Home » Modeling » GMF (Graphical Modeling Framework) » How to model in XSD?
How to model in XSD? [message #55279] Mon, 25 September 2006 11:44 Go to next message
Hey,
I'm having trouble with building a model for gmf in a xsd file.
I want to start off with a very simple model that contains only one type
of element that can then be associated with other elements (a directed
association) of the same type. The element will have some attributes (or
should these be elements?) as well but it's doing the association I don't
understand.
What I want to model is a simple dialogue that is divided into segments.
Each node to be a segment in a graph structure.
Is there any documentation on this? Cheers.
So something like:
<xsd:schema
targetNamespace="http://www.example.org/dialoguegraph"
xmlns:dialoguegraph="http://www.example.org/dialoguegraph"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore">
<xsd:complexType name="DialogueSegment">
<xsd:attribute name="intro_text" type="xsd:string"/> //set to max of one
<xsd:attribute name="transcript" type="xsd:string"/> //set to max of one
<xsd:attribute name="outro_text" type="xsd:string"/> //0..*
</xsd:complexType>
//set the relatonship between nodes?????
</xsd:schema>
Re: How to model in XSD? [message #55332 is a reply to message #55279] Mon, 25 September 2006 11:50 Go to previous messageGo to next message
--------------060004020504010204010907
Gaff,
Probably you'll want to read this document:
XML Schema to Ecore Mapping
< http://www.eclipse.org/emf/docs/overviews/XMLSchemaToEcoreMa pping.pdf>
This EMF tutorial shows how ecore:reference in combination with anyURI
or IDREF can be used to define references between objects.
Tutorial: Generating an EMF Model using XML Schema
< http://dev.eclipse.org/viewcvs/indextools.cgi/*checkout*/org .eclipse.emf/doc/org.eclipse.emf.doc/tutorials/xlibmod/xlibm od.html>
Gaff wrote:
> Hey,
> type of element that can then be associated with other elements (a
> directed association) of the same type. The element will have some
> attributes (or should these be elements?) as well but it's doing the
> association I don't understand.
> segments. Each node to be a segment in a graph structure.
> So something like:
> <xsd:schema targetNamespace="http://www.example.org/dialoguegraph"
> </xsd:complexType>
> </xsd:schema>
<html>
<head>
http-equiv="Content-Type">
</head>
Gaff,<br>
<br>
Probably you'll want to read this document:<br>
<blockquote><a
href=" http://www.eclipse.org/emf/docs/overviews/XMLSchemaToEcoreMa pping.pdf">XML
Schema to Ecore Mapping</a><br>
</blockquote>
or IDREF can be used to define references between objects.<br>
<blockquote><a
href=" http://dev.eclipse.org/viewcvs/indextools.cgi/*checkout*/org .eclipse.emf/doc/org.eclipse.emf.doc/tutorials/xlibmod/xlibm od.html">Tutorial:
Generating an EMF Model using XML Schema</a><br>
</blockquote>
<br>
Gaff wrote:
<blockquote cite="mid4af494102978b95747fb7ee1a64f7860$1@www.eclipse.org"
type="cite">Hey,
<br>
<br>
I'm having
Re: How to model in XSD? [message #55706 is a reply to message #55332] Tue, 26 September 2006 05:58 Go to previous messageGo to next message
Cheers, the XML Schema to Ecore Mapping is good for the syntax but not
sure it really explains what needs to be in the file. Like, do I need to
have an abstract definition first that contains all other figures? Do I
need to state which is the diagram root element in the xsd file?
Is this kind of stuff explained anywhere?
To start with i'm just trying to get a node worknig by itself, the xsd is
below, I've tried getting an editor working with it and get as far as
ECore to GMFGraph, Diagram root element, as all the code is generated from
my model there must be something wrong with it:
(BTW, thanks for your hwelp ED)
<xsd:schema
xmlns:mindmap="http://www.example.org/mindmap"
<xsd:complexType name="DiaSeg">
<xsd:sequence>
<xsd:element maxOccurs="unbounded" minOccurs="0" name="intro"
type="xsd:string"/>
<xsd:element maxOccurs="unbounded" minOccurs="0" name="transcript"
type="xsd:string"/>
<xsd:element maxOccurs="unbounded" minOccurs="0" name="outro"
type="xsd:string"/>
</xsd:sequence>
<xsd:attribute name="alittlebit" type="xsd:string"/>
</xsd:complexType>
</xsd:schema>
Re: How to model in XSD? [message #55735 is a reply to message #55706] Tue, 26 September 2006 08:07 Go to previous message
--------------000605080806030505000705
Gaff,
I can't really answer questions about how you should model something
(since I don't really know what goal you are trying to achieve and don't
have the time). Typically its a good idea to define a global element for
anything you wish to serialize at the root of a document. If you
already know the model you want, but don't know how to write it as a
schema, you might want to try creating the Ecore model directly,
creating a GenModel for it, and then exporting the corresponding
schema. This demo might help:
http://adobedev.breezecentral.com/p17835008/
You should try to ask more specific questions because open ended ones
that require a long story are much less likely to get the kind of
information you are looking for...
> to have an abstract definition first that contains all other figures?
> Do I need to state which is the diagram root element in the xsd file?
> is below, I've tried getting an editor working with it and get as far
> as ECore to GMFGraph, Diagram root element, as all the code is
> generated from my model there must be something wrong with it:
> <xsd:schema xmlns:mindmap="http://www.example.org/mindmap"
> <xsd:sequence>
> type="xsd:string"/>
> type="xsd:string"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
<html>
<head>
</head>
Gaff,<br>
<br>
don't have the time). Typically its a good idea to define a global
element for anything you wish to serialize at the root of a document.
Previous Topic:direct editing
Next Topic:UML2 example
Current Time: Thu Nov 06 22:06:59 EST 2025
Powered by FUDForum. Page generated in 0.03710 seconds
