Re: Servlet delegate not registered [message #57522 is a reply to message #55763] |
Mon, 05 November 2007 09:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: fappel.innoopract.com
seems as if all necessary bundles have been activated. Are you sure that you
have set the init-param enableFrameworkControls in the web.xml? The RAP
deployment demo contains a web.xml that has that setting commented out.
Because of this the sp_test doesn't work with RAP deployments by default.
For log information you may look at
work\Catalina\localhost\test\eclipse\workspace\.metadata\.lo g
Hope that helps!
Ciao
Frank
"Christian" <zerostress@libero.it> schrieb im Newsbeitrag
news:ffsh7h$5oo$1@build.eclipse.org...
> sorry...this is the correct log from equinox...
> osgi> ss
> Framework is launched.
> id State Bundle
> 0 ACTIVE org.eclipse.osgi_3.3.0.v20070530
> Fragments=37
> 1 ACTIVE javax.servlet_1.0.0.200710261234
> 2 ACTIVE org.eclipse.core.commands_3.3.0.I20070605-0010
> 3 ACTIVE org.eclipse.core.contenttype_3.2.100.v20070319
> 4 ACTIVE org.eclipse.core.expressions_3.3.0.v20070606-0010
> 5 ACTIVE org.eclipse.core.jobs_3.3.0.v20070423
> 6 ACTIVE
> org.eclipse.core.runtime.compatibility.auth_3.2.100.v2007050
> 2
> 7 ACTIVE org.eclipse.core.runtime_3.3.100.v20070530
> 8 ACTIVE org.eclipse.equinox.app_1.0.0.v20070606
> 9 ACTIVE org.eclipse.equinox.common_3.3.0.v20070426
> 10 ACTIVE org.eclipse.equinox.http.registry_1.0.0.200710261234
> 11 ACTIVE
> org.eclipse.equinox.http.servletbridge_1.0.0.200710261234
> 12 ACTIVE org.eclipse.equinox.http.servlet_1.0.0.200710261234
> 13 ACTIVE org.eclipse.equinox.preferences_3.2.100.v20070522
> 14 ACTIVE org.eclipse.equinox.registry_3.3.0.v20070522
> 15 ACTIVE org.eclipse.equinox.servletbridge_1.0.0.200710261234
> 16 ACTIVE org.eclipse.osgi.services_3.1.200.v20070605
> 17 ACTIVE org.eclipse.rap.jface_1.0.0.20071010-2241
> 18 ACTIVE org.eclipse.rap.rwt_1.0.0.20071010-2241
> 19 ACTIVE org.eclipse.rap.ui.workbench_1.0.0.20071010-2241
> 20 ACTIVE org.eclipse.rap.ui_1.0.0.20071010-2241
> 21 ACTIVE org.eclipse.update.configurator_3.2.2.R32x_v20070111
> 22 ACTIVE test_1.0.0
> 37 RESOLVED
> org.eclipse.equinox.servletbridge.extensionbundle_1.0.0
> Master=0
> Help me! :)
> Christian
> christian ha scritto:
>> i've deployed my app under Tomcat. All seems to loads correctly but when
>> i invoke the url http://localhost:9080/test/sp_test the answer is
>> Servlet delegate not registered.
>> below some informations
>> osgi> ss
>> id State Bundle
>> Fragments=36
>> 1 ACTIVE javax.servlet_1.0.0.200710261152
>> 6 ACTIVE
>> 2
>> 10 ACTIVE org.eclipse.equinox.http.registry_1.0.0.200710261152
>> 11 ACTIVE
>> org.eclipse.equinox.http.servletbridge_1.0.0.200710261152
>> 12 ACTIVE org.eclipse.equinox.http.servlet_1.0.0.200710261152
>> 15 ACTIVE org.eclipse.equinox.servletbridge_1.0.0.200710261152
>> 36 RESOLVED
>> Master=0
>> in the folder work\Catalina\localhost\test\eclipse\configuration there
>> is no log file...so there is no error....
>> What's wrong?
>> Thanks
>> Christian
FUDForum. Page generated in 0.03943 seconds
