Home » Modeling » Epsilon » org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog
Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #5676 is a reply to message #5325] |
Wed, 26 November 2008 15:05 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Nicolas,
I just set up a fresh copy of 3.5M3, installed EMF/GMF/UML2 etc, checked
out the code of Epsilon from the SVN and the
WizardsExtensionPreferenceDialog seems to be working under this setup.
I'm pretty much clueless as to what the problem could be or what to try
next...
Dimitrios
Nicolas Rouquette wrote:
> Hi Dimitrios,
> I am running 3.5M3 on Windows XP Pro SP3.
> Basically, I get the same dialog as you except that there is no
> "Namespace URI:" field and no "Wizards" field and no "Browse
> workspace..." button either.
> Just the title, message, OK and Cancel.
> I filed a bug: 256473
> -- Nicolas.
> Dimitrios Kolovos wrote:
>> Hi Nicolas,
>> Strange... I've just checked and it seems to be working fine with my
>> 3.4.1/WinXP setup (see attached screenshot). What OS are you running?
>> Cheers,
>> Dimitrios
>>> Hi,
>>> Epsilon (from SVN) seems to be OK on 3.4 and 3.5M3 except for the
>>> WizardsExtensionPreferenceDialog which shows just the text, label and
>>> OK/Cancel buttons.
>>> There is no field editor for selecting the namespace.
>>> There is no selector for choosing the *.ewl file.
>>> Is this normal?
>>> -- Nicolas.
Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #5694 is a reply to message #5676] |
Wed, 26 November 2008 23:25 |
Nicolas Rouquette Messages: 157 Registered: July 2009 |
Hi Dimitrios,
I seems that the problem is that the TitleDialog isn't resized.
The WizardsExtensionPreferenceDialog.createDialogArea(Composite) method
does construct the two widgets but it seems that the geometry of the
dialog itself isn't re-computed so it shows up as a default-size dialog
instead of a dialog sized to accomodate all of the widgets.
I don't know how to force the dialog geometry/layout to be computed but
I'm willing to try that if you can offer a suggestion.
-- Nicolas.
> Hi Nicolas,
> next...
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> -- Nicolas.
>>> Hi Nicolas,
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> and OK/Cancel buttons.
>>>> Is this normal?
>>>> -- Nicolas.
Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #5712 is a reply to message #5694] |
Thu, 27 November 2008 10:19 |
Hi Nicolas,
I've changed the code a bit and removed a suspicious statement
(preferredSize.height = 210;). Could you please update from the SVN and
let me know if it works now?
Dimitrios
> Hi Dimitrios,
> -- Nicolas.
>> Hi Nicolas,
>> checked out the code of Epsilon from the SVN and the
>> try next...
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> -- Nicolas.
>>>> Hi Nicolas,
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi,
>>>>> Is this normal?
>>>>> -- Nicolas.
Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #5729 is a reply to message #5712] |
Fri, 28 November 2008 07:23 |
Hi Dimitrios,
It works for me! Thanks!
-- Nicolas.
> Hi Nicolas,
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> method does construct the two widgets but it seems that the geometry
>> of the dialog itself isn't re-computed so it shows up as a
>> default-size dialog instead of a dialog sized to accomodate all of the
>> widgets.
>> but I'm willing to try that if you can offer a suggestion.
>> -- Nicolas.
>>> Hi Nicolas,
>>> setup. I'm pretty much clueless as to what the problem could be or
>>> what to try next...
>>> Cheers,
>>> Dimitrios
>>>> Hi Dimitrios,
>>>> -- Nicolas.
>>>>> Hi Nicolas,
>>>>> my 3.4.1/WinXP setup (see attached screenshot). What OS are you
>>>>> running?
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Hi,
>>>>>> Is this normal?
>>>>>> -- Nicolas.
Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #5746 is a reply to message #5729] |
Fri, 28 November 2008 10:01 |
Hi Nicolas,
Glad it helped and thanks for your persistence and patience with this!
Dimitrios
> Hi Dimitrios,
> -- Nicolas.
>> Hi Nicolas,
>> and let me know if it works now?
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> the widgets.
>>> -- Nicolas.
>>>> Hi Nicolas,
>>>> what to try next...
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi Dimitrios,
>>>>> -- Nicolas.
>>>>>> Hi Nicolas,
>>>>>> running?
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> Hi,
>>>>>>> Is this normal?
>>>>>>> -- Nicolas.
Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #562517 is a reply to message #5325] |
Hi Nicolas,
next...
Dimitrios
> Hi Dimitrios,
> -- Nicolas.
>> Hi Nicolas,
>> Cheers,
>> Dimitrios
>>> Hi,
>>> OK/Cancel buttons.
>>> Is this normal?
>>> -- Nicolas.
Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #562541 is a reply to message #5676] |
Hi Dimitrios,
-- Nicolas.
> Hi Nicolas,
> next...
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> -- Nicolas.
>>> Hi Nicolas,
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> Is this normal?
>>>> -- Nicolas.
Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #562564 is a reply to message #5694] |
Hi Nicolas,
Dimitrios
> Hi Dimitrios,
> -- Nicolas.
>> Hi Nicolas,
>> try next...
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> -- Nicolas.
>>>> Hi Nicolas,
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi,
>>>>> Is this normal?
>>>>> -- Nicolas.
Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #562586 is a reply to message #5712] |
Hi Dimitrios,
-- Nicolas.
> Hi Nicolas,
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> widgets.
>> -- Nicolas.
>>> Hi Nicolas,
>>> what to try next...
>>> Cheers,
>>> Dimitrios
>>>> Hi Dimitrios,
>>>> -- Nicolas.
>>>>> Hi Nicolas,
>>>>> running?
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Hi,
>>>>>> Is this normal?
>>>>>> -- Nicolas.
Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #562604 is a reply to message #5729] |
Hi Nicolas,
Dimitrios
> Hi Dimitrios,
> -- Nicolas.
>> Hi Nicolas,
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> the widgets.
>>> -- Nicolas.
>>>> Hi Nicolas,
>>>> what to try next...
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi Dimitrios,
>>>>> -- Nicolas.
>>>>>> Hi Nicolas,
>>>>>> running?
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> Hi,
>>>>>>> Is this normal?
>>>>>>> -- Nicolas.
Current Time: Sat Oct 19 14:56:22 GMT 2024
Powered by FUDForum. Page generated in 0.06100 seconds
