Re: Node with multiple Connection [message #55358 is a reply to message #55307] |
Mon, 25 September 2006 16:27 |
Originally posted by: 5d5.mail.ru
I guess that something went wrong with your mapping or gmfgen model; it
would be helpful to see them.
Balraj Kannan wrote:
> I have an element which can have connections to many elements. I have
> label associated with the link. To achieve i have done the following:
> <nodea>
> <nodeb>
> <nodec>
> <relationship source="nodea" target_nodeb="nodeb" label="optional">
> <relationship source="nodea" target_nodec="nodec" label="mandatory">
> I have elements "nodea", "nodeb", "nodec" and "relationship". Node
> relationship is used to hold the link label, source and target links. I
> have attributes target_nodeb and target_nodec defined which are used to
> hold the link. When this is implemented I see that the label is shown
> only for the first link that is created in the mapping file. The label
> is not shown for the second element added. To test if I was going wrong
> in mapping or something I did the following:
> From the mapping file I deleted the first link mapping for nodea and
> nodeb, then generated the code. This showed the label for nodea and
> nodec mapping.
> The model file is generated correctly but the label is not displayed on
> the editor.
> I am going wrong somewhere? Please suggest.
> Thanks & Regards
> Balraj
FUDForum. Page generated in 0.03330 seconds
