[xText] Error indexin EPackages from registry [message #55363] |
Fri, 03 July 2009 12:50 |
Originally posted by: anders.hessellund.gmail.com
I've created a little grammar and generated an editor. It works fine
although I noticed a strange error message in the Error Log. Is this
something that I should worry about?
org.eclipse.emf.common.util.WrappedException:
java.lang.ClassNotFoundException:
com.sun.java.xml.ns.persistence.orm.OrmPackage
org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(RegistryReader.java:279)
org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegistryImpl.java:133)
org.eclipse.emf.index.ecore.impl.EcoreIndexFeederImpl.feedEP ackagesFromRegistry(EcoreIndexFeederImpl.java:72)
org.eclipse.emf.index.ui.builder.IndexStartupInitializer.ear lyStartup(IndexStartupInitializer.java:58)
org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup (EarlyStartupRunnable.java:87)
org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartu pRunnable.java:66)
at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2192 )
Caused by: java.lang.ClassNotFoundException:
org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:489)
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:321)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:231)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1193)
org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(RegistryReader.java:272)
.... 8 more
Re: [xText] Error indexin EPackages from registry [message #55498 is a reply to message #55445] |
Fri, 03 July 2009 14:00 |
Sebastian Zarnekow wrote:
> Hi Anders,
> this is a bug in the Xtext 0.7.0 release, that is shiped with the EPP
> build. You may want to try the itemis distro from
> http://xtext.itemis.com which contains several other bugfixes and a more
> complete documentation.
> Sorry for inconvenience,
> Sebastian
> Am 03.07.2009 14:52 Uhr, schrieb Anders Hessellund:
>> Ups, perhaps I should mention that I'm running on the new Galileo
>> package "Eclipse Modeling Tools (includes Incubating components)" with
>> xText 0.7.
Ok, thanks for the reply
FUDForum. Page generated in 0.02960 seconds
