E3.1 M6 - Suse Linux & Font Size [message #55789] |
Wed, 20 April 2005 19:37 |
Originally posted by: an.nym.us
Hi there, I just installed Eclipse on my Linux after using it many times
under Windows.
Now I have the problem, that Serveral Fonts are just tooo BIG.
I could adjust some unter Preferences, but the MainMenu Texts , and texts
in the views themselves (e.g Filenames in the Navigator, Property
attributes in the Properties view) are just to big , where and how can I
adjust them ?
Thanks Sascha
Re: E3.1 M6 - Suse Linux & Font Size [message #56020 is a reply to message #55789] |
Thu, 21 April 2005 09:46 |
Originally posted by: constantin.gruber.change2linux.com
Hi Sascha!
Since you are using SuSE I assume you are using the K Desktop Environment.
Eclipse takes use of the GTK+ - library bindings and hence your Font
settings in KDE are of no affect for GTK+ based programs... ;)
You can change the fonts for any GTK+ programm using the Gnome-Tool
"gnome-font-properties" or using the Tool
"gtk-qt-engine" (http://www.freedesktop.org/Software/gtk-qt) which gives
you an option in your KDE Control Center allowing you to automatically
assign your KDE-Font settings to GTK+-Applications. I think this is the
easiest way for you...
Hope this helps!
Constantin
FUDForum. Page generated in 0.07282 seconds
