Home » Eclipse Projects » GEF » Drag-and-Drop
Drag-and-Drop [message #55229] Thu, 16 January 2003 10:53 Go to next message
Originally posted by: jan.odvarko.schemantix.com
Hi All,
I am using drag-and-drop facility of the GEF
and I am able to transfer a simple text (i.e. String)
by that operation.
The problem is, that I don't know how to
transfer a reference to a java object.
Should I use another transfer class
(something instead of the TextTransfer class)?
Where could I take a look?
Thanks for any help.
Honza
Re: Drag-and-Drop [message #55359 is a reply to message #55229] Thu, 16 January 2003 14:52 Go to previous message
Yes, you'll need to use a different Transfer. I'm not sure which objects you're trying to drag, so
I don't know which Transfer you should use. You should look at the view you want to drag from and
find out which transfer they use.
Eric
Jan Odvárko wrote:
> Hi All,
> by that operation.
> Honza
Previous Topic:Problems in running latest GEF and Logic Editor Example I20030114 on Eclipse I20030114
Next Topic:Runtime workbech hangs after moving a node in graphical editor
Current Time: Thu Sep 18 11:12:15 EDT 2025
Powered by FUDForum. Page generated in 0.05805 seconds
