Re: NullPointerException when trying to view Coverage Statistics [message #55726 is a reply to message #55265] |
Tue, 28 February 2006 20:53 |
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 0072BE9985257123_=
Content-Type: text/plain; charset="US-ASCII"
Seems like a strange issue.
1) Do you experience the same problem when you select different profiling
options?
2) Have you defined a custom filterset? If so, can you try profiling with
the default filterset to see if you have the same problem?
3) Can you profile to a file instead and post the trace file here? To
profile to a file: Select the profiling tab of your launch configuration
-> click on the destination tab -> Send profiling data to a file
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Seems like a strange issue.</font>
<br>
<br><font size=2 face="sans-serif">1) Do you experience the same problem
when you select different profiling options?</font>
<br><font size=2 face="sans-serif">2) Have you defined a custom filterset?
If so, can you try profiling with the default filterset to see if you have
the same problem?</font>
<br><font size=2 face="sans-serif">3) Can you profile to a file instead
and post the trace file here? To profile to a file: Select the profiling
tab of your launch configuration -> click on the destination tab ->
Send profiling data to a file</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 0072BE9985257123_=--
FUDForum. Page generated in 0.03431 seconds
