WTP [message #55488] |
Mon, 06 December 2004 16:07 |
Originally posted by: j_kakar.yahoo.com
I am trying to use Tomcat Web Tooling Platform. I follow the following
link step my setp, but when I try to run the jsp by right clicking I get
the following error.
Thank you in advance
Garandi
03 Dec 2004 18:04:02 - org.apache.slide.common.Domain - INFO -
Auto-Initializing Domain
03 Dec 2004 18:04:02 - org.apache.slide.common.Domain - INFO - Domain
configuration : {org.apache.slide.lock=true,
org.apache.slide.versioncontrol=true, org.apache.slide.debug=false,
org.apache.slide.search=true, org.apache.slide.security=true,
org.apache.slide.urlEncoding=UTF-8,
org.apache.slide.domain=../slide/Domain.xml}
03 Dec 2004 18:04:02 - org.apache.slide.common.Domain - ERROR - Domain
initialization error : ..\slide\Domain.xml (The system cannot find the
path specified)
java.lang.reflect.InvocationTargetException
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 97)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:39 8)
Caused by: org.apache.slide.common.DomainInitializationFailedError: Domain
path specified)
at org.apache.slide.common.Domain.selfInit(Domain.java:752)
at org.apache.slide.common.Domain.accessNamespace(Domain.java:2 35)
at wrappers.catalina.SlideRealm.start(SlideRealm.java:178)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1118)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:521)
org.apache.catalina.core.StandardService.start(StandardServi ce.java:519)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:2345)
at org.apache.catalina.startup.Catalina.start(Catalina.java:594 )
... 6 more
Re: WTP [message #55572 is a reply to message #55488] |
Tue, 07 December 2004 23:09 |
Originally posted by: anonymous.eclipse.org
Are you using tomcat 5.5? I met the similar exception on tomcat 5.5, when
i changed to tomcat 5.0, it was solved.
Weijian
Garandi wrote:
> Garandi
> initialization error : ..slideDomain.xml (The system cannot find the
> path specified)
> path specified)
> at
> ... 6 more
Re: WTP [message #55597 is a reply to message #55572] |
Wed, 08 December 2004 15:28 |
I am using tomcat 5.0
Thank you
Garandi
> Weijian
> Garandi wrote:
>> Garandi
>> path specified)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> path specified)
>> at
>> ... 6 more
FUDForum. Page generated in 1.89252 seconds
