Information about AJDT release streams [message #55404] |
Mon, 25 July 2005 14:34 |
Originally posted by: mchapman.uk.ibm.com
As we work towards better support for Eclipse 3.1, we have had to separate
AJDT into two release streams. The AJDT 1.2 line will continue to support
Eclipse 3.0, with the next release being 1.2.1. The AJDT 1.3 line will
support Eclipse 3.1, beginning with 1.3.0 which is planned for September.
Both of these releases will contain the same function and bug fixes,
except of course for anything specific to either of the Eclipse versions.
The development builds section of the AJDT download page:
http://www.eclipse.org/ajdt/downloads/#dev
has been updated to show the most recent development builds for each
release stream. The latest builds for Eclipse 3.1 now have appropriate
version numbers beginning 1.3.0.
There is also a build report link for each build, showing exactly what has
changed in that build compared with the previous one.
Extra information for those working with the AJDT source code:
CVS HEAD contains the source code for the AJDT 1.3 line, and the new
"ajdt1_2" branch contains the AJDT 1.2 line. For more details, see
updated FAQ entry 4.3: How do I setup an AJDT development environment in
Eclipse?
Matt.
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Re: Information about AJDT release streams [message #55512 is a reply to message #55431] |
Tue, 26 July 2005 09:53 |
On Mon, 25 Jul 2005 12:45:40 -0700, Barry Kaplan wrote:
> What version of aspectj is the 3.1 stream currently using? Is it always
> the latest dev release?
It is using a dev build of aspectj from 20 June. It is only updated when
aspectj reaches a stable point, such as a milestone release, or when a
particular fix or change is needed urgently.
Matt.
FUDForum. Page generated in 0.04171 seconds
