mar 13 13:20:35 EDT 2025
Powered by FUDForum. Page generated in 0.03638 seconds
