[ATL] Problem with an atl rule [message #55751] |
Thu, 02 August 2007 10:46 |
Originally posted by: NewsgroupSPAM.iKupp.de
ive got another problem ;-(
ive got a xml file like
<children xsi:type="Element" name="Document" value="">
<children xsi:type="Element" name="Entity" value="">
<children xsi:type="Element" name="id" value="123"/>
<children xsi:type="Element" name="name" value="my name"/>
<children xsi:type="Element" name="is_a" value="345"/>
</children>
<children xsi:type="Element" name="id" value="345"/>
<children xsi:type="Element" name="name" value="my other name"/>
<children xsi:type="Element" name="is_a" value="789"/>
</children>
</children>
and a target file like
<relation from_id="123" to_id="345" from_name="my name" to_name="my
other name">
but how do i get the to_name value from the other element?
i ve got a rule like:
rule entity{
from i : XML!Element (
i.name='Entity'
)outr0 : relation!relation(
from_id <-i.getvalue('id'),
to_id <-i.getvalue('is_a'),
from_name <-i.getvalue('name'),
to_name <-?????????????
with the helper
helper context XML!Element def : getvalue(finder : String) : String =
if self.children->select(c | c.oclIsKindOf(XML!Element) and
c.name=finder)->size()=0 then '' else self.children->select(c |
c.oclIsKindOf(XML!Element) and c.name=finder)->first().value endif;
Many thanks
Ina
Re: [ATL] Problem with an atl rule [message #55778 is a reply to message #55751] |
Thu, 02 August 2007 11:24 |
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Ina Kupp a écrit :
Hi Ina,
> </children>
> </children>
> </children>
> other name">
> rule entity{
> i.name='Entity'
> with the helper
You can define this helper:
helper def: getEntityNameFromId(entityId : String) : String =
XML!Element.allInstances()->select(e | e.name = 'Entity' and
e.children->select(c | c.name='id' and c.value= entityId)->notEmpty())
->first().children->select(c | c.name='name')->first().value;
And call it like this:
to_name <- getEntityNameFromId(i.getvalue('is_a'))
> Many thanks
> Ina
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] Problem with an atl rule [message #55805 is a reply to message #55778] |
Thu, 02 August 2007 11:25 |
Hugo Bruneliere a écrit :
> Ina Kupp a écrit :
> Hi Ina,
>> </children>
>> </children>
>> </children>
>> other name">
>> rule entity{
>> i.name='Entity'
>> with the helper
> and e.children->select(c | c.name='id' and c.value=
Sorry:
to_name <- thisModule.getEntityNameFromId(i.getvalue('is_a'))
>> Many thanks
>> Ina
> Best regards,
> Hugo
Re: [ATL] Problem with an atl rule [message #55963 is a reply to message #55805] |
Fri, 03 August 2007 13:03 |
>> Ina Kupp a écrit :
>>> Hi,
>> Hi Ina,
>>> </children>
>>> </children>
>>> </children>
>>> other name">
>>> rule entity{
>>> i.name='Entity'
>>> with the helper
> Sorry:
with this helper i get an error if the id isnt found, so i added an if
clause to the helper:
now it works but it isnt very fast.
if XML!Element.allInstances()->select(e | e.name = 'Entity' and
entityId)->notEmpty())->notEmpty()
then XML!Element.allInstances()->select(e | e.name = 'Entity' and
else ''endif;
many thanks for your contemporary help, this helper saved my day ;-)
Ina
Re: [ATL] Problem with an atl rule [message #56023 is a reply to message #55963] |
Fri, 03 August 2007 13:34 |
Originally posted by: quentin.glineur.obeo.fr
--------------080609050208010708070904
Concerning your helper performances, you should try to use a let
statement so that your time consuming request is evaluated only once.
Quentin GLINEUR
Ina Kupp a
Re: [ATL] Problem with an atl rule (solved) [message #56347 is a reply to message #55963] |
Mon, 06 August 2007 08:56 |
Ina Kupp schrieb:
>>> Ina Kupp a écrit :
>>>> Hi,
>>> Hi Ina,
>>>> </children>
>>>> </children>
>>>> </children>
>>>> other name">
>>>> rule entity{
>>>> i.name='Entity'
>>>> with the helper
>> Sorry:
> else ''endif;
> Ina
fyi:
i changed it to this:
helper def: getEntityNameFromId(entityId : String, outname : String,
inname : String) : String =
e.children->select(c | if c.oclIsUndefined() then false else
c.name=inname and c.value= entityId endif)->notEmpty())
->first().children->select(c | if c.oclIsUndefinded() then false
else c.name=outname endif )->first().value;
(the outname and inname are only for being more flexible)
this changed the speed from over 25h (i canceld it after 10h and after
that it needed another 15h to end the process (it seems like it did the
transformation till the end) to 2h. (the input file is only 276KB big)
many thanks for your help
Ina
FUDForum. Page generated in 0.03881 seconds
