Home » Archived » EPF » EPF Composer X EPF Wiki
EPF Composer X EPF Wiki [message #55492] |
Wed, 11 February 2009 19:52 |
Fernanda Oliveira Messages: 21 Registered: July 2009 |
Junior Member |
I´d like to know, to understand better, what EPF Composer tool has that
EPF Wiki doesn´t have (features).
Maybe a comparison with when I should use one and when I should use another.
I have been using EPF Composer for 2 years, and usually I have problems
with “non-technical” users, because these users that don´t know eclipse
framework/tools in general think it´s complex to use EPF Composer, and
now I think the wiki it is the solution to incentive the processes
documentation by “non-technical” users, because wiki format seems to be
easier to understand.
What I understood until the moment that is the correct way of working:
1) Create the Library: We should create all process structure in EPF
Composer, creating the “Library”, then publish the site.
2) Generate the Wiki: then we should generate the EPF Wiki based on the
generated site.
3) Process Maintanance/Evolution: all users can edit the process and
approve it ni EPF Wiki.
4) Final Release Publish: Then we should “re-generate” the “Library”
(harvesting) to be opened in EPF Composer to execute some structure
changes, if necessary, and publish the final release (EPF Site or Wiki)
with all users modifications.
Is it correct?
Thank you in advance,
Fernanda
Re: EPF Composer X EPF Wiki [message #55776 is a reply to message #55600] |
Tue, 03 March 2009 12:39 |
Junior Member |
Hi Ricardo,
Thank you your information. I think I´m in the right way.
I installed and tested the Wiki and worked fine.
But until the moment I couldn´t discover HOW to transform a wiki in a
EPFC Library. I selected my changes as "Review Completed (harvesting)"
but now I´d like to see how my changes impacted the Library to generate
a release.
Thank you,
Fernanda
Ricardo Balduino escreveu:
> Fernanda,
> At this time, there isn't a comparison table between EPF Composer and EPF
> Wiki (not that I know of). However, your assumptions below (in terms of
> usage model) are correct. The EPF Wiki opens the door for non-technical
> users (non-technical in the sense they don't need to know the process
> metamodel) to collaborate and improve their process descriptions. However, a
> more robust environment to capture, author, extend, configure and publish a
> process is EPF Composer.
> Ricardo.
> "Fernanda Oliveira" <fernanda.stringassi@venturus.org.br> wrote in message
> news:gmvabd$hi9$1@build.eclipse.org...
>> another.
>> framework/tools in general think it´s complex to use EPF Composer, and now
>> generated site.
>> Is it correct?
>> Fernanda
Re: EPF Composer X EPF Wiki [message #591388 is a reply to message #55600] |
Junior Member |
Hi Ricardo,
a release.
Thank you,
Fernanda
> Fernanda,
> Ricardo.
>> another.
>> generated site.
>> Is it correct?
>> Fernanda
Current Time: Sat Oct 19 10:54:24 GMT 2024
Powered by FUDForum. Page generated in 0.03418 seconds
