| When is generated file availible? [message #55522] |
Thu, 15 January 2009 06:30  |
Originally posted by: johannes.nel.gmail.com
I generate a file from a template, then in the next line in my main.jet
I try to access that file from a custom function tag. The resource
writen by the ws:file does seem to be availible (can I refresh the
eclipse file system model from jet (i assume that is the cause) or has
the file not been written to the file system yet?
Johan
| Re: When is generated file availible? [message #55575 is a reply to message #55549] |
Thu, 15 January 2009 09:07   |
Johan:
As you have notices, JET doesn't write files immediately. In fact, it
accumulates all workspace actions until main.jet is complete, then it does
all the actions within a single workspace operation. The main reason for
this is JET can do a single validateEdit call on all files are controlled by
team environments. (Some team environments, including IBM Rational's
ClearCase will prompt you to check out files before writing them - failing
to do a single validateEdit call could result in a check-out prompt for each
file.)
But, that's not answering your question :-)
With the standard tags, there isn't a way for one template to read a file
created by another (simply because all templates have been evaluated before
any file gets written.)
A couple of suggestions:
1) write your own version of ws:file that, instead of defering the write,
writes the file immediately. Depending on what team environment you use (if
any), you may be able to live quite confortably without the delayed writing,
unified validate edit, and single workspace operation.
2) Evaluate your first template and save its result into a JET variable -
you'd need to create a custom tag for this. Then, have your tags in the
second template access the contents from the variable instead of the file
system.
Paul
| Re: When is generated file availible? [message #55628 is a reply to message #55575] |
Fri, 16 January 2009 03:51  |
clearcase, cvs.ok, point taken.
ok, so I am thinking of using a two-time parsing approach. either kick
of a seperate timed thread to invoke the second pass or write a manager
plugin which executes two jet transformations.
I had not considered team enviroments in my regeneration (duh!), thanks
for that timely reminder of that reality (we use svn which makes it much
easier), thanks.
Paul Elder wrote:
> Johan:
> file.)
> system.
> Paul
FUDForum. Page generated in 0.03129 seconds
