Home » Eclipse Projects » Plugin Development Environment (PDE) » p2 director can't find binary,org.eclipse.equinox.executable_root
p2 director can't find binary,org.eclipse.equinox.executable_root [message #55503] |
Thu, 16 April 2009 02:45 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: wbeckwith.gmail.com
The director complains of not finding the
org.eclipse.equinox.executable_root binary @ version
3.3.200.v20090306-1900-7M-FhJFHQfz-5DbTcLIwDaa. Where is this coming
from? Since I'm building a windows product with a windows SDK pointed
at a target with Eclipse 3.5M6 SDK + Eclipse 3.5M6 Delta Pack, there
should be no reason it can't find the executable I imagine.
1.) Where is this org.eclipse.equinox.executable_root
plugin/feature/fragment?
2.) What does the director application used it for?
If I can get those question answered then I can hopefully get a product
actually provisioned.
runDirector:
Project base dir set to: D:\dev\workspace-main\lisa-product.builder\build
[ant] calling target(s) [runDirector] in build file
D:\dev\eclipse-3.5M6\plugins\org.eclipse.pde.build_3.5.0.v20 090312-1500\scripts\genericTargets.xml
parsing buildfile
with URI =
file:/D:/dev/eclipse-3.5M6/plugins/org.eclipse.pde.build_3.5 .0.v20090312-1500/scripts/genericTargets.xml
Override ignored for property "configs"
Override ignored for property "fetchTag"
Override ignored for property "customEESources"
Override ignored for property "transformedRepoLocation"
Override ignored for property "buildingOSGi"
Override ignored for property "generateJnlp"
Override ignored for property "signJars"
Override ignored for property "generateFeatureVersionSuffix"
Override ignored for property "generateVersionsLists"
Override ignored for property "groupConfigurations"
Override ignored for property "pluginPath"
Override ignored for property "filteredDependencyCheck"
Override ignored for property "filterP2Base"
[ant] Entering
D:\dev\eclipse-3.5M6\plugins\org.eclipse.pde.build_3.5.0.v20 090312-1500\scripts\genericTargets.xml...
Build sequence for target(s) `runDirector' is [runDirector]
Complete build sequence is [runDirector, noDefault, transformRepos,
init, assembleElement, processElement, processFlat, gatherLogs,
gatherSources, packageElement, processViaFeature, generateScript,
fetchElement, gatherBinaries, cleanElement, ]
runDirector:
Override ignored for property "p2.director.version"
[java] Executing 'C:\jdk1.5.x\jre\bin\java.exe' with arguments:
[java]
'-Declipse.p2.data.area=D:\dev\workspace-main\lisa-product.b uilder/build/tmp/eclipse/p2'
[java] '-Declipse.p2.MD5Check=false'
[java] '-jar'
[java]
'D:\dev\eclipse-3.5M6\plugins\org.eclipse.equinox.launcher_1 .0.200.v20090306-1900.jar'
[java] '-application'
[java] 'org.eclipse.equinox.p2.director.app.application'
[java] '-nosplash'
[java] '--launcher.suppressErrors'
[java] '-consoleLog'
[java] '-flavor'
[java] 'tooling'
[java] '-installIU'
[java] 'com.itko.lisa.workstation.product'
[java] '-version'
[java] '1.0.0'
[java] '-p2.os'
[java] 'win32'
[java] '-p2.ws'
[java] 'win32'
[java] '-p2.arch'
[java] 'x86'
[java] '-roaming'
[java] '-profile'
[java] 'profile'
[java] '-profileProperties'
[java] 'org.eclipse.update.install.features=true'
[java] '-metadataRepository'
[java]
'file:D:\dev\workspace-main\lisa-product.builder/build/build Repo'
[java] '-artifactRepository'
[java]
[java] '-destination'
[java] 'D:\dev\workspace-main\lisa-product.builder/build/tmp/eclips e'
[java] '-bundlepool'
[java]
[java] The ' characters around the executable and arguments are
[java] not part of the command.
[java] Installing com.itko.lisa.workstation.product 1.0.0.
[java] Installation failed.
[java] !SESSION 2009-04-15 19:10:19.179
[java] eclipse.buildId=I20090313-0100
[java] java.version=1.5.0_17
[java] java.vendor=Sun Microsystems Inc.
[java] BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
[java] Framework arguments: -application
--launcher.suppressErrors -flavor tooling -installIU
com.itko.lisa.workstation.product -version 1.0.0 -p2.os win32 -p2.ws
win32 -p2.arch x86 -roaming -profile profile -profileProperties
org.eclipse.update.install.features=true -metadataRepository
file:D:\dev\workspace-main\lisa-product.builder/build/buildR epo
-artifactRepository
-destination
D:\dev\workspace-main\lisa-product.builder/build/tmp/eclipse -bundlepool
[java] Command-line arguments: -application
--launcher.suppressErrors -consoleLog -flavor tooling -installIU
-artifactRepository
-destination
[java]
[java] !ENTRY org.eclipse.equinox.p2.engine 4 4 2009-04-15
19:10:31.557
[java] !MESSAGE An error occurred while collecting items to be
installed
[java] !SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2009-04-15
19:10:31.557
[java] !MESSAGE session context was:(profile=profile, phase=,
operand=, action=).
[java] !SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 0
2009-04-15 19:10:31.557
[java] !MESSAGE No repository found containing:
binary,org.eclipse.equinox.executable_root,3.3.200.v20090306 -1900-7M-FhJFHQfz-5DbTcLIwDaa
[ant] Exiting
[antcall] Exiting
D:\dev\workspace-main\lisa-product.builder\build\package.org .eclipse.pde.build.container.feature.win32.win32.x86.xml.
[ant] Exiting
[ant] Exiting
D:\dev\workspace-main\lisa-product.builder\customTargets.xml .
[ant] Exiting
D:\dev\workspace-main\lisa-product.builder\build\package.org .eclipse.pde.build.container.feature.all.xml.
[ant] Exiting
[antcall] Exiting
[ant] Exiting
[antcall] Exiting
D:\dev\eclipse-3.5M6\plugins\org.eclipse.pde.build_3.5.0.v20 090312-1500\scripts\productBuild\productBuild.xml.
BUILD FAILED
D:\dev\eclipse-3.5M6\plugins\org.eclipse.pde.build_3.5.0.v20 090312-1500\scripts\productBuild\productBuild.xml:32:
The following error occurred while executing this line:
D:\dev\eclipse-3.5M6\plugins\org.eclipse.pde.build_3.5.0.v20 090312-1500\scripts\build.xml:115:
D:\dev\workspace-main\lisa-product.builder\customTargets.xml :12: The
D:\dev\eclipse-3.5M6\plugins\org.eclipse.pde.build_3.5.0.v20 090312-1500\scripts\productBuild\allElements.xml:10:
D:\dev\eclipse-3.5M6\plugins\org.eclipse.pde.build_3.5.0.v20 090312-1500\scripts\genericTargets.xml:182:
D:\dev\workspace-main\lisa-product.builder\build\package.org .eclipse.pde.build.container.feature.all.xml:23:
D:\dev\workspace-main\lisa-product.builder\build\package.org .eclipse.pde.build.container.feature.all.xml:15:
D:\dev\eclipse-3.5M6\plugins\org.eclipse.pde.build_3.5.0.v20 090312-1500\scripts\productBuild\allElements.xml:44:
D:\dev\workspace-main\lisa-product.builder\build\package.org .eclipse.pde.build.container.feature.win32.win32.x86.xml:89:
D:\dev\workspace-main\lisa-product.builder\build\package.org .eclipse.pde.build.container.feature.win32.win32.x86.xml:766 :
D:\dev\eclipse-3.5M6\plugins\org.eclipse.pde.build_3.5.0.v20 090312-1500\scripts\genericTargets.xml:213:
Java returned: 13
Wb
Re: p2 director can't find binary,org.eclipse.equinox.executable_root [message #56265 is a reply to message #55503] |
Thu, 16 April 2009 20:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Andrew Niefer![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=aniefer%40gmail.com) Messages: 990 Registered: July 2009 |
This is a bug, I raised 272572.
You are probably including the org.eclipse.equinox.executable feature
directly in your product. If you removed it and instead let it be
automatically included, then you will probably be able to install.
-Andrew
> runDirector:
> parsing buildfile
> with URI =
> [ant] Entering
> runDirector:
> [java]
> [java] '-jar'
> [java]
> [java] '-nosplash'
> [java] '-flavor'
> [java] 'tooling'
> [java] '-installIU'
> [java] '-version'
> [java] '1.0.0'
> [java] '-p2.os'
> [java] 'win32'
> [java] '-p2.ws'
> [java] 'win32'
> [java] '-p2.arch'
> [java] 'x86'
> [java] '-roaming'
> [java] '-profile'
> [java] 'profile'
> [java]
> [java]
> [java]
> -artifactRepository
> -destination
> -artifactRepository
> -destination
> [java]
> 19:10:31.557
> installed
> 19:10:31.557
> operand=, action=).
> [ant] Exiting
> [antcall] Exiting
> [ant] Exiting
> [ant] Exiting
> [ant] Exiting
> [ant] Exiting
> [antcall] Exiting
> [ant] Exiting
> [antcall] Exiting
> BUILD FAILED
> Java returned: 13
> Wb
Re: p2 director can't find binary,org.eclipse.equinox.executable_root [message #56324 is a reply to message #56265] |
Thu, 16 April 2009 20:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
BTW, this is a binary artifact.
If you look in
D:\dev\workspace-main\lisa-product.builder/build/buildRepo/b inary
you will should see at least
org.eclipse.equinox.executable_root.win32.win32.x86
-Andrew
> -Andrew
>> product actually provisioned.
>> runDirector:
>> parsing buildfile
>> with URI =
>> [ant] Entering
>> runDirector:
>> [java]
>> [java] '-jar'
>> [java]
>> [java] '-nosplash'
>> [java] '-flavor'
>> [java] 'tooling'
>> [java] '-installIU'
>> [java] '-version'
>> [java] '1.0.0'
>> [java] '-p2.os'
>> [java] 'win32'
>> [java] '-p2.ws'
>> [java] 'win32'
>> [java] '-p2.arch'
>> [java] 'x86'
>> [java] '-roaming'
>> [java] '-profile'
>> [java] 'profile'
>> [java]
>> [java]
>> [java]
>> [java]
>> [java]
>> -artifactRepository
>> -destination
>> -bundlepool D:\dev\workspace-main\lisa-product.builder/build/tmp/eclipse
>> -artifactRepository
>> -destination
>> [java]
>> 19:10:31.557
>> installed
>> 19:10:31.557
>> operand=, action=).
>> [ant] Exiting
>> [antcall] Exiting
>> [ant] Exiting
>> [ant] Exiting
>> [ant] Exiting
>> [ant] Exiting
>> [antcall] Exiting
>> [ant] Exiting
>> [antcall] Exiting
>> BUILD FAILED
>> Java returned: 13
>> Wb
Re: p2 director can't find binary,org.eclipse.equinox.executable_root [message #56719 is a reply to message #56265] |
Fri, 17 April 2009 15:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
That was indeed my issue. Once I removed the inclusion of the
org.eclipse.equinox.feature, then the director application succeeded.
Wb
> -Andrew
Re: p2 director can't find binary,org.eclipse.equinox.executable_root [message #63321 is a reply to message #56265] |
Tue, 26 May 2009 18:33 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Euclides Neto![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=wen014%40motorola.com) Messages: 8 Registered: July 2009 |
Junior Member |
I've just downloaded the Galileo RC2 and tried to build and install my
main feature using director app, and the same issue was raised. I verified
my features and none of them includes org.eclipse.equinox.executable. Can
someone point how to "fix" this issue? Following I'll paste the error log.
-- Euclides
Log:
!SESSION 2009-05-26 14:59:54.770
eclipse.buildId=I20090522-1710
java.version=1.5.0_15
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
org.eclipse.equinox.p2.director.app.application -metadataRepository
file:/components/myproduct/repo -artifactRepository
file:/components/myproduct/repo -installIU my.feature.feature.group
-version 2.2.0 -destination /components/dist/tmp/MyProduct -profile
MyProfile -profileProperties org.eclipse.update.install.features=true
-bundlepool /components/dist/tmp/MyProduct -p2.os win32 -p2.ws win32
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:58.976
!MESSAGE The installable unit
org.eclipse.equinox.executable_root.gtk.solaris.x86 is missing the
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:58.978
org.eclipse.equinox.executable_root.gtk.linux.x86 is missing the filename
property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:58.980
org.eclipse.equinox.executable_root.motif.aix.ppc is missing the filename
property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:58.982
org.eclipse.equinox.executable_root.motif.linux.x86 is missing the
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:58.984
org.eclipse.equinox.executable_root.cocoa.macosx.x86_64 is missing the
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:58.985
org.eclipse.equinox.executable_root.motif.hpux.ia64_32 is missing the
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:58.987
org.eclipse.equinox.executable_root.cocoa.macosx.ppc is missing the
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:58.989
!MESSAGE The installable unit org.eclipse.equinox.executable_root is
missing the filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:58.990
org.eclipse.equinox.executable_root.motif.hpux.PA_RISC is missing the
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:58.992
org.eclipse.equinox.executable_root.motif.solaris.sparc is missing the
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:58.995
org.eclipse.equinox.executable_root.wpf.win32.x86 is missing the filename
property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:58.998
org.eclipse.equinox.executable_root.win32.win32.ia64 is missing the
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.000
org.eclipse.equinox.executable_root.carbon.macosx.ppc is missing the
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.002
org.eclipse.equinox.executable_root.gtk.linux.ppc is missing the filename
property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.003
org.eclipse.equinox.executable_root.gtk.linux.x86_64 is missing the
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.005
org.eclipse.equinox.executable_root.cocoa.macosx.x86 is missing the
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.007
org.eclipse.equinox.executable_root.photon.qnx.x86 is missing the filename
property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.009
org.eclipse.equinox.executable_root.gtk.solaris.sparc is missing the
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.011
org.eclipse.equinox.executable_root.carbon.macosx.x86 is missing the
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.012
org.eclipse.equinox.executable_root.win32.win32.x86 is missing the
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.014
org.eclipse.equinox.executable_root.win32.win32.x86_64 is missing the
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.353
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.355
property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.356
property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.361
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.363
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.364
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.366
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.368
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.371
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.372
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.374
property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.376
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.377
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.380
property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.382
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.384
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.390
property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.392
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.394
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.395
filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-26 14:59:59.397
filename property.
!ENTRY org.eclipse.equinox.p2.engine 4 4 2009-05-26 15:00:02.844
!MESSAGE An error occurred while installing the items
!SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2009-05-26 15:00:02.844
!MESSAGE session context was:(profile=SDKProfile,
phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Install,
operand=null --> [R]org.eclipse.equinox.executable_root
3.3.200.v20090521-1800-7M-Fm-FI3UouOe61h3BYGC,
action=org.eclipse.equinox.internal.p2.touchpoint.natives.ac tions.UnzipAction).
!SUBENTRY 1 org.eclipse.equinox.p2.touchpoint.natives 4 0 2009-05-26
15:00:02.844
!MESSAGE The artifact for
binary,org.eclipse.equinox.executable_root,3.3.200.v20090521 -1800-7M-Fm-FI3UouOe61h3BYGC
is not available.
!ENTRY org.eclipse.equinox.p2.director 4 1 2009-05-26 15:00:03.036
!MESSAGE Cannot complete the install because one or more required items
could not be found.
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2009-05-26 15:00:03.036
!MESSAGE Software being installed: My Platform 2.2.0
(my.feature.feature.group 2.2.0)
!MESSAGE Missing requirement: My RCP 2.2.0 (my.feature.rcp.feature.group
2.2.0) requires 'org.eclipse.rcp.feature.group
[3.5.0.v20090519-9SA-FwxFv6x-rk8-j91Tg58C,3.6.0)' but it could not be found
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2009-05-26 15:00:03.036
!MESSAGE Cannot satisfy dependency:
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2009-05-26 15:00:03.036
!MESSAGE From: My Platform 2.2.0 (my.feature.feature.group 2.2.0)
!MESSAGE To: my.feature.rcp.feature.group [2.2.0]
Re: p2 director can't find binary,org.eclipse.equinox.executable_root [message #63526 is a reply to message #63321] |
Wed, 27 May 2009 19:14 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
There are a couple of bugs that are probably related to this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=248578
https://bugs.eclipse.org/bugs/show_bug.cgi?id=278086
I believe this is related to how you installed the deltapack.
For best results, you want the delta pack to be in your target, but not
in the eclipse that is running the build.
For export, this means don't unzip the deltapack on top of your eclipse
(or into dropins), but instead unzip it into its own directory. Then in
Preferences -> Plug-in Development -> Target Platform, edit the active
target, and add the directory where you extracted the deltapack.
-Andrew
> verified my features and none of them includes
> org.eclipse.equinox.executable. Can someone point how to "fix" this
> -- Euclides
> Log:
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> 15:00:02.844
> is not available.
> could not be found.
Re: p2 director can't find binary,org.eclipse.equinox.executable_root [message #595603 is a reply to message #55503] |
Thu, 16 April 2009 20:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
-Andrew
> runDirector:
> parsing buildfile
> with URI =
> [ant] Entering
> runDirector:
> [java]
> [java] '-jar'
> [java]
> [java] '-nosplash'
> [java] '-flavor'
> [java] 'tooling'
> [java] '-installIU'
> [java] '-version'
> [java] '1.0.0'
> [java] '-p2.os'
> [java] 'win32'
> [java] '-p2.ws'
> [java] 'win32'
> [java] '-p2.arch'
> [java] 'x86'
> [java] '-roaming'
> [java] '-profile'
> [java] 'profile'
> [java]
> [java]
> [java]
> -artifactRepository
> -destination
> -artifactRepository
> -destination
> [java]
> 19:10:31.557
> installed
> 19:10:31.557
> operand=, action=).
> [ant] Exiting
> [antcall] Exiting
> [ant] Exiting
> [ant] Exiting
> [ant] Exiting
> [ant] Exiting
> [antcall] Exiting
> [ant] Exiting
> [antcall] Exiting
> BUILD FAILED
> Java returned: 13
> Wb
Re: p2 director can't find binary,org.eclipse.equinox.executable_root [message #595613 is a reply to message #56265] |
Thu, 16 April 2009 20:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
If you look in
-Andrew
> -Andrew
>> runDirector:
>> parsing buildfile
>> with URI =
>> [ant] Entering
>> runDirector:
>> [java]
>> [java] '-jar'
>> [java]
>> [java] '-nosplash'
>> [java] '-flavor'
>> [java] 'tooling'
>> [java] '-installIU'
>> [java] '-version'
>> [java] '1.0.0'
>> [java] '-p2.os'
>> [java] 'win32'
>> [java] '-p2.ws'
>> [java] 'win32'
>> [java] '-p2.arch'
>> [java] 'x86'
>> [java] '-roaming'
>> [java] '-profile'
>> [java] 'profile'
>> [java]
>> [java]
>> [java]
>> [java]
>> [java]
>> -artifactRepository
>> -destination
>> -artifactRepository
>> -destination
>> [java]
>> 19:10:31.557
>> installed
>> 19:10:31.557
>> operand=, action=).
>> [ant] Exiting
>> [antcall] Exiting
>> [ant] Exiting
>> [ant] Exiting
>> [ant] Exiting
>> [ant] Exiting
>> [antcall] Exiting
>> [ant] Exiting
>> [antcall] Exiting
>> BUILD FAILED
>> Java returned: 13
>> Wb
Re: p2 director can't find binary,org.eclipse.equinox.executable_root [message #595743 is a reply to message #56265] |
Fri, 17 April 2009 15:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Wb
> -Andrew
Re: p2 director can't find binary,org.eclipse.equinox.executable_root [message #597875 is a reply to message #56265] |
Tue, 26 May 2009 18:33 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Junior Member |
-- Euclides
Log:
filename property.
property.
property.
filename property.
filename property.
filename property.
filename property.
filename property.
filename property.
property.
filename property.
filename property.
property.
filename property.
filename property.
property.
filename property.
filename property.
filename property.
filename property.
filename property.
property.
property.
filename property.
filename property.
filename property.
filename property.
filename property.
filename property.
property.
filename property.
filename property.
property.
filename property.
filename property.
property.
filename property.
filename property.
filename property.
filename property.
15:00:02.844
is not available.
could not be found.
Re: p2 director can't find binary,org.eclipse.equinox.executable_root [message #597932 is a reply to message #63321] |
-Andrew
> -- Euclides
> Log:
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> filename property.
> 15:00:02.844
> is not available.
> could not be found.
Current Time: Wed Jul 17 14:54:29 GMT 2024
Powered by FUDForum. Page generated in 0.04984 seconds
