Home » Eclipse Projects » GEF » Problems in running latest GEF and Logic Editor Example I20030114 on Eclipse I20030114
Problems in running latest GEF and Logic Editor Example I20030114 on Eclipse I20030114 [message #55070] Wed, 15 January 2003 10:52 Go to next message
Originally posted by: sy_cheung2.yahoo.com
I download the latest GEF and Eclipse Integrated build I20030114 .
When I try to create a Logic Diagram from the wizard, I get the following
exception. I check the class "org/eclipse/gef/internal/GEFMessages" is in
gef.jar. So I dont' understand why it can't find this class but it can find
other classes in GEF. After I press "Finish" 2 more times, I am able to exit
the Creation wizard. But when I look at the editor, it does not have tool
bar.
Thanks for any help.
!MESSAGE org/eclipse/gef/internal/GEFMessages
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/gef/internal/GEFMessages
org.eclipse.gef.examples.logicdesigner.LogicActionBarContrib utor.createActio
ns(LogicActionBarContributor.java:46)
org.eclipse.gef.ui.actions.ActionBarContributor.init(ActionB arContributor.ja
va:187)
org.eclipse.ui.part.EditorActionBarContributor.init(EditorAc tionBarContribut
or.java:113)
org.eclipse.ui.internal.EditorManager.createEditorActionBars (EditorManager.j
ava:166)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:576)
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:
621)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager
..java:429)
org.eclipse.ui.internal.EditorManager.openEditorFromInput(Ed itorManager.java
:303)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:394)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1840)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1678)
org.eclipse.gef.examples.logicdesigner.CreateLogicPage1.fini sh(CreateLogicPa
ge1.java:110)
org.eclipse.gef.examples.logicdesigner.LogicCreationWizard.p erformFinish(Log
icCreationWizard.java:30)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:570)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:308)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:398)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:87)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:836)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1692)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1410)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:561 )
at org.eclipse.jface.window.Window.open(Window.java:541)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:109)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:804 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:422)
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionCont
ributionItem.java:374)
org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionI
tem.java:368)
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(A
ctionContributionItem.java:69)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1467)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1450)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:462)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
!ENTRY org.eclipse.ui.workbench 4 2 Jan 15, 2003 09:46:09.298
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
org.eclipse.gef.ui.actions.ActionBarContributor.setActiveEdi tor(ActionBarCon
tributor.java:202)
org.eclipse.ui.internal.EditorActionBars.partChanged(EditorA ctionBars.java:1
74)
at org.eclipse.ui.internal.WorkbenchPage$2.run(WorkbenchPage.ja va:364)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:852)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
org.eclipse.ui.internal.WorkbenchPage.activatePart(Workbench Page.java:356)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2258)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:345)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1855)
ge1.java:110)
tem.java:368)
a:845)
..java:25)
!ENTRY org.eclipse.ui.workbench 4 2 Jan 15, 2003 09:46:10.941
!STACK 0
org.eclipse.gef.ui.actions.SelectionAction.update(SelectionA ction.java:84)
org.eclipse.gef.ui.parts.GraphicalEditor.updateAction(Graphi calEditor.java:2
78)
org.eclipse.gef.ui.parts.GraphicalEditor.updateSelectionDepe ndentActions(Gra
phicalEditor.java:291)
org.eclipse.gef.ui.parts.GraphicalEditor.selectionChanged(Gr aphicalEditor.ja
va:229)
org.eclipse.ui.internal.AbstractSelectionService$3.run(Abstr actSelectionServ
ice.java:137)
:852)
org.eclipse.ui.internal.AbstractSelectionService.fireSelecti on(AbstractSelec
tionService.java:135)
org.eclipse.ui.internal.AbstractSelectionService.partActivat ed(AbstractSelec
tionService.java:238)
org.eclipse.ui.internal.WWinPartService$1.partActivated(WWin PartService.java
:23)
org.eclipse.ui.internal.PartListenerList2$1.run(PartListener List2.java:39)
:852)
org.eclipse.ui.internal.PartListenerList2.firePartActivated( PartListenerList
2.java:37)
org.eclipse.ui.internal.WorkbenchPage.firePartActivated(Work benchPage.java:1
093)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2272)
ge1.java:110)
tem.java:368)
a:845)
..java:25)
Re: Problems in running latest GEF and Logic Editor Example I20030114 on Eclipse I20030114 [message #55149 is a reply to message #55070] Wed, 15 January 2003 15:04 Go to previous messageGo to next message
I found that the logic example is still refering to org.eclipse.gef.internal
class that is no longer exported. If you edit the gef plugin.xml file
(located in \eclipse\plugins\org.eclipse.gef_2.0.1 directory) and add the
following line it will start working (I guess someone will have to update
the example to eliminate this internal usage).
<export name="org.eclipse.gef.internal.*"/>
"Sam Cheung" <sy_cheung2@yahoo.com> wrote in message
news:b03v5b$co4$1@rogue.oti.com...
find
exit
> bar.
> !STACK 0
> at
> at
> va:187)
> at
> or.java:113)
> at
> ava:166)
> at
> at
> 621)
> at
> .java:429)
> at
> :303)
> at
> at
> at
> at
> ge1.java:110)
> at
> at
> at
> at
> at
> at
> at
> tem.java:368)
> at
> at
> a:845)
> at
> at
> .java:25)
> !STACK 0
> java.lang.NullPointerException
> at
> tributor.java:202)
> at
> 74)
> at
> :852)
> at
> at
> at
> at
> at
> ge1.java:110)
> at
> at
> at
> at
> at
> at
> at
> tem.java:368)
> at
> at
> a:845)
> at
39
> at
> .java:25)
> !STACK 0
> at
> at
> 78)
> at
> at
> va:229)
> at
> ice.java:137)
> at
> :852)
> at
> at
> at
> :23)
> at
> at
> :852)
> at
> 2.java:37)
> at
> 093)
> at
> at
> at
> at
> ge1.java:110)
> at
> at
> at
> at
> at
> at
> at
> tem.java:368)
> at
> at
> a:845)
> at
> at
> .java:25)
Re: Problems in running latest GEF and Logic Editor Example I20030114 on Eclipse I20030114 [message #55176 is a reply to message #55149] Wed, 15 January 2003 15:14 Go to previous message
I'm fixing this now. It will be fixed by tomorrow's build. We intentionally don't export internal
packages, but unfortunately Eclipse doesn't notify you of this during development. We were running
the logic example with no idea there was a problem.
>>Hi,
> find
> exit
>>bar.
>>!STACK 0
>> at
>> at
>>va:187)
>> at
>>or.java:113)
>> at
>>ava:166)
>> at
>> at
>>621)
>> at
>>.java:429)
>> at
>>:303)
>> at
>> at
>> at
>> at
>>ge1.java:110)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>tem.java:368)
>> at
>> at
>>a:845)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>>.java:25)
>>!STACK 0
>> at
>>tributor.java:202)
>> at
>>74)
>> at
>>:852)
>> at
>> at
>> at
>> at
>> at
>>ge1.java:110)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>tem.java:368)
>> at
>> at
>>a:845)
>> at
> 39
>> at
>>.java:25)
>>!STACK 0
>> at
>> at
>>78)
>> at
>> at
>>va:229)
>> at
>>ice.java:137)
>> at
>>:852)
>> at
>> at
>> at
>>:23)
>> at
>> at
>>:852)
>> at
>>2.java:37)
>> at
>>093)
>> at
>> at
>> at
>> at
>>ge1.java:110)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>tem.java:368)
>> at
>> at
>>a:845)
>> at
>> at
>>.java:25)
Previous Topic:Logic Example I20030114 is broken under Linux
Next Topic:Drag-and-Drop
Current Time: Thu Mar 13 13:43:57 EDT 2025
Powered by FUDForum. Page generated in 0.07351 seconds
