Home » Eclipse Projects » Plugin Development Environment (PDE) » Don't succeed to fetch bundles with p2IU
Don't succeed to fetch bundles with p2IU [message #55256] Wed, 15 April 2009 06:02 Go to next message
Originally posted by: mickael.istria.openwide.fr
Hi all,
I am trying to use the ability to fetch plugins from map files using the
new p2IU fetch type with Galileo M6 (I20090313-0100).
However, I cannot get it working, and more generally, I cannot install
anything using p2 director app with all p2 repos/update-sites I tried
(Galileo, JWT, Orbit and an internal one). I've already checked that the
units I am trying to install exist with the good version in the
content.xml file.
The behavior I always get is "The installable unit <...> has not been
found.".
Has anybody here already got p2 director app and/or p2IU fetch working
with Galileo M6 ? If yes, I'd really appreciate some help and some
pointers to go ahead.
Thanks in advance,
Mickael
Re: Don't succeed to fetch bundles with p2IU, nor to use p2 director [message #55586 is a reply to message #55256] Thu, 16 April 2009 03:52 Go to previous messageGo to next message
[Cross-posted to platform]
Hi again,
In case it can help you to understand my problem, here is the command I
use to install IU. I assume that p2IU fetch runs something similar.
java -jar
plugins/org.eclipse.equinox.launcher_1.0.200.v20090306-1900. jar
-application org.eclipse.equinox.p2.director.app.application
-metadataRepository http://download.eclipse.org/releases/galileo/
-artifactRepository http://download.eclipse.org/releases/galileo/
-installIU org.eclipse.uml2.uml -version 3.0.0 -consoleLog
==============> Returns
!ENTRY org.eclipse.equinox.p2.director.app 4 0 2009-04-16 08:39:46.104
!MESSAGE The installable unit org.eclipse.uml2.uml has not been found.
Whereas org.eclipse.uml2.uml is an available unit.
I had the same result for any IU.
Could this be a bug in p2 director app? Or a breaking change that I missed?
Thanks in advance for your help
Mickael Istria a écrit :
> Hi all,
> content.xml file.
> found.".
> Thanks in advance,
> Mickael
Re: Don't succeed to fetch bundles with p2IU, nor to use p2 director [message #55856 is a reply to message #55586] Thu, 16 April 2009 10:26 Go to previous messageGo to next message
> Hi again,
> java -jar
While I think that should still work (you're correct, it's in the
content.xml), that's a plugin IU ... the actual feature IU would be
org.eclipse.uml2.feature.group Does it work better if you try that?
What if you leave off the -version?
You've probably seen
http://wiki.eclipse.org/Equinox_p2_director_application and it looks
like you are using the example from that page. What if you use the one
with more arguments (I use in my scripts, for example) from
http://wiki.eclipse.org/Equinox_p2_director_application/Exam ples/Install_into_eclipse_using_SDKProfile
Later,
PW
Paul Webster
Re: Don't succeed to fetch bundles with p2IU, nor to use p2 director [message #56554 is a reply to message #55856] Fri, 17 April 2009 05:43 Go to previous message
>> Hi again,
>> I use to install IU. I assume that p2IU fetch runs something similar.
>> java -jar
>> missed?
> Later,
> PW
Hello Paul,
I get this error with any installation unit (plugin or feature).
I've tried with several arguments combination, and always get the same
result. Moreover, that same command-line works well with a Ganymede, and
also with a Galileo m6 on a colleague's machine.
Then it is probably an inconsistency in my Eclipse, I'll reinstall the
latest EPP build one hoping I'll be able to use p2 and to fetch p2IU in
builds.
I'll open a bug if I can reproduce it with my newer Eclipse.
Thanks for your help.
Mickael
Re: Don't succeed to fetch bundles with p2IU, nor to use p2 director [message #595371 is a reply to message #55256] Thu, 16 April 2009 03:52 Go to previous message
Hi again,
java -jar
> Hi all,
> content.xml file.
> found.".
> Thanks in advance,
> Mickael
Re: Don't succeed to fetch bundles with p2IU, nor to use p2 director [message #595459 is a reply to message #55586] Thu, 16 April 2009 10:26 Go to previous message
> Hi again,
> java -jar
Later,
PW
Paul Webster
Re: Don't succeed to fetch bundles with p2IU, nor to use p2 director [message #595687 is a reply to message #55856] Fri, 17 April 2009 05:43 Go to previous message
>> Hi again,
>> java -jar
>> missed?
> Later,
> PW
Hello Paul,
builds.
Mickael
Previous Topic:How to manually mark editor dirty?
Next Topic:Executing External tool (.exe,.bat etc) from the plugin
Current Time: Tue Nov 04 03:30:47 EST 2025
Powered by FUDForum. Page generated in 0.25514 seconds
